RTEMS
6.3
Toggle main menu visibility
bsps
arm
include
bsp
arm-errata.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (c) 2014 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef ARM_ERRATA_H_
37
#define ARM_ERRATA_H_
38
39
bsp/arm-release-id.h
40
libcpu/arm-cp15.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
/* __cplusplus */
45
46
static
inline
arm_release_id arm_errata_get_processor_release(
void
47
48
const
uint32_t MIDR = arm_cp15_get_id_code();
49
const
uint8_t REVISION = (MIDR & 0xF00000U) >> 20;
50
const
uint8_t PATCH_LEVEL = (MIDR & 0xFU);
51
52
return
ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL(
53
REVISION,
54
PATCH_LEVEL
55
56
57
58
static
inline
bool
arm_errata_is_applicable_processor_errata_764369(
void
59
60
#if defined(RTEMS_SMP)
61
const
arm_release_id RELEASE = arm_errata_get_processor_release();
62
bool
is_applicable =
false
63
64
/* Errata information for Cortex-A9 processors.
65
* Information taken from ARMs
66
* "Cortex-A series processors
67
* - Cortex-A9
68
* - Software Developers Errata Notice
69
* - Revision r4 revisions
70
* - ARM Cortex-A9 processors r4 release Software Developers Errata Notice"
71
* The corresponding link is: http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0360f/BABJFIBA.html
72
* Please see this document for more information on these erratas */
73
74
switch
( RELEASE ) {
75
case
ARM_RELEASE_ID_R4_P1:
76
case
ARM_RELEASE_ID_R4_P4:
77
case
ARM_RELEASE_ID_R3_P0:
78
case
ARM_RELEASE_ID_R2_P10:
79
case
ARM_RELEASE_ID_R2_P8:
80
case
ARM_RELEASE_ID_R2_P6:
81
case
ARM_RELEASE_ID_R2_P4:
82
case
ARM_RELEASE_ID_R2_P3:
83
case
ARM_RELEASE_ID_R2_P2:
84
case
ARM_RELEASE_ID_R2_P0:
85
is_applicable =
true
86
break
87
default
88
is_applicable =
false
89
break
90
91
92
return
is_applicable;
93
#else
94
return
false
95
#endif
96
97
98
static
inline
bool
arm_errata_is_applicable_processor_errata_775420(
void
99
100
const
101
bool
is_applicable =
false
102
103
104
105
106
* - Cortex-A9
107
108
109
110
111
112
113
switch
( RELEASE ) {
114
case
115
case
116
case
117
case
118
case
119
case
120
is_applicable =
true
121
break
122
default
123
is_applicable =
false
124
break
125
126
127
return
is_applicable;
128
129
130
#ifdef __cplusplus
131
132
#endif
/* __cplusplus */
133
134
#endif
/* ARM_ERRATA_H_ */
arm-cp15.h
ARM co-processor 15 (CP15) API.
arm-release-id.h
Create defines for release IDs.
