#define | PL011_UARTDR_OE BSP_BIT32(11) |
#define | PL011_UARTDR_BE BSP_BIT32(10) |
#define | PL011_UARTDR_PE BSP_BIT32(9) |
#define | PL011_UARTDR_FE BSP_BIT32(8) |
| #define | PL011_UARTDR_DATA(val) |
| #define | PL011_UARTDR_DATA_GET(reg) |
| #define | PL011_UARTDR_DATA_SET(reg, val) |
#define | PL011_UARTRSR_UARTECR_OE BSP_BIT32(3) |
#define | PL011_UARTRSR_UARTECR_BE BSP_BIT32(2) |
#define | PL011_UARTRSR_UARTECR_PE BSP_BIT32(1) |
#define | PL011_UARTRSR_UARTECR_FE BSP_BIT32(0) |
#define | PL011_UARTFR_RI BSP_BIT32(8) |
#define | PL011_UARTFR_TXFE BSP_BIT32(7) |
#define | PL011_UARTFR_RXFF BSP_BIT32(6) |
#define | PL011_UARTFR_TXFF BSP_BIT32(5) |
#define | PL011_UARTFR_RXFE BSP_BIT32(4) |
#define | PL011_UARTFR_BUSY BSP_BIT32(3) |
#define | PL011_UARTFR_DCD BSP_BIT32(2) |
#define | PL011_UARTFR_DSR BSP_BIT32(1) |
#define | PL011_UARTFR_CTS BSP_BIT32(0) |
| #define | PL011_UARTILPR_ILPDVSR(val) |
| #define | PL011_UARTILPR_ILPDVSR_GET(reg) |
| #define | PL011_UARTILPR_ILPDVSR_SET(reg, val) |
#define | PL011_UARTIBRD_BAUD_DIVINT_WIDTH 16 |
#define | PL011_UARTIBRD_BAUD_DIVINT_MASK BSP_MSK32(0, PL011_UARTIBRD_BAUD_DIVINT_WIDTH - 1) |
| #define | PL011_UARTIBRD_BAUD_DIVINT(val) |
| #define | PL011_UARTIBRD_BAUD_DIVINT_GET(reg) |
| #define | PL011_UARTIBRD_BAUD_DIVINT_SET(reg, val) |
#define | PL011_UARTFBRD_BAUD_DIVFRAC_WIDTH 6 |
#define | PL011_UARTFBRD_BAUD_DIVFRAC_MASK BSP_MSK32(0, PL011_UARTFBRD_BAUD_DIVFRAC_WIDTH - 1) |
| #define | PL011_UARTFBRD_BAUD_DIVFRAC(val) |
| #define | PL011_UARTFBRD_BAUD_DIVFRAC_GET(reg) |
| #define | PL011_UARTFBRD_BAUD_DIVFRAC_SET(reg, val) |
#define | PL011_UARTLCR_H_SPS BSP_BIT32(7) |
| #define | PL011_UARTLCR_H_WLEN(val) |
| #define | PL011_UARTLCR_H_WLEN_GET(reg) |
| #define | PL011_UARTLCR_H_WLEN_SET(reg, val) |
#define | PL011_UARTLCR_H_WLEN_5 0x00U |
#define | PL011_UARTLCR_H_WLEN_6 0x01U |
#define | PL011_UARTLCR_H_WLEN_7 0x02U |
#define | PL011_UARTLCR_H_WLEN_8 0x03U |
#define | PL011_UARTLCR_H_FEN BSP_BIT32(4) |
#define | PL011_UARTLCR_H_STP2 BSP_BIT32(3) |
#define | PL011_UARTLCR_H_EPS BSP_BIT32(2) |
#define | PL011_UARTLCR_H_PEN BSP_BIT32(1) |
#define | PL011_UARTLCR_H_BRK BSP_BIT32(0) |
#define | PL011_UARTCR_CTSEN BSP_BIT32(15) |
#define | PL011_UARTCR_RTSEN BSP_BIT32(14) |
#define | PL011_UARTCR_OUT2 BSP_BIT32(13) |
#define | PL011_UARTCR_OUT1 BSP_BIT32(12) |
#define | PL011_UARTCR_RTS BSP_BIT32(11) |
#define | PL011_UARTCR_DTR BSP_BIT32(10) |
#define | PL011_UARTCR_RXE BSP_BIT32(9) |
#define | PL011_UARTCR_TXE BSP_BIT32(8) |
#define | PL011_UARTCR_LBE BSP_BIT32(7) |
#define | PL011_UARTCR_SIRLP BSP_BIT32(2) |
#define | PL011_UARTCR_SIREN BSP_BIT32(1) |
#define | PL011_UARTCR_UARTEN BSP_BIT32(0) |
| #define | PL011_UARTIFLS_RXIFLSEL(val) |
| #define | PL011_UARTIFLS_RXIFLSEL_GET(reg) |
| #define | PL011_UARTIFLS_RXIFLSEL_SET(reg, val) |
| #define | PL011_UARTIFLS_TXIFLSEL(val) |
| #define | PL011_UARTIFLS_TXIFLSEL_GET(reg) |
| #define | PL011_UARTIFLS_TXIFLSEL_SET(reg, val) |
#define | PL011_UARTI_OEI BSP_BIT32(10) |
#define | PL011_UARTI_BEI BSP_BIT32(9) |
#define | PL011_UARTI_PEI BSP_BIT32(8) |
#define | PL011_UARTI_FEI BSP_BIT32(7) |
#define | PL011_UARTI_RTI BSP_BIT32(6) |
#define | PL011_UARTI_TXI BSP_BIT32(5) |
#define | PL011_UARTI_RXI BSP_BIT32(4) |
#define | PL011_UARTI_DSRMI BSP_BIT32(3) |
#define | PL011_UARTI_DCDMI BSP_BIT32(2) |
#define | PL011_UARTI_CTSMI BSP_BIT32(1) |
#define | PL011_UARTI_RIMI BSP_BIT32(0) |
#define | PL011_UARTI_MASK BSP_MSK32(0, 10) |
#define | PL011_UARTDMACR_DMAONERR BSP_BIT32(2) |
#define | PL011_UARTDMACR_TXDMAE BSP_BIT32(1) |
#define | PL011_UARTDMACR_RXDMAE BSP_BIT32(0) |
ARM PL011 Register definitions.
