RTEMS
6.3
Toggle main menu visibility
bsps
sparc64
include
boot
ofw_tree.h
1
2
* Copyright (c) 2006 Jakub Jermar
3
* All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
9
* - Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* - Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
* - The name of the author may not be used to endorse or promote products
15
* derived from this software without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
18
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
19
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
20
* IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
21
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
22
* NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
26
* THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27
28
29
#ifndef BOOT_OFW_TREE_H_
30
#define BOOT_OFW_TREE_H_
31
32
#include <boot/types.h>
33
#include <boot/ofw.h>
34
35
37
typedef
struct
38
char
name[OFW_TREE_PROPERTY_MAX_NAMELEN];
39
size_t
size;
40
void
*value;
41
ofw_tree_property_t
42
44
typedef
struct
ofw_tree_node
45
struct
ofw_tree_node
*parent;
46
struct
ofw_tree_node
*peer;
47
struct
ofw_tree_node
*child;
48
49
uint32_t
node_handle
50
51
char
da_name
52
53
unsigned
int
properties
54
ofw_tree_property_t
*property;
55
56
void
device
57
} ofw_tree_node_t;
58
59
extern
ofw_tree_node_t *ofw_tree_build(
void
60
61
#endif
ofw_tree_node
Definition
ofw_tree.h:44
ofw_tree_node::node_handle
uint32_t node_handle
Definition
ofw_tree.h:49
ofw_tree_node::da_name
char * da_name
Definition
ofw_tree.h:51
ofw_tree_node::properties
unsigned int properties
Definition
ofw_tree.h:53
ofw_tree_node::device
void * device
Definition
ofw_tree.h:56
ofw_tree_property_t
Definition
ofw_tree.h:37
