RTEMS 6.3
Watchdog Driver. More...
#include <bsp/raspberrypi.h>#include <bsp/watchdog.h>Macros | |
| #define | PM_WDOG BCM2835_REG(BCM2711_PM_WDOG) |
| #define | PM_RSTC BCM2835_REG(BCM2711_PM_RSTC) |
| void | raspberrypi_watchdog_init () |
| Initialize BSP watchdog routines. | |
| void | raspberrypi_watchdog_start (uint32_t timeout_ms) |
| Turn on the watchdog / begin the counter at the desired value. | |
| void | raspberrypi_watchdog_stop () |
| Turn off the watchdog. | |
| void | raspberrypi_watchdog_reload () |
| Reload watchdog. | |
| uint32_t | raspberrypi_watchdog_get_remaining_time () |
| Get the remaining time of the watchdog. The return value is still valid when the watchdog has been stopped. | |
| uint32_t | raspberrypi_watchdog_timeout |
Watchdog Driver.
| uint32_t raspberrypi_watchdog_get_remaining_time | ( | void | ) |
| Watchdog | remaining time in ms. |
| void raspberrypi_watchdog_init | ( | void | ) |
void raspberrypi_watchdog_example() { raspberrypi_watchdog_init(); raspberrypi_watchdog_start(15000);
raspberrypi_watchdog_reload(); ... raspberrypi_watchdog_reload();
| void raspberrypi_watchdog_start | ( | uint32_t | timeout_ms | ) |
| timeout | Watchdog timeout value in ms. The watchdog device has 20 bits of timeout, so it only supports a maximum of 15999 ms for its timeout. This value should be between 0 and 15999. |
