RTEMS
6.3
Toggle main menu visibility
bsps
include
bsp
fdt.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (C) 2015, 2017 embedded brains GmbH & Co. KG
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
27
28
#ifndef LIBBSP_SHARED_FDT_H
29
#define LIBBSP_SHARED_FDT_H
30
31
#include <bsp.h>
32
33
#ifdef __cplusplus
34
extern
"C"
35
#endif
/* __cplusplus */
36
37
38
* BSPs that implement the FDT support functions must define
39
* BSP_FDT_IS_SUPPORTED.
40
41
53
void
bsp_fdt_copy(
const
void
*src);
54
60
const
void
bsp_fdt_get
void
61
74
uint32_t
bsp_fdt_map_intr
const
uint32_t *intr,
size_t
icells);
75
76
#ifdef __cplusplus
77
78
#endif
/* __cplusplus */
79
80
#endif
/* LIBBSP_SHARED_FDT_H */
bsp_fdt_get
const void * bsp_fdt_get(void)
Returns the FDT of the BSP.
Definition
bsp_fdt.c:40
bsp_fdt_map_intr
uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
Maps the interrupt number of the FDT to the interrupt vector used by the interrupt management.
Definition
bsp_fdt.c:45
