RTEMS 6.3
| void | ACC_Configure (Acc *pAcc, uint8_t idAcc, uint8_t ucSelplus, uint8_t ucSelminus, uint16_t wAc_en, uint16_t wEdge, uint16_t wInvert) |
| Initialize the ACC controller. | |
| void | ACC_SetComparisonPair (Acc *pAcc, uint8_t ucSelplus, uint8_t ucSelminus) |
| uint32_t | ACC_GetComparisonResult (Acc *pAcc, uint32_t dwStatus) |
Implementation of Analog Comparator Controller (ACC).
extern |
| pAcc | Pointer to an Acc instance. |
| idAcc | ACC identifier |
| ucSelplus | input connected to inp, 0~7 |
| ucSelminus | input connected to inm,0~7 |
| wAc_en | Analog comparator enabled/disabled |
| wEdge | CF flag triggering mode |
| wInvert | INVert comparator output,use pattern defined in the device header file |
extern |
Return Comparison Result
| dwStatus | value of ACC_ISR |
