RTEMS 6.3
linker-symbols-arch.h
2
11
12/*
13 * Copyright (C) 2008, 2016 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef LIBBSP_ARM_SHARED_LINKER_SYMBOLS_H
38#define LIBBSP_ARM_SHARED_LINKER_SYMBOLS_H
39
40#ifdef __cplusplus
41extern "C" {
42#endif /* __cplusplus */
43
54
55#ifndef ASM
56 #define LINKER_SYMBOL(sym) extern char sym [];
57#else
58 #define LINKER_SYMBOL(sym) .extern sym
59#endif
60
61LINKER_SYMBOL(bsp_stack_fiq_size)
62LINKER_SYMBOL(bsp_stack_abt_size)
63LINKER_SYMBOL(bsp_stack_und_size)
64LINKER_SYMBOL(bsp_stack_hyp_size)
65
66LINKER_SYMBOL(bsp_section_vector_begin)
67LINKER_SYMBOL(bsp_section_vector_end)
68LINKER_SYMBOL(bsp_section_vector_size)
69
70LINKER_SYMBOL(bsp_vector_table_begin)
71LINKER_SYMBOL(bsp_vector_table_end)
72LINKER_SYMBOL(bsp_vector_table_size)
73
74LINKER_SYMBOL(bsp_start_vector_table_begin)
75LINKER_SYMBOL(bsp_start_vector_table_end)
76LINKER_SYMBOL(bsp_start_vector_table_size)
77
78LINKER_SYMBOL(bsp_translation_table_base)
79LINKER_SYMBOL(bsp_translation_table_end)
80
81
82
83#ifdef __cplusplus
84}
85#endif /* __cplusplus */
86
87#endif /* LIBBSP_ARM_SHARED_LINKER_SYMBOLS_H */
