RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
gen5200
include
bsp
bestcomm
bestcomm_glue.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* RTEMS generic MPC5200 BSP
5
6
* This file declares glue functions to the Freescale BestComm API.
7
8
9
10
* Copyright (C) 2004, 2005 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef _BESTCOMM_GLUE_H
35
#define _BESTCOMM_GLUE_H
36
37
rtems/irq-extension.h
38
39
#ifdef __cplusplus
40
extern
"C"
41
#endif
/* __cplusplus */
42
43
44
| Function: |
45
46
void
bestcomm_glue_irq_enable
47
48
49
| Purpose: |
50
| enable interrupt for given task number |
51
52
| Input Parameters: |
53
54
int
bestcomm_taskno
/* task number to enable */
55
56
57
| Return Value: |
58
| none |
59
60
61
62
| Function: |
63
64
void
bestcomm_glue_irq_disable
65
66
67
| Purpose: |
68
| disable interrupt for given task number |
69
70
| Input Parameters: |
71
72
int
bestcomm_taskno
/* task number to disable */
73
74
75
| Return Value: |
76
| none |
77
78
79
80
| Function: |
81
82
void
bestcomm_glue_irq_install
83
84
85
| Purpose: |
86
| install given function as bestcomm interrupt handler |
87
88
| Input Parameters: |
89
90
int
bestcomm_taskno,
/* task number for handler */
91
rtems_interrupt_handler
handler,
/* function to call */
92
void
*arg
93
94
95
| Return Value: |
96
| none |
97
98
99
100
| Function: |
101
102
void
bestcomm_glue_init
103
104
105
| Purpose: |
106
| initialize the bestcomm module (if not yet done): |
107
| - load code |
108
| - initialize registers |
109
| - initialize bus arbiter |
110
| - initialize interrupt control |
111
112
| Input Parameters: |
113
114
void
/* none */
115
116
117
| Return Value: |
118
| none |
119
120
121
void
*bestcomm_malloc(
size_t
size);
122
123
void
bestcomm_free(
void
*ptr);
124
125
#ifdef __cplusplus
126
127
#endif
/* __cplusplus */
128
129
#endif
/* _BESTCOMM_GLUE_H */
void(*) rtems_interrupt_handler(void *)
Interrupt handler routines shall have this type.
Definition
intr.h:1030
irq-extension.h
This header file is provided for backward compatiblility.
