RTEMS 6.3
tm27.h
1
6
7/*
8 * tm27.h
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef _RTEMS_TMTEST27
16#error "This is an RTEMS internal file you must not include directly."
17#endif
18
19#ifndef __tm27_h
20#define __tm27_h
21
28
29/*
30 * Define the interrupt mechanism for Time Test 27
31 */
32
33#define MUST_WAIT_FOR_INTERRUPT 0
34
35#define TM27_USE_VECTOR_HANDLER
36
37#define Install_tm27_vector(handler) \
38{ \
39 set_vector( handler, 0x06, 1 ); \
40}
41
42#define Cause_tm27_intr() __asm__ volatile("raise 0x06;" : :);
43
44#define Clear_tm27_intr() /* empty */
45
46#define Lower_tm27_intr() /* empty */
47
49
50#endif
