RTEMS
6.3
Toggle main menu visibility
bsps
aarch64
xilinx-zynqmp
include
tm27.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
13
* Written by Kinsey Moore <kinsey.moore@oarcorp.com>
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_TMTEST27
38
#error "This is an RTEMS internal file you must not include directly."
39
#endif
40
41
#ifndef __tm27_h
42
#define __tm27_h
43
44
45
* On ZynqMP hardware, SGI0-7 are permanently enabled for IPI usage while
46
* SGI8-15 are permanently disabled along with PPI16-24. Override tm27's usage
47
* of SGI12 and SGI13 with SGI6 and SGI7.
48
49
#define ARM_GIC_TM27_IRQ_LOW ARM_GIC_IRQ_SGI_6
50
#define ARM_GIC_TM27_IRQ_HIGH ARM_GIC_IRQ_SGI_7
51
52
dev/irq/arm-gic-tm27.h
53
54
#endif
/* __tm27_h */
arm-gic-tm27.h
This header file provides the TM27 support for the ARM Generic Interrupt Controller (GIC).
