RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
beatnik
include
bsp
VMEConfig.h
1
#ifndef RTEMS_BSP_VME_CONFIG_H
2
#define RTEMS_BSP_VME_CONFIG_H
3
4
/* BSP specific address space configuration parameters */
5
6
7
* Authorship
8
9
* This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
10
* created by Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
11
* Stanford Linear Accelerator Center, Stanford University.
12
13
* Acknowledgement of sponsorship
14
15
* The 'beatnik' BSP was produced by
16
* the Stanford Linear Accelerator Center, Stanford University,
17
* under Contract DE-AC03-76SFO0515 with the Department of Energy.
18
19
* Government disclaimer of liability
20
21
* Neither the United States nor the United States Department of Energy,
22
* nor any of their employees, makes any warranty, express or implied, or
23
* assumes any legal liability or responsibility for the accuracy,
24
* completeness, or usefulness of any data, apparatus, product, or process
25
* disclosed, or represents that its use would not infringe privately owned
26
* rights.
27
28
* Stanford disclaimer of liability
29
30
* Stanford University makes no representations or warranties, express or
31
* implied, nor assumes any liability for the use of this software.
32
33
* Stanford disclaimer of copyright
34
35
* Stanford University, owner of the copyright, hereby disclaims its
36
* copyright and all other rights in this software. Hence, anyone may
37
* freely use it for any purpose without restriction.
38
39
* Maintenance of notices
40
41
* In the interest of clarity regarding the origin and status of this
42
* SLAC software, this and all the preceding Stanford University notices
43
* are to remain affixed to any copy or derivative of this software made
44
* or distributed by the recipient and are to be affixed to any copy of
45
* software made or distributed by the recipient that contains a copy or
46
* derivative of this software.
47
48
* ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
49
50
51
#define _VME_DRIVER_TSI148
52
#define _VME_DRIVER_UNIVERSE
53
54
55
* NOTE: the BSP (startup/bspstart.c) uses
56
* hardcoded window lengths that match this
57
* layout when setting BATs:
58
59
#define _VME_A32_WIN0_ON_PCI 0x90000000
60
/* If _VME_CSR_ON_PCI is defined then the A32 window is reduced to accommodate
61
* CSR for space.
62
63
#define _VME_CSR_ON_PCI 0x9e000000
64
#define _VME_A24_ON_PCI 0x9f000000
65
#define _VME_A16_ON_PCI 0x9fff0000
66
67
/* start of the A32 window on the VME bus
68
* TODO: this should perhaps be a configuration option
69
70
#define _VME_A32_WIN0_ON_VME 0x20000000
71
72
/* if _VME_DRAM_OFFSET is defined, the BSP
73
* will map our RAM onto the VME bus, starting
74
* at _VME_DRAM_OFFSET
75
76
#define _VME_DRAM_OFFSET 0x90000000
77
78
extern
int
BSP_VMEInit(
void
79
extern
int
BSP_VMEIrqMgrInstall(
void
80
81
#define BSP_VME_INSTALL_IRQ_MGR(err) \
82
do { \
83
err = -1; \
84
switch (BSP_getBoardType()) { \
85
case MVME6100: \
86
err = theOps->install_irq_mgr( \
87
VMETSI148_IRQ_MGR_FLAG_SHARED, \
88
0, BSP_IRQ_GPP_0 + 20, \
89
1, BSP_IRQ_GPP_0 + 21, \
90
2, BSP_IRQ_GPP_0 + 22, \
91
3, BSP_IRQ_GPP_0 + 23, \
92
-1); \
93
break; \
94
95
case MVME5500: \
96
97
VMEUNIVERSE_IRQ_MGR_FLAG_SHARED | \
98
VMEUNIVERSE_IRQ_MGR_FLAG_PW_WORKAROUND, \
99
0, BSP_IRQ_GPP_0 + 12, \
100
1, BSP_IRQ_GPP_0 + 13, \
101
2, BSP_IRQ_GPP_0 + 14, \
102
3, BSP_IRQ_GPP_0 + 15, \
103
-1); \
104
break; \
105
106
default: \
107
printk("WARNING: unknown board; "); \
108
break; \
109
110
if ( err ) \
111
printk("VME interrupt manager NOT INSTALLED (error: %i)\n", err); \
112
} while (0)
113
114
#endif
