RTEMS 6.3
APIC implementation. More...
#include <acpi/acpi.h>#include <apic.h>#include <assert.h>#include <bsp.h>#include <pic.h>#include <rtems/score/idt.h>Functions | |
| void | apic_spurious_handler (void) |
| bool | lapic_initialize (void) |
| Initializes the Local APIC by hardware and software enabling it. | |
| uint32_t | lapic_timer_calc_ticks (uint64_t desired_freq_hz) |
| Calculates the number of Local APIC timer ticks which can be used with lapic_timer_enable to set up a timer of given frequency. | |
| void | lapic_timer_enable (uint32_t reload_value) |
| Enables the Local APIC timer. | |
| volatile uint32_t * | amd64_lapic_base |
| bool lapic_initialize | ( | void | ) |
Initializes the Local APIC by hardware and software enabling it, and sets up the amd64_lapic_base pointer that can be used as a 32-bit addressable array to access Local APIC registers.
| uint32_t lapic_timer_calc_ticks | ( | uint64_t | desired_freq_hz | ) |
| desired_freq_hz | The frequency in Hz. |
| void lapic_timer_enable | ( | uint32_t | reload_value | ) |
| reload_value | Number of ticks per interrupt. |
