RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
shared
vme
bspVmeDmaListP.h
1
8
9
#ifndef BSP_VME_DMA_LIST_P_H
10
#define BSP_VME_DMA_LIST_P_H
11
12
bsp/bspVmeDmaList.h
13
14
15
* This is used by chip drivers to implement the
16
* 'class' members so that 'bspVmeDmaList' can access
17
* the device in an abstract manner.
18
19
20
21
* Authorship
22
23
* This software was created by
24
* Till Straumann <strauman@slac.stanford.edu>, 2006, 2007
25
* Stanford Linear Accelerator Center, Stanford University.
26
27
* Acknowledgement of sponsorship
28
29
* This software was produced by
30
* the Stanford Linear Accelerator Center, Stanford University,
31
* under Contract DE-AC03-76SFO0515 with the Department of Energy.
32
33
* Government disclaimer of liability
34
35
* Neither the United States nor the United States Department of Energy,
36
* nor any of their employees, makes any warranty, express or implied, or
37
* assumes any legal liability or responsibility for the accuracy,
38
* completeness, or usefulness of any data, apparatus, product, or process
39
* disclosed, or represents that its use would not infringe privately owned
40
* rights.
41
42
* Stanford disclaimer of liability
43
44
* Stanford University makes no representations or warranties, express or
45
* implied, nor assumes any liability for the use of this software.
46
47
* Stanford disclaimer of copyright
48
49
* Stanford University, owner of the copyright, hereby disclaims its
50
* copyright and all other rights in this software. Hence, anyone may
51
* freely use it for any purpose without restriction.
52
53
* Maintenance of notices
54
55
* In the interest of clarity regarding the origin and status of this
56
* SLAC software, this and all the preceding Stanford University notices
57
* are to remain affixed to any copy or derivative of this software made
58
* or distributed by the recipient and are to be affixed to any copy of
59
* software made or distributed by the recipient that contains a copy or
60
* derivative of this software.
61
62
* ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
63
64
#ifdef __cplusplus
65
extern
"C"
66
#endif
67
68
typedef
void
*DmaDescriptor;
69
77
78
typedef
DmaDescriptor (*DmaDescriptorAlloc)(void);
79
typedef
void (*DmaDescriptorFree) (DmaDescriptor d);
80
typedef
void (*DmaDescriptorInit) (DmaDescriptor d);
81
/* Setup takes the parameters declared in VMEDMA.h */
82
typedef
int (*DmaDescriptorSetup)(DmaDescriptor d, uint32_t, uint32_t, uint32_t, uint32_t, uint32_t);
83
typedef
void (*DmaDescriptorSetNxt)(DmaDescriptor d, DmaDescriptor next);
84
typedef
int (*DmaDescriptorStart)(
volatile
void
*controller_addr,
int
channel, DmaDescriptor);
85
typedef
int (*DmaDescriptorRefr) (DmaDescriptor);
86
typedef
void (*DmaDescriptorDump) (DmaDescriptor);
87
88
89
typedef
struct
VMEDmaListClassRec_
90
int
desc_size;
/* size of a descritor */
91
int
desc_align;
/* alignment of a descriptor */
92
VMEDmaListNode freeList;
/* list of free descriptors of this class, MUST be initialized to NULL */
93
DmaDescriptorAlloc desc_alloc;
/* [optional, may be NULL] allocator for one descriptor */
94
DmaDescriptorFree desc_free;
/* [optional, may be NULL] destructor for one descriptor */
95
DmaDescriptorInit desc_init;
/* [optional, may be NULL] set stuff that don't change during lifetime */
96
DmaDescriptorSetNxt desc_setnxt;
/* set 'NEXT' pointer in descriptor; mark as LAST if next == 0 */
97
DmaDescriptorSetup desc_setup;
/* setup a descriptor */
98
DmaDescriptorStart desc_start;
/* start list at a descriptor */
99
DmaDescriptorRefr desc_refr;
/* refresh a descriptor */
100
DmaDescriptorDump desc_dump;
/* dump a descriptor (for debugging) */
101
} VMEDmaListClassRec;
102
103
#ifdef __cplusplus
104
105
#endif
106
107
#endif
bspVmeDmaList.h
This header should only be used inside a BSP chosing to use bspVmeDmaList for implementing VMEDMA....
VMEDmaListClassRec_
Definition
bspVmeDmaListP.h:89
