RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
include
bsp
VME.h
1
8
9
#ifndef RTEMS_BSP_VME_API_H
10
#define RTEMS_BSP_VME_API_H
11
12
13
* Authorship
14
15
* This software was created by
16
* Till Straumann <strauman@slac.stanford.edu>, 2002,
17
* Stanford Linear Accelerator Center, Stanford University.
18
19
* Acknowledgement of sponsorship
20
21
* This software was produced by
22
* the Stanford Linear Accelerator Center, Stanford University,
23
* under Contract DE-AC03-76SFO0515 with the Department of Energy.
24
25
* Government disclaimer of liability
26
27
* Neither the United States nor the United States Department of Energy,
28
* nor any of their employees, makes any warranty, express or implied, or
29
* assumes any legal liability or responsibility for the accuracy,
30
* completeness, or usefulness of any data, apparatus, product, or process
31
* disclosed, or represents that its use would not infringe privately owned
32
* rights.
33
34
* Stanford disclaimer of liability
35
36
* Stanford University makes no representations or warranties, express or
37
* implied, nor assumes any liability for the use of this software.
38
39
* Stanford disclaimer of copyright
40
41
* Stanford University, owner of the copyright, hereby disclaims its
42
* copyright and all other rights in this software. Hence, anyone may
43
* freely use it for any purpose without restriction.
44
45
* Maintenance of notices
46
47
* In the interest of clarity regarding the origin and status of this
48
* SLAC software, this and all the preceding Stanford University notices
49
* are to remain affixed to any copy or derivative of this software made
50
* or distributed by the recipient and are to be affixed to any copy of
51
* software made or distributed by the recipient that contains a copy or
52
* derivative of this software.
53
54
* ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
55
56
57
59
/* address modifiers & friends */
60
bsp/vme_am_defs.h
61
62
#ifndef BSP_LOCAL2PCI_ADDR
63
#define BSP_LOCAL2PCI_ADDR(a) ((unsigned long)(a) + PCI_DRAM_OFFSET)
64
#endif
65
66
#ifdef __cplusplus
67
extern
"C"
68
#endif
69
78
79
void
BSP_vme_config(
void
80
81
/* translate through host bridge and vme master window of vme bridge */
82
int
83
BSP_vme2local_adrs(
unsigned
long
am,
unsigned
long
vmeaddr,
unsigned
long
*plocaladdr);
84
85
/* how a CPU address is mapped to the VME bus (if at all) */
86
int
87
BSP_local2vme_adrs(
unsigned
long
am,
unsigned
long
localaddr,
unsigned
long
*pvmeaddr);
88
89
/* interrupt handlers and levels */
90
typedef
void (*BSP_VME_ISR_t)(
void
*usrArg,
unsigned
long
vector);
91
92
int
93
BSP_installVME_isr(
unsigned
long
vector, BSP_VME_ISR_t handler,
void
*arg);
94
int
95
BSP_removeVME_isr(
unsigned
long
void
*arg);
96
97
/* retrieve the currently installed ISR for a given vector */
98
BSP_VME_ISR_t
99
BSP_getVME_isr(
unsigned
long
vector,
void
**parg);
100
101
int
102
BSP_enableVME_int_lvl(
unsigned
int
level);
103
104
int
105
BSP_disableVME_int_lvl(
unsigned
int
level);
106
107
int
108
BSP_VMEOutboundPortCfg(
109
unsigned
long
port,
110
unsigned
long
address_space,
111
unsigned
long
vme_address,
112
unsigned
long
pci_address,
113
unsigned
long
size);
114
115
int
116
BSP_VMEInboundPortCfg(
117
unsigned
long
port,
118
unsigned
long
address_space,
119
unsigned
long
vme_address,
120
unsigned
long
pci_address,
121
unsigned
long
size);
122
123
void
124
BSP_VMEOutboundPortsShow(FILE *f);
125
126
void
127
BSP_VMEInboundPortsShow(FILE *f);
128
129
/* Assert VME SYSRESET */
130
void
131
BSP_VMEResetBus(
void
132
133
#ifdef __cplusplus
134
135
#endif
136
137
#endif
vme_am_defs.h
vxworks compatible addressing modes
