RTEMS 6.3
bbb-pwm.h File Reference
BeagleBone Black PWM support definitions. More...
#define BBB_CONTROL_CONF_GPMC_AD(n)
 BeagleBone Black PWM Macros.
#define BBB_CONTROL_CONF_LCD_DATA(n)
#define BBB_P8_13_MUX_PWM   4
#define BBB_P8_19_MUX_PWM   4
#define BBB_P8_45_MUX_PWM   3
#define BBB_P8_46_MUX_PWM   3
#define BBB_P8_34_MUX_PWM   2
#define BBB_P8_36_MUX_PWM   2
#define BBB_P9_14_MUX_PWM   6
#define BBB_P9_16_MUX_PWM   6
#define BBB_P9_21_MUX_PWM   3
#define BBB_P9_22_MUX_PWM   3
#define BBB_P9_29_MUX_PWM   1
#define BBB_P9_31_MUX_PWM   1
#define BBB_PWM_FREQ_THRESHOLD   0.5f
enum  bbb_pwm_pin_t {
  BBB_P8_13_2B = 3 , BBB_P8_19_2A , BBB_P8_45_2A , BBB_P8_46_2B ,
  BBB_P8_34_1B , BBB_P8_36_1A , BBB_P9_14_1A , BBB_P9_16_1B ,
  BBB_P9_21_0B , BBB_P9_22_0A , BBB_P9_29_0B , BBB_P9_31_0A
bool beagle_pwm_init (BBB_PWMSS pwmss_id)
 BeagleBone Black PWM API.
int beagle_pwm_configure (BBB_PWMSS pwm_id, float pwm_freq, float duty_a, float duty_b)
bool beagle_pwm_enable (BBB_PWMSS pwmid)
 This API enables the particular PWM module.
bool beagle_pwm_disable (BBB_PWMSS pwmid)
 This API disables the particular PWM module.
bool beagle_pwm_pinmux_setup (bbb_pwm_pin_t pin_no, BBB_PWMSS pwm_id)
 This function enables pinmuxing for PWM module.
bool beagle_pwmss_is_running (unsigned int pwmss_id)
 This function determines whether PWMSS-wide clocks enabled or not.
◆ BBB_CONTROL_CONF_GPMC_AD
#define BBB_CONTROL_CONF_GPMC_AD ( n)
Value:
(0x800 + (n * 4))
Some constants are taken from https://github.com/VegetableAvenger/BBBIOlib/blob/master/BBBio_lib/BBBiolib_PWMSS.h
◆ BBB_CONTROL_CONF_LCD_DATA
#define BBB_CONTROL_CONF_LCD_DATA ( n)
Value:
(0x8a0 + (n * 4))
◆ beagle_pwm_disable()
bool beagle_pwm_disable ( BBB_PWMSS pwmid)
Parameters
pwmidIt is the instance number of EPWM of pwm sub system.
Returns
true if successful
false if fail
◆ beagle_pwm_enable()
bool beagle_pwm_enable ( BBB_PWMSS pwmid)
Parameters
Returns
true if successful
false if fail
◆ beagle_pwm_init()
bool beagle_pwm_init ( BBB_PWMSS pwmss_id)
This function intilizes clock for pwm sub system.
Parameters
PWMSS_IDIt is the instance number of EPWM of pwm sub system.
Returns
true if successful
false if not successful
◆ beagle_pwm_pinmux_setup()
bool beagle_pwm_pinmux_setup ( bbb_pwm_pin_t pin_no,
BBB_PWMSS pwm_id )
Parameters
pin_noIt is individual pin at which freuqency need to be generated. It should be according to pwm sub system.
pwm_idIt is the instance number of EPWM of pwmsubsystem.
Returns
true if successful
false if fail
◆ beagle_pwmss_is_running()
bool beagle_pwmss_is_running ( unsigned int pwmss_id)
Parameters
pwmss_idIt is the instance number of PWMSS which clocks need to be checked.
Returns
true if successful
false if fail
