RTEMS
6.3
Toggle main menu visibility
bsps
arm
altera-cyclone-v
include
bsp
alt_qspi_private.h
1
6
7
8
9
* Copyright 2013 Altera Corporation. All Rights Reserved.
10
11
12
* modification, are permitted provided that the following conditions are met:
13
14
* 1. Redistributions of source code must retain the above copyright notice,
15
* this list of conditions and the following disclaimer.
16
17
* 2. Redistributions in binary form must reproduce the above copyright notice,
18
* this list of conditions and the following disclaimer in the documentation
19
* and/or other materials provided with the distribution.
20
21
* 3. The name of the author may not be used to endorse or promote products
22
* derived from this software without specific prior written permission.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR
25
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
26
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO
27
* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
28
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
29
* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
32
* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
33
* OF SUCH DAMAGE.
34
35
36
40
41
#ifndef __ALT_QSPI_PRIVATE_H__
42
#define __ALT_QSPI_PRIVATE_H__
43
44
#include "
socal/socal.h
45
46
47
// This section provisions support for various flash devices.
48
49
50
#define ALT_QSPI_PROVISION_MICRON_N25Q_SUPPORT 1
51
53
54
#define ALT_QSPI_PAGE_ADDR_MSK 0xFFFFFF00
55
#define ALT_QSPI_PAGE_SIZE 0x00000100
// 256 B
56
#define ALT_QSPI_SUBSECTOR_ADDR_MSK 0xFFFFF000
57
#define ALT_QSPI_SUBSECTOR_SIZE 0x00001000
// 4096 B
58
#define ALT_QSPI_SECTOR_ADDR_MSK 0xFFFF0000
59
#define ALT_QSPI_SECTOR_SIZE 0x00010000
// 64 KiB
60
#define ALT_QSPI_BANK_ADDR_MSK 0xFF000000
61
#define ALT_QSPI_BANK_SIZE 0x01000000
// 16 MiB
62
63
#if ALT_QSPI_PROVISION_MICRON_N25Q_SUPPORT
64
#define ALT_QSPI_N25Q_DIE_ADDR_MSK 0xFE000000
65
#define ALT_QSPI_N25Q_DIE_SIZE 0x02000000
// 32 MiB
66
#endif
67
69
70
// Default delay timing (in ns) for N25Q.
71
// These values are from the N25Q handbook. The timing correctness is difficult
72
// to test because the test setup does not feature mutliple chips.
73
#define ALT_QSPI_TSHSL_NS_DEF (50)
74
#define ALT_QSPI_TSD2D_NS_DEF (0)
75
#define ALT_QSPI_TCHSH_NS_DEF (4)
76
#define ALT_QSPI_TSLCH_NS_DEF (4)
77
78
79
80
#define ALT_QSPI_TSHSL_NS_DEF (200)
81
#define ALT_QSPI_TSD2D_NS_DEF (255)
82
#define ALT_QSPI_TCHSH_NS_DEF (20)
83
#define ALT_QSPI_TSLCH_NS_DEF (20)
84
85
86
// Flash commands
87
#define ALT_QSPI_STIG_OPCODE_READ (0x03)
88
#define ALT_QSPI_STIG_OPCODE_4BYTE_READ (0x13)
89
#define ALT_QSPI_STIG_OPCODE_FASTREAD (0x0B)
90
#define ALT_QSPI_STIG_OPCODE_FASTREAD_DUAL_OUTPUT (0x3B)
91
#define ALT_QSPI_STIG_OPCODE_FASTREAD_QUAD_OUTPUT (0x6B)
92
#define ALT_QSPI_STIG_OPCODE_FASTREAD_DUAL_IO (0xBB)
93
#define ALT_QSPI_STIG_OPCODE_FASTREAD_QUAD_IO (0xEB)
94
#define ALT_QSPI_STIG_OPCODE_PP (0x02)
95
#define ALT_QSPI_STIG_OPCODE_DUAL_PP (0xA2)
96
#define ALT_QSPI_STIG_OPCODE_QUAD_PP (0x32)
97
#define ALT_QSPI_STIG_OPCODE_RDID (0x9F)
98
#define ALT_QSPI_STIG_OPCODE_WREN (0x06)
99
#define ALT_QSPI_STIG_OPCODE_WRDIS (0x04)
100
#define ALT_QSPI_STIG_OPCODE_RDSR (0x05)
101
#define ALT_QSPI_STIG_OPCODE_WRSR (0x01)
102
#define ALT_QSPI_STIG_OPCODE_SUBSEC_ERASE (0x20)
103
#define ALT_QSPI_STIG_OPCODE_SEC_ERASE (0xD8)
104
#define ALT_QSPI_STIG_OPCODE_BULK_ERASE (0xC7)
105
#define ALT_QSPI_STIG_OPCODE_DIE_ERASE (0xC4)
106
#define ALT_QSPI_STIG_OPCODE_CHIP_ERASE (0x60)
107
#define ALT_QSPI_STIG_OPCODE_RD_EXT_REG (0xC8)
108
#define ALT_QSPI_STIG_OPCODE_WR_EXT_REG (0xC5)
109
#define ALT_QSPI_STIG_OPCODE_RD_STAT_REG (0x05)
110
#define ALT_QSPI_STIG_OPCODE_WR_STAT_REG (0x01)
111
#define ALT_QSPI_STIG_OPCODE_ENTER_4BYTE_MODE (0xB7)
112
#define ALT_QSPI_STIG_OPCODE_EXIT_4BYTE_MODE (0xE9)
113
114
// Micron commands, for 512 Mib, 1 Gib (64 MiB, 128 MiB) parts.
115
116
#define ALT_QSPI_STIG_OPCODE_RESET_EN (0x66)
117
#define ALT_QSPI_STIG_OPCODE_RESET_MEM (0x99)
118
#define ALT_QSPI_STIG_OPCODE_RDFLGSR (0x70)
119
#define ALT_QSPI_STIG_OPCODE_CLRFLGSR (0x50)
120
#define ALT_QSPI_STIG_OPCODE_DISCVR_PARAM (0x5A)
121
#endif
122
123
// Spansion commands
124
// #define OPCODE_ECRM (0xFF) // Exit continuous read mode
125
126
#define QSPI_READ_CLK_MHZ (50)
127
#define QSPI_FASTREAD_CLK_MHZ (100)
128
129
// Manufacturer ID
130
#define ALT_QSPI_STIG_RDID_JEDECID_MICRON (0x20)
131
#define ALT_QSPI_STIG_RDID_JEDECID_NUMONYX (0x20)
// Same as Micron
132
#define ALT_QSPI_STIG_RDID_JEDECID_SPANSION (0xEF)
133
#define ALT_QSPI_STIG_RDID_JEDECID_WINBOND (0xEF)
// Same as Spansion
134
#define ALT_QSPI_STIG_RDID_JEDECID_MACRONIC (0xC2)
135
#define ALT_QSPI_STIG_RDID_JEDECID_ATMEL (0x1F)
136
137
#define ALT_QSPI_STIG_RDID_JEDECID_GET(value) ((value >> 0) & 0xff)
138
#define ALT_QSPI_STIG_RDID_CAPACITYID_GET(value) ((value >> 16) & 0xff)
139
140
#define ALT_QSPI_STIG_FLAGSR_ERASEPROGRAMREADY_GET(value) ((value >> 7) & 0x1)
141
#define ALT_QSPI_STIG_FLAGSR_ERASEREADY_GET(value) ((value >> 7) & 0x1)
142
#define ALT_QSPI_STIG_FLAGSR_PROGRAMREADY_GET(value) ((value >> 7) & 0x1)
143
#define ALT_QSPI_STIG_FLAGSR_ERASEERROR_GET(value) ((value >> 5) & 0x1)
144
#define ALT_QSPI_STIG_FLAGSR_PROGRAMERROR_GET(value) ((value >> 4) & 0x1)
145
#define ALT_QSPI_STIG_FLAGSR_ADDRESSINGMODE_GET(value) ((value >> 1) & 0x1)
146
#define ALT_QSPI_STIG_FLAGSR_PROTECTIONERROR_GET(value) ((value >> 0) & 0x1)
147
148
#define ALT_QSPI_STIG_SR_BUSY_GET(value) ((value >> 0) & 0x1)
149
151
152
#define ALT_QSPI_TIMEOUT_INFINITE (0xffffffff)
153
154
ALT_STATUS_CODE
alt_qspi_replace(uint32_t dst,
const
void
* src,
size_t
size);
155
156
ALT_STATUS_CODE
alt_qspi_stig_cmd(uint32_t opcode, uint32_t dummy, uint32_t timeout);
157
ALT_STATUS_CODE
alt_qspi_stig_rd_cmd(uint8_t opcode, uint32_t dummy,
158
uint32_t num_bytes, uint32_t * output,
159
uint32_t timeout);
160
ALT_STATUS_CODE
alt_qspi_stig_wr_cmd(uint8_t opcode, uint32_t dummy,
161
uint32_t num_bytes,
const
uint32_t * input,
162
uint32_t timeout);
163
ALT_STATUS_CODE
alt_qspi_stig_addr_cmd(uint8_t opcode, uint32_t dummy,
164
uint32_t address,
165
uint32_t timeout);
166
167
ALT_STATUS_CODE
alt_qspi_device_wren(
void
168
ALT_STATUS_CODE
alt_qspi_device_wrdis(
void
169
ALT_STATUS_CODE
alt_qspi_device_rdid(uint32_t * rdid);
170
ALT_STATUS_CODE
alt_qspi_discovery_parameter(uint32_t * param);
171
ALT_STATUS_CODE
alt_qspi_device_bank_select(uint32_t bank);
172
173
#endif
// __ALT_PRIVATE_QSPI_H__
ALT_STATUS_CODE
int32_t ALT_STATUS_CODE
Definition
hwlib.h:60
socal.h
