RTEMS
6.3
Toggle main menu visibility
bsps
arm
edb7312
include
uart.h
1
8
9
10
* This software is Copyright (C) 1998 by T.sqware - all rights limited
11
* It is provided in to the public domain "as is", can be freely modified
12
* as far as this copyight notice is kept unchanged, but does not imply
13
* an endorsement by T.sqware of the product in which it is included.
14
15
* Copyright (c) Canon Research France SA.]
16
* Emmanuel Raguet, mailto:raguet@crf.canon.fr
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef _BSPUART_H
24
#define _BSPUART_H
25
26
rtems/bspIo.h
27
28
void
BSP_uart_init(
int
uart,
int
baud,
int
hwFlow);
29
void
BSP_uart_set_baud(
int
aurt,
int
baud);
30
void
BSP_uart_intr_ctrl(
int
uart,
int
cmd);
31
void
BSP_uart_throttle(
int
uart);
32
void
BSP_uart_unthrottle(
int
uart);
33
int
BSP_uart_polled_status(
int
uart);
34
void
BSP_uart_polled_write(
int
uart,
int
val);
35
int
BSP_uart_polled_read(
int
uart);
36
void
BSP_uart_termios_set(
int
uart,
void
*ttyp);
37
int
BSP_uart_termios_write_com1(
int
minor,
const
char
*buf,
int
len);
38
int
BSP_uart_termios_write_com2(
int
minor,
const
char
*buf,
int
len);
39
void
BSP_uart_termios_isr_com1(
void
40
void
BSP_uart_termios_isr_com2(
void
41
void
BSP_uart_dbgisr_com1(
void
42
void
BSP_uart_dbgisr_com2(
void
43
extern
unsigned
BSP_poll_char_via_serial(
void
44
extern
void
BSP_output_char_via_serial(
int
val);
45
extern
int
BSPConsolePort;
46
extern
int
BSPBaseBaud;
47
48
* Command values for BSP_uart_intr_ctrl(),
49
* values are strange in order to catch errors
50
* with assert
51
52
#define BSP_UART_INTR_CTRL_DISABLE (0)
53
#define BSP_UART_INTR_CTRL_GDB (0xaa)
/* RX only */
54
#define BSP_UART_INTR_CTRL_ENABLE (0xbb)
/* Normal operations */
55
#define BSP_UART_INTR_CTRL_TERMIOS (0xcc)
/* RX & line status */
56
57
/* Return values for uart_polled_status() */
58
#define BSP_UART_STATUS_ERROR (-1)
/* No character */
59
#define BSP_UART_STATUS_NOCHAR (0)
/* No character */
60
#define BSP_UART_STATUS_CHAR (1)
/* Character present */
61
#define BSP_UART_STATUS_BREAK (2)
/* Break point is detected */
62
63
/* PC UART definitions */
64
#define BSP_UART_COM1 (0)
65
#define BSP_UART_COM2 (1)
66
67
68
* Base IO for UART
69
70
71
#define COM1_BASE_IO 0x3F8
72
#define COM2_BASE_IO 0x2F8
73
74
75
* Offsets from base
76
77
78
/* DLAB 0 */
79
#define RBR RSRBR
/* Rx Buffer Register (read) */
80
#define THR RSTHR
/* Tx Buffer Register (write) */
81
#define IER RSIER
/* Interrupt Enable Register */
82
83
/* DLAB X */
84
#define IIR RSIIR
/* Interrupt Ident Register (read) */
85
#define FCR RSFCR
/* FIFO Control Register (write) */
86
#define LCR RSLCR
/* Line Control Register */
87
#define LSR RSLSR
/* Line Status Register */
88
89
/* DLAB 1 */
90
#define DLL RSDLL
/* Divisor Latch, LSB */
91
#define DLM RSDLH
/* Divisor Latch, MSB */
92
93
/* Uart control */
94
#define CNT RSCNT
/* General Control register */
95
96
97
* define bit for CNT
98
99
#define UART_ENABLE 1
100
#define PAD_ENABLE 2
101
102
103
* Interrupt source definition via IIR
104
105
#define NO_MORE_INTR 1
106
#define TRANSMITTER_HODING_REGISTER_EMPTY 2
107
#define RECEIVER_DATA_AVAIL 4
108
#define RECEIVER_ERROR 6
109
#define CHARACTER_TIMEOUT_INDICATION 12
110
111
112
* Bits definition of IER
113
114
#define RECEIVE_ENABLE 0x1
115
#define TRANSMIT_ENABLE 0x2
116
#define RECEIVER_LINE_ST_ENABLE 0x4
117
#define INTERRUPT_DISABLE 0x0
118
119
120
* Bits definition of the Line Status Register (LSR)
121
122
#define DR 0x01
/* Data Ready */
123
#define OE 0x02
/* Overrun Error */
124
#define PE 0x04
/* Parity Error */
125
#define FE 0x08
/* Framing Error */
126
#define BI 0x10
/* Break Interrupt */
127
#define THRE 0x20
/* Transmitter Holding Register Empty */
128
#define TEMT 0x40
/* Transmitter Empty */
129
#define ERFIFO 0x80
/* Error receive Fifo */
130
131
132
* Bits definition of the Line Control Register (LCR)
133
134
#define CHR_5_BITS 0
135
#define CHR_6_BITS 1
136
#define CHR_7_BITS 2
137
#define CHR_8_BITS 3
138
139
#define WL 0x03
/* Word length mask */
140
#define STB 0x04
/* 1 Stop Bit, otherwise 2 Stop Bits */
141
#define PEN 0x08
/* Parity Enabled */
142
#define EPS 0x10
/* Even Parity Select, otherwise Odd */
143
#define SP 0x20
/* Stick Parity */
144
#define BCB 0x40
/* Break Control Bit */
145
#define DLAB 0x80
/* Enable Divisor Latch Access */
146
147
148
* Bits definition of the FIFO Control Register : WD16C552 or NS16550
149
150
151
#define FIFO_CTRL 0x01
/* Set to 1 permit access to other bits */
152
#define FIFO_EN 0x01
/* Enable the FIFO */
153
#define XMIT_RESET 0x04
/* Transmit FIFO Reset */
154
#define RCV_RESET 0x02
/* Receive FIFO Reset */
155
#define FCR3 0x08
/* do not understand manual! */
156
157
#define RECEIVE_FIFO_TRIGGER1 0x0
/* trigger recieve interrupt after 1 byte */
158
#define RECEIVE_FIFO_TRIGGER4 0x40
/* trigger recieve interrupt after 4 byte */
159
#define RECEIVE_FIFO_TRIGGER8 0x80
/* trigger recieve interrupt after 8 byte */
160
#define RECEIVE_FIFO_TRIGGER12 0xc0
/* trigger recieve interrupt after 14 byte */
161
#define TRIG_LEVEL 0xc0
/* Mask for the trigger level */
162
163
#endif
/* _BSPUART_H */
bspIo.h
This header file provides the kernel character input/output support API.
