RTEMS
6.3
Toggle main menu visibility
bsps
arm
altera-cyclone-v
include
bsp
socal
alt_dmasecure.h
1
6
7
8
9
* Copyright 2013 Altera Corporation. All Rights Reserved. *
10
11
* Redistribution and use in source and binary forms, with or without *
12
* modification, are permitted provided that the following conditions are met: *
13
14
* 1. Redistributions of source code must retain the above copyright notice, *
15
* this list of conditions and the following disclaimer. *
16
17
* 2. Redistributions in binary form must reproduce the above copyright notice, *
18
* this list of conditions and the following disclaimer in the documentation *
19
* and/or other materials provided with the distribution. *
20
21
* 3. The name of the author may not be used to endorse or promote products *
22
* derived from this software without specific prior written permission. *
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27
* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33
* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34
35
36
37
/* Altera - ALT_DMASECURE */
38
39
#ifndef __ALTERA_ALT_DMASECURE_H__
40
#define __ALTERA_ALT_DMASECURE_H__
41
42
#ifdef __cplusplus
43
extern
"C"
44
45
#endif
/* __cplusplus */
46
47
48
* Component : secure DMA Module Address Space - ALT_DMASECURE
49
* secure DMA Module Address Space
50
51
* Address space allocated to the secure DMA. For detailed information about the
52
* use of this address space,
53
* [url=http://infocenter.arm.com/help/topic/com.arm.doc.ddi0424b/index.html]click
54
* here[/url] to access the ARM documentation for the DMA-330.
55
56
57
58
* Register : Empty - reg
59
60
* Placeholder
61
62
* Register Layout
63
64
* Bits | Access | Reset | Description
65
66
* [31:0] | RW | Unknown | Empty
67
68
69
70
* Field : Empty - fld
71
72
* Placeholder
73
74
* Field Access Macros:
75
76
77
/* The Least Significant Bit (LSB) position of the ALT_DMASECURE_REG_FLD register field. */
78
#define ALT_DMASECURE_REG_FLD_LSB 0
79
/* The Most Significant Bit (MSB) position of the ALT_DMASECURE_REG_FLD register field. */
80
#define ALT_DMASECURE_REG_FLD_MSB 31
81
/* The width in bits of the ALT_DMASECURE_REG_FLD register field. */
82
#define ALT_DMASECURE_REG_FLD_WIDTH 32
83
/* The mask used to set the ALT_DMASECURE_REG_FLD register field value. */
84
#define ALT_DMASECURE_REG_FLD_SET_MSK 0xffffffff
85
/* The mask used to clear the ALT_DMASECURE_REG_FLD register field value. */
86
#define ALT_DMASECURE_REG_FLD_CLR_MSK 0x00000000
87
/* The reset value of the ALT_DMASECURE_REG_FLD register field is UNKNOWN. */
88
#define ALT_DMASECURE_REG_FLD_RESET 0x0
89
/* Extracts the ALT_DMASECURE_REG_FLD field value from a register. */
90
#define ALT_DMASECURE_REG_FLD_GET(value) (((value) & 0xffffffff) >> 0)
91
/* Produces a ALT_DMASECURE_REG_FLD register field value suitable for setting the register. */
92
#define ALT_DMASECURE_REG_FLD_SET(value) (((value) << 0) & 0xffffffff)
93
94
#ifndef __ASSEMBLY__
95
96
* WARNING: The C register and register group struct declarations are provided for
97
* convenience and illustrative purposes. They should, however, be used with
98
* caution as the C language standard provides no guarantees about the alignment or
99
* atomicity of device memory accesses. The recommended practice for writing
100
* hardware drivers is to use the SoCAL access macros and alt_read_word() and
101
* alt_write_word() functions.
102
103
* The struct declaration for register ALT_DMASECURE_REG.
104
105
struct
ALT_DMASECURE_REG_s
106
107
uint32_t fld : 32;
/* Empty */
108
109
110
/* The typedef declaration for register ALT_DMASECURE_REG. */
111
typedef
volatile
struct
ALT_DMASECURE_REG_s
ALT_DMASECURE_REG_t;
112
#endif
/* __ASSEMBLY__ */
113
114
/* The byte offset of the ALT_DMASECURE_REG register from the beginning of the component. */
115
#define ALT_DMASECURE_REG_OFST 0x0
116
117
118
119
120
121
122
123
124
125
126
* The struct declaration for register group ALT_DMASECURE.
127
128
struct
ALT_DMASECURE_s
129
130
volatile
ALT_DMASECURE_REG_t reg;
/* ALT_DMASECURE_REG */
131
132
133
/* The typedef declaration for register group ALT_DMASECURE. */
134
typedef
volatile
struct
ALT_DMASECURE_s
ALT_DMASECURE_t;
135
/* The struct declaration for the raw register contents of register group ALT_DMASECURE. */
136
struct
ALT_DMASECURE_raw_s
137
138
volatile
uint32_t reg;
139
140
141
/* The typedef declaration for the raw register contents of register group ALT_DMASECURE. */
142
typedef
volatile
struct
ALT_DMASECURE_raw_s
ALT_DMASECURE_raw_t;
143
#endif
/* __ASSEMBLY__ */
144
145
146
#ifdef __cplusplus
147
148
#endif
/* __cplusplus */
149
#endif
/* __ALTERA_ALT_DMASECURE_H__ */
150
ALT_DMASECURE_REG_s
Definition
alt_dmasecure.h:106
ALT_DMASECURE_raw_s
Definition
alt_dmasecure.h:137
ALT_DMASECURE_s
Definition
alt_dmasecure.h:129
