RTEMS 6.3
armv7-pmsa.h File Reference
This header file provides the API to manage an Arm PMSAv7 based Memory Protection Unit (MPU). More...
#include <rtems/score/aarch32-system-registers.h>
#include <rtems/score/cpu.h>
struct  ARMV7_PMSA_Region
 The region definition is used to initialize the Memory Protection Unit (MPU). More...
#define ARMV7_PMSA_TEXT_SECTION
#define ARMV7_RGNR_REGION_SHIFT   0
#define ARMV7_RGNR_REGION_MASK   0xffU
#define ARMV7_RGNR_REGION_GET(_reg)
#define ARMV7_RGNR_REGION_SET(_reg, _val)
#define ARMV7_RGNR_REGION(_val)
#define ARMV7_RSR_EN   0x1U
#define ARMV7_RSR_RSIZE_SHIFT   1
#define ARMV7_RSR_RSIZE_MASK   0x3eU
#define ARMV7_RSR_RSIZE_GET(_reg)
#define ARMV7_RSR_RSIZE_SET(_reg, _val)
#define ARMV7_RSR_RSIZE(_val)
#define ARMV7_RSR_SD_SHIFT   8
#define ARMV7_RSR_SD_MASK   0xff00U
#define ARMV7_RSR_SD_GET(_reg)
#define ARMV7_RSR_SD_SET(_reg, _val)
#define ARMV7_RSR_SD(_val)
#define ARMV7_RACR_B   0x1U
#define ARMV7_RACR_C   0x2U
#define ARMV7_RACR_S   0x4U
#define ARMV7_RACR_TEX_0   0x8U
#define ARMV7_RACR_TEX_1   0x10U
#define ARMV7_RACR_TEX_2   0x20U
#define ARMV7_RACR_AP_0   0x100U
#define ARMV7_RACR_AP_1   0x200U
#define ARMV7_RACR_AP_2   0x400U
#define ARMV7_RACR_XN   0x1000U
#define ARMV7_PMSA_READ_ONLY_CACHED
#define ARMV7_PMSA_READ_ONLY_UNCACHED   (ARMV7_RACR_TEX_0 | ARMV7_RACR_AP_0 | ARMV7_RACR_AP_2)
#define ARMV7_PMSA_READ_WRITE_CACHED   (ARMV7_RACR_TEX_0 | ARMV7_RACR_C | ARMV7_RACR_B | ARMV7_RACR_AP_0)
#define ARMV7_PMSA_READ_WRITE_UNCACHED   (ARMV7_RACR_TEX_0 | ARMV7_RACR_AP_0)
#define ARMV7_PMSA_READ_WRITE_SHARED   (ARMV7_RACR_TEX_0 | ARMV7_RACR_S | ARMV7_RACR_AP_0)
#define ARMV7_PMSA_SHAREABLE_DEVICE   (ARMV7_RACR_B | ARMV7_RACR_AP_0)
#define ARMV7_PMSA_NON_SHAREABLE_DEVICE   (ARMV7_RACR_TEX_1 | ARMV7_RACR_AP_0)
typedef struct ARMV7_PMSA_Region ARMV7_PMSA_Region
