RTEMS 6.3
fsl_iomuxc.h
1/*
2 * Copyright 2016 Freescale Semiconductor, Inc.
3 * Copyright 2016-2021 NXP
4 * All rights reserved.
5 *
6 * SPDX-License-Identifier: BSD-3-Clause
7 */
8
9#ifndef _FSL_IOMUXC_H_
10#define _FSL_IOMUXC_H_
11
12#include "fsl_common.h"
13
18
20
21/*******************************************************************************
22 * Definitions
23 ******************************************************************************/
24/* Component ID definition, used by tools. */
25#ifndef FSL_COMPONENT_ID
26#define FSL_COMPONENT_ID "platform.drivers.iomuxc"
27#endif
28
32#define FSL_IOMUXC_DRIVER_VERSION (MAKE_VERSION(2, 0, 0))
34
41#define IOMUXC_GPIO_LPSR_00_FLEXCAN3_TX 0x40C08000U, 0x0U, 0, 0, 0x40C08040U
42#define IOMUXC_GPIO_LPSR_00_MIC_CLK 0x40C08000U, 0x1U, 0, 0, 0x40C08040U
43#define IOMUXC_GPIO_LPSR_00_MQS_RIGHT 0x40C08000U, 0x2U, 0, 0, 0x40C08040U
44#define IOMUXC_GPIO_LPSR_00_ARM_CM4_EVENTO 0x40C08000U, 0x3U, 0, 0, 0x40C08040U
45#define IOMUXC_GPIO_LPSR_00_GPIO_MUX6_IO00 0x40C08000U, 0x5U, 0, 0, 0x40C08040U
46#define IOMUXC_GPIO_LPSR_00_LPUART12_TXD 0x40C08000U, 0x6U, 0x40C080B0U, 0x0U, 0x40C08040U
47#define IOMUXC_GPIO_LPSR_00_SAI4_MCLK 0x40C08000U, 0x7U, 0x40C080C8U, 0x0U, 0x40C08040U
48#define IOMUXC_GPIO_LPSR_00_GPIO12_IO00 0x40C08000U, 0xAU, 0, 0, 0x40C08040U
49
50#define IOMUXC_GPIO_LPSR_01_FLEXCAN3_RX 0x40C08004U, 0x0U, 0x40C08080U, 0x0U, 0x40C08044U
51#define IOMUXC_GPIO_LPSR_01_MIC_BITSTREAM0 0x40C08004U, 0x1U, 0x40C080B4U, 0x0U, 0x40C08044U
52#define IOMUXC_GPIO_LPSR_01_MQS_LEFT 0x40C08004U, 0x2U, 0, 0, 0x40C08044U
53#define IOMUXC_GPIO_LPSR_01_ARM_CM4_EVENTI 0x40C08004U, 0x3U, 0, 0, 0x40C08044U
54#define IOMUXC_GPIO_LPSR_01_GPIO_MUX6_IO01 0x40C08004U, 0x5U, 0, 0, 0x40C08044U
55#define IOMUXC_GPIO_LPSR_01_LPUART12_RXD 0x40C08004U, 0x6U, 0x40C080ACU, 0x0U, 0x40C08044U
56#define IOMUXC_GPIO_LPSR_01_GPIO12_IO01 0x40C08004U, 0xAU, 0, 0, 0x40C08044U
57
58#define IOMUXC_GPIO_LPSR_02_GPIO12_IO02 0x40C08008U, 0xAU, 0, 0, 0x40C08048U
59#define IOMUXC_GPIO_LPSR_02_SRC_BOOT_MODE00 0x40C08008U, 0x0U, 0, 0, 0x40C08048U
60#define IOMUXC_GPIO_LPSR_02_LPSPI5_SCK 0x40C08008U, 0x1U, 0x40C08098U, 0x0U, 0x40C08048U
61#define IOMUXC_GPIO_LPSR_02_SAI4_TX_DATA 0x40C08008U, 0x2U, 0, 0, 0x40C08048U
62#define IOMUXC_GPIO_LPSR_02_MQS_RIGHT 0x40C08008U, 0x3U, 0, 0, 0x40C08048U
63#define IOMUXC_GPIO_LPSR_02_GPIO_MUX6_IO02 0x40C08008U, 0x5U, 0, 0, 0x40C08048U
64
65#define IOMUXC_GPIO_LPSR_03_SRC_BOOT_MODE01 0x40C0800CU, 0x0U, 0, 0, 0x40C0804CU
66#define IOMUXC_GPIO_LPSR_03_LPSPI5_PCS0 0x40C0800CU, 0x1U, 0x40C08094U, 0x0U, 0x40C0804CU
67#define IOMUXC_GPIO_LPSR_03_SAI4_TX_SYNC 0x40C0800CU, 0x2U, 0x40C080DCU, 0x0U, 0x40C0804CU
68#define IOMUXC_GPIO_LPSR_03_MQS_LEFT 0x40C0800CU, 0x3U, 0, 0, 0x40C0804CU
69#define IOMUXC_GPIO_LPSR_03_GPIO_MUX6_IO03 0x40C0800CU, 0x5U, 0, 0, 0x40C0804CU
70#define IOMUXC_GPIO_LPSR_03_GPIO12_IO03 0x40C0800CU, 0xAU, 0, 0, 0x40C0804CU
71
72#define IOMUXC_GPIO_LPSR_04_LPI2C5_SDA 0x40C08010U, 0x0U, 0x40C08088U, 0x0U, 0x40C08050U
73#define IOMUXC_GPIO_LPSR_04_LPSPI5_SOUT 0x40C08010U, 0x1U, 0x40C080A0U, 0x0U, 0x40C08050U
74#define IOMUXC_GPIO_LPSR_04_SAI4_TX_BCLK 0x40C08010U, 0x2U, 0x40C080D8U, 0x0U, 0x40C08050U
75#define IOMUXC_GPIO_LPSR_04_LPUART12_RTS_B 0x40C08010U, 0x3U, 0, 0, 0x40C08050U
76#define IOMUXC_GPIO_LPSR_04_GPIO_MUX6_IO04 0x40C08010U, 0x5U, 0, 0, 0x40C08050U
77#define IOMUXC_GPIO_LPSR_04_LPUART11_TXD 0x40C08010U, 0x6U, 0x40C080A8U, 0x0U, 0x40C08050U
78#define IOMUXC_GPIO_LPSR_04_GPIO12_IO04 0x40C08010U, 0xAU, 0, 0, 0x40C08050U
79
80#define IOMUXC_GPIO_LPSR_05_GPIO12_IO05 0x40C08014U, 0xAU, 0, 0, 0x40C08054U
81#define IOMUXC_GPIO_LPSR_05_LPI2C5_SCL 0x40C08014U, 0x0U, 0x40C08084U, 0x0U, 0x40C08054U
82#define IOMUXC_GPIO_LPSR_05_LPSPI5_SIN 0x40C08014U, 0x1U, 0x40C0809CU, 0x0U, 0x40C08054U
83#define IOMUXC_GPIO_LPSR_05_SAI4_MCLK 0x40C08014U, 0x2U, 0x40C080C8U, 0x1U, 0x40C08054U
84#define IOMUXC_GPIO_LPSR_05_LPUART12_CTS_B 0x40C08014U, 0x3U, 0, 0, 0x40C08054U
85#define IOMUXC_GPIO_LPSR_05_GPIO_MUX6_IO05 0x40C08014U, 0x5U, 0, 0, 0x40C08054U
86#define IOMUXC_GPIO_LPSR_05_LPUART11_RXD 0x40C08014U, 0x6U, 0x40C080A4U, 0x0U, 0x40C08054U
87#define IOMUXC_GPIO_LPSR_05_NMI_GLUE_NMI 0x40C08014U, 0x7U, 0x40C080C4U, 0x0U, 0x40C08054U
88
89#define IOMUXC_GPIO_LPSR_06_LPI2C6_SDA 0x40C08018U, 0x0U, 0x40C08090U, 0x0U, 0x40C08058U
90#define IOMUXC_GPIO_LPSR_06_SAI4_RX_DATA 0x40C08018U, 0x2U, 0x40C080D0U, 0x0U, 0x40C08058U
91#define IOMUXC_GPIO_LPSR_06_LPUART12_TXD 0x40C08018U, 0x3U, 0x40C080B0U, 0x1U, 0x40C08058U
92#define IOMUXC_GPIO_LPSR_06_LPSPI6_PCS3 0x40C08018U, 0x4U, 0, 0, 0x40C08058U
93#define IOMUXC_GPIO_LPSR_06_GPIO_MUX6_IO06 0x40C08018U, 0x5U, 0, 0, 0x40C08058U
94#define IOMUXC_GPIO_LPSR_06_FLEXCAN3_TX 0x40C08018U, 0x6U, 0, 0, 0x40C08058U
95#define IOMUXC_GPIO_LPSR_06_PIT2_TRIGGER3 0x40C08018U, 0x7U, 0, 0, 0x40C08058U
96#define IOMUXC_GPIO_LPSR_06_LPSPI5_PCS1 0x40C08018U, 0x8U, 0, 0, 0x40C08058U
97#define IOMUXC_GPIO_LPSR_06_GPIO12_IO06 0x40C08018U, 0xAU, 0, 0, 0x40C08058U
98
99#define IOMUXC_GPIO_LPSR_07_LPI2C6_SCL 0x40C0801CU, 0x0U, 0x40C0808CU, 0x0U, 0x40C0805CU
100#define IOMUXC_GPIO_LPSR_07_SAI4_RX_BCLK 0x40C0801CU, 0x2U, 0x40C080CCU, 0x0U, 0x40C0805CU
101#define IOMUXC_GPIO_LPSR_07_LPUART12_RXD 0x40C0801CU, 0x3U, 0x40C080ACU, 0x1U, 0x40C0805CU
102#define IOMUXC_GPIO_LPSR_07_LPSPI6_PCS2 0x40C0801CU, 0x4U, 0, 0, 0x40C0805CU
103#define IOMUXC_GPIO_LPSR_07_GPIO_MUX6_IO07 0x40C0801CU, 0x5U, 0, 0, 0x40C0805CU
104#define IOMUXC_GPIO_LPSR_07_FLEXCAN3_RX 0x40C0801CU, 0x6U, 0x40C08080U, 0x1U, 0x40C0805CU
105#define IOMUXC_GPIO_LPSR_07_PIT2_TRIGGER2 0x40C0801CU, 0x7U, 0, 0, 0x40C0805CU
106#define IOMUXC_GPIO_LPSR_07_LPSPI5_PCS2 0x40C0801CU, 0x8U, 0, 0, 0x40C0805CU
107#define IOMUXC_GPIO_LPSR_07_GPIO12_IO07 0x40C0801CU, 0xAU, 0, 0, 0x40C0805CU
108
109#define IOMUXC_GPIO_LPSR_08_GPIO12_IO08 0x40C08020U, 0xAU, 0, 0, 0x40C08060U
110#define IOMUXC_GPIO_LPSR_08_LPUART11_TXD 0x40C08020U, 0x0U, 0x40C080A8U, 0x1U, 0x40C08060U
111#define IOMUXC_GPIO_LPSR_08_FLEXCAN3_TX 0x40C08020U, 0x1U, 0, 0, 0x40C08060U
112#define IOMUXC_GPIO_LPSR_08_SAI4_RX_SYNC 0x40C08020U, 0x2U, 0x40C080D4U, 0x0U, 0x40C08060U
113#define IOMUXC_GPIO_LPSR_08_MIC_CLK 0x40C08020U, 0x3U, 0, 0, 0x40C08060U
114#define IOMUXC_GPIO_LPSR_08_LPSPI6_PCS1 0x40C08020U, 0x4U, 0, 0, 0x40C08060U
115#define IOMUXC_GPIO_LPSR_08_GPIO_MUX6_IO08 0x40C08020U, 0x5U, 0, 0, 0x40C08060U
116#define IOMUXC_GPIO_LPSR_08_LPI2C5_SDA 0x40C08020U, 0x6U, 0x40C08088U, 0x1U, 0x40C08060U
117#define IOMUXC_GPIO_LPSR_08_PIT2_TRIGGER1 0x40C08020U, 0x7U, 0, 0, 0x40C08060U
118#define IOMUXC_GPIO_LPSR_08_LPSPI5_PCS3 0x40C08020U, 0x8U, 0, 0, 0x40C08060U
119
120#define IOMUXC_GPIO_LPSR_09_GPIO12_IO09 0x40C08024U, 0xAU, 0, 0, 0x40C08064U
121#define IOMUXC_GPIO_LPSR_09_LPUART11_RXD 0x40C08024U, 0x0U, 0x40C080A4U, 0x1U, 0x40C08064U
122#define IOMUXC_GPIO_LPSR_09_FLEXCAN3_RX 0x40C08024U, 0x1U, 0x40C08080U, 0x2U, 0x40C08064U
123#define IOMUXC_GPIO_LPSR_09_PIT2_TRIGGER0 0x40C08024U, 0x2U, 0, 0, 0x40C08064U
124#define IOMUXC_GPIO_LPSR_09_MIC_BITSTREAM0 0x40C08024U, 0x3U, 0x40C080B4U, 0x1U, 0x40C08064U
125#define IOMUXC_GPIO_LPSR_09_LPSPI6_PCS0 0x40C08024U, 0x4U, 0, 0, 0x40C08064U
126#define IOMUXC_GPIO_LPSR_09_GPIO_MUX6_IO09 0x40C08024U, 0x5U, 0, 0, 0x40C08064U
127#define IOMUXC_GPIO_LPSR_09_LPI2C5_SCL 0x40C08024U, 0x6U, 0x40C08084U, 0x1U, 0x40C08064U
128#define IOMUXC_GPIO_LPSR_09_SAI4_TX_DATA 0x40C08024U, 0x7U, 0, 0, 0x40C08064U
129
130#define IOMUXC_GPIO_LPSR_10_GPIO12_IO10 0x40C08028U, 0xAU, 0, 0, 0x40C08068U
131#define IOMUXC_GPIO_LPSR_10_JTAG_MUX_TRSTB 0x40C08028U, 0x0U, 0, 0, 0x40C08068U
132#define IOMUXC_GPIO_LPSR_10_LPUART11_CTS_B 0x40C08028U, 0x1U, 0, 0, 0x40C08068U
133#define IOMUXC_GPIO_LPSR_10_LPI2C6_SDA 0x40C08028U, 0x2U, 0x40C08090U, 0x1U, 0x40C08068U
134#define IOMUXC_GPIO_LPSR_10_MIC_BITSTREAM1 0x40C08028U, 0x3U, 0x40C080B8U, 0x0U, 0x40C08068U
135#define IOMUXC_GPIO_LPSR_10_LPSPI6_SCK 0x40C08028U, 0x4U, 0, 0, 0x40C08068U
136#define IOMUXC_GPIO_LPSR_10_GPIO_MUX6_IO10 0x40C08028U, 0x5U, 0, 0, 0x40C08068U
137#define IOMUXC_GPIO_LPSR_10_LPI2C5_SCLS 0x40C08028U, 0x6U, 0, 0, 0x40C08068U
138#define IOMUXC_GPIO_LPSR_10_SAI4_TX_SYNC 0x40C08028U, 0x7U, 0x40C080DCU, 0x1U, 0x40C08068U
139#define IOMUXC_GPIO_LPSR_10_LPUART12_TXD 0x40C08028U, 0x8U, 0x40C080B0U, 0x2U, 0x40C08068U
140
141#define IOMUXC_GPIO_LPSR_11_JTAG_MUX_TDO 0x40C0802CU, 0x0U, 0, 0, 0x40C0806CU
142#define IOMUXC_GPIO_LPSR_11_LPUART11_RTS_B 0x40C0802CU, 0x1U, 0, 0, 0x40C0806CU
143#define IOMUXC_GPIO_LPSR_11_LPI2C6_SCL 0x40C0802CU, 0x2U, 0x40C0808CU, 0x1U, 0x40C0806CU
144#define IOMUXC_GPIO_LPSR_11_MIC_BITSTREAM2 0x40C0802CU, 0x3U, 0x40C080BCU, 0x0U, 0x40C0806CU
145#define IOMUXC_GPIO_LPSR_11_LPSPI6_SOUT 0x40C0802CU, 0x4U, 0, 0, 0x40C0806CU
146#define IOMUXC_GPIO_LPSR_11_GPIO_MUX6_IO11 0x40C0802CU, 0x5U, 0, 0, 0x40C0806CU
147#define IOMUXC_GPIO_LPSR_11_LPI2C5_SDAS 0x40C0802CU, 0x6U, 0, 0, 0x40C0806CU
148#define IOMUXC_GPIO_LPSR_11_ARM_TRACE_SWO 0x40C0802CU, 0x7U, 0, 0, 0x40C0806CU
149#define IOMUXC_GPIO_LPSR_11_LPUART12_RXD 0x40C0802CU, 0x8U, 0x40C080ACU, 0x2U, 0x40C0806CU
150#define IOMUXC_GPIO_LPSR_11_GPIO12_IO11 0x40C0802CU, 0xAU, 0, 0, 0x40C0806CU
151
152#define IOMUXC_GPIO_LPSR_12_GPIO12_IO12 0x40C08030U, 0xAU, 0, 0, 0x40C08070U
153#define IOMUXC_GPIO_LPSR_12_JTAG_MUX_TDI 0x40C08030U, 0x0U, 0, 0, 0x40C08070U
154#define IOMUXC_GPIO_LPSR_12_PIT2_TRIGGER0 0x40C08030U, 0x1U, 0, 0, 0x40C08070U
155#define IOMUXC_GPIO_LPSR_12_MIC_BITSTREAM3 0x40C08030U, 0x3U, 0x40C080C0U, 0x0U, 0x40C08070U
156#define IOMUXC_GPIO_LPSR_12_LPSPI6_SIN 0x40C08030U, 0x4U, 0, 0, 0x40C08070U
157#define IOMUXC_GPIO_LPSR_12_GPIO_MUX6_IO12 0x40C08030U, 0x5U, 0, 0, 0x40C08070U
158#define IOMUXC_GPIO_LPSR_12_LPI2C5_HREQ 0x40C08030U, 0x6U, 0, 0, 0x40C08070U
159#define IOMUXC_GPIO_LPSR_12_SAI4_TX_BCLK 0x40C08030U, 0x7U, 0x40C080D8U, 0x1U, 0x40C08070U
160#define IOMUXC_GPIO_LPSR_12_LPSPI5_SCK 0x40C08030U, 0x8U, 0x40C08098U, 0x1U, 0x40C08070U
161
162#define IOMUXC_GPIO_LPSR_13_GPIO12_IO13 0x40C08034U, 0xAU, 0, 0, 0x40C08074U
163#define IOMUXC_GPIO_LPSR_13_JTAG_MUX_MOD 0x40C08034U, 0x0U, 0, 0, 0x40C08074U
164#define IOMUXC_GPIO_LPSR_13_MIC_BITSTREAM1 0x40C08034U, 0x1U, 0x40C080B8U, 0x1U, 0x40C08074U
165#define IOMUXC_GPIO_LPSR_13_PIT2_TRIGGER1 0x40C08034U, 0x2U, 0, 0, 0x40C08074U
166#define IOMUXC_GPIO_LPSR_13_GPIO_MUX6_IO13 0x40C08034U, 0x5U, 0, 0, 0x40C08074U
167#define IOMUXC_GPIO_LPSR_13_SAI4_RX_DATA 0x40C08034U, 0x7U, 0x40C080D0U, 0x1U, 0x40C08074U
168#define IOMUXC_GPIO_LPSR_13_LPSPI5_PCS0 0x40C08034U, 0x8U, 0x40C08094U, 0x1U, 0x40C08074U
169
170#define IOMUXC_GPIO_LPSR_14_JTAG_MUX_TCK 0x40C08038U, 0x0U, 0, 0, 0x40C08078U
171#define IOMUXC_GPIO_LPSR_14_MIC_BITSTREAM2 0x40C08038U, 0x1U, 0x40C080BCU, 0x1U, 0x40C08078U
172#define IOMUXC_GPIO_LPSR_14_PIT2_TRIGGER2 0x40C08038U, 0x2U, 0, 0, 0x40C08078U
173#define IOMUXC_GPIO_LPSR_14_GPIO_MUX6_IO14 0x40C08038U, 0x5U, 0, 0, 0x40C08078U
174#define IOMUXC_GPIO_LPSR_14_SAI4_RX_BCLK 0x40C08038U, 0x7U, 0x40C080CCU, 0x1U, 0x40C08078U
175#define IOMUXC_GPIO_LPSR_14_LPSPI5_SOUT 0x40C08038U, 0x8U, 0x40C080A0U, 0x1U, 0x40C08078U
176#define IOMUXC_GPIO_LPSR_14_GPIO12_IO14 0x40C08038U, 0xAU, 0, 0, 0x40C08078U
177
178#define IOMUXC_GPIO_LPSR_15_GPIO12_IO15 0x40C0803CU, 0xAU, 0, 0, 0x40C0807CU
179#define IOMUXC_GPIO_LPSR_15_JTAG_MUX_TMS 0x40C0803CU, 0x0U, 0, 0, 0x40C0807CU
180#define IOMUXC_GPIO_LPSR_15_MIC_BITSTREAM3 0x40C0803CU, 0x1U, 0x40C080C0U, 0x1U, 0x40C0807CU
181#define IOMUXC_GPIO_LPSR_15_PIT2_TRIGGER3 0x40C0803CU, 0x2U, 0, 0, 0x40C0807CU
182#define IOMUXC_GPIO_LPSR_15_GPIO_MUX6_IO15 0x40C0803CU, 0x5U, 0, 0, 0x40C0807CU
183#define IOMUXC_GPIO_LPSR_15_SAI4_RX_SYNC 0x40C0803CU, 0x7U, 0x40C080D4U, 0x1U, 0x40C0807CU
184#define IOMUXC_GPIO_LPSR_15_LPSPI5_SIN 0x40C0803CU, 0x8U, 0x40C0809CU, 0x1U, 0x40C0807CU
185
186#define IOMUXC_WAKEUP_DIG_GPIO13_IO00 0x40C94000U, 0x5U, 0, 0, 0x40C94040U
187#define IOMUXC_WAKEUP_DIG_NMI_GLUE_NMI 0x40C94000U, 0x7U, 0x40C080C4U, 0x1U, 0x40C94040U
188
189#define IOMUXC_PMIC_ON_REQ_DIG_SNVS_LP_PMIC_ON_REQ 0x40C94004U, 0x0U, 0, 0, 0x40C94044U
190#define IOMUXC_PMIC_ON_REQ_DIG_GPIO13_IO01 0x40C94004U, 0x5U, 0, 0, 0x40C94044U
191
192#define IOMUXC_PMIC_STBY_REQ_DIG_CCM_PMIC_VSTBY_REQ 0x40C94008U, 0x0U, 0, 0, 0x40C94048U
193#define IOMUXC_PMIC_STBY_REQ_DIG_GPIO13_IO02 0x40C94008U, 0x5U, 0, 0, 0x40C94048U
194
195#define IOMUXC_GPIO_SNVS_00_DIG_SNVS_TAMPER0 0x40C9400CU, 0x0U, 0, 0, 0x40C9404CU
196#define IOMUXC_GPIO_SNVS_00_DIG_GPIO13_IO03 0x40C9400CU, 0x5U, 0, 0, 0x40C9404CU
197
198#define IOMUXC_GPIO_SNVS_01_DIG_SNVS_TAMPER1 0x40C94010U, 0x0U, 0, 0, 0x40C94050U
199#define IOMUXC_GPIO_SNVS_01_DIG_GPIO13_IO04 0x40C94010U, 0x5U, 0, 0, 0x40C94050U
200
201#define IOMUXC_GPIO_SNVS_02_DIG_SNVS_TAMPER2 0x40C94014U, 0x0U, 0, 0, 0x40C94054U
202#define IOMUXC_GPIO_SNVS_02_DIG_GPIO13_IO05 0x40C94014U, 0x5U, 0, 0, 0x40C94054U
203
204#define IOMUXC_GPIO_SNVS_03_DIG_SNVS_TAMPER3 0x40C94018U, 0x0U, 0, 0, 0x40C94058U
205#define IOMUXC_GPIO_SNVS_03_DIG_GPIO13_IO06 0x40C94018U, 0x5U, 0, 0, 0x40C94058U
206
207#define IOMUXC_GPIO_SNVS_04_DIG_SNVS_TAMPER4 0x40C9401CU, 0x0U, 0, 0, 0x40C9405CU
208#define IOMUXC_GPIO_SNVS_04_DIG_GPIO13_IO07 0x40C9401CU, 0x5U, 0, 0, 0x40C9405CU
209
210#define IOMUXC_GPIO_SNVS_05_DIG_SNVS_TAMPER5 0x40C94020U, 0x0U, 0, 0, 0x40C94060U
211#define IOMUXC_GPIO_SNVS_05_DIG_GPIO13_IO08 0x40C94020U, 0x5U, 0, 0, 0x40C94060U
212
213#define IOMUXC_GPIO_SNVS_06_DIG_SNVS_TAMPER6 0x40C94024U, 0x0U, 0, 0, 0x40C94064U
214#define IOMUXC_GPIO_SNVS_06_DIG_GPIO13_IO09 0x40C94024U, 0x5U, 0, 0, 0x40C94064U
215
216#define IOMUXC_GPIO_SNVS_07_DIG_SNVS_TAMPER7 0x40C94028U, 0x0U, 0, 0, 0x40C94068U
217#define IOMUXC_GPIO_SNVS_07_DIG_GPIO13_IO10 0x40C94028U, 0x5U, 0, 0, 0x40C94068U
218
219#define IOMUXC_GPIO_SNVS_08_DIG_SNVS_TAMPER8 0x40C9402CU, 0x0U, 0, 0, 0x40C9406CU
220#define IOMUXC_GPIO_SNVS_08_DIG_GPIO13_IO11 0x40C9402CU, 0x5U, 0, 0, 0x40C9406CU
221
222#define IOMUXC_GPIO_SNVS_09_DIG_SNVS_TAMPER9 0x40C94030U, 0x0U, 0, 0, 0x40C94070U
223#define IOMUXC_GPIO_SNVS_09_DIG_GPIO13_IO12 0x40C94030U, 0x5U, 0, 0, 0x40C94070U
224
225#define IOMUXC_TEST_MODE_DIG 0, 0, 0, 0, 0x40C94034U
226
227#define IOMUXC_POR_B_DIG 0, 0, 0, 0, 0x40C94038U
228
229#define IOMUXC_ONOFF_DIG 0, 0, 0, 0, 0x40C9403CU
230
231#define IOMUXC_GPIO_EMC_B1_00_SEMC_DATA00 0x400E8010U, 0x0U, 0, 0, 0x400E8254U
232#define IOMUXC_GPIO_EMC_B1_00_FLEXPWM4_PWM0_A 0x400E8010U, 0x1U, 0, 0, 0x400E8254U
233#define IOMUXC_GPIO_EMC_B1_00_GPIO_MUX1_IO00 0x400E8010U, 0x5U, 0, 0, 0x400E8254U
234#define IOMUXC_GPIO_EMC_B1_00_FLEXIO1_D00 0x400E8010U, 0x8U, 0, 0, 0x400E8254U
235#define IOMUXC_GPIO_EMC_B1_00_GPIO7_IO00 0x400E8010U, 0xAU, 0, 0, 0x400E8254U
236
237#define IOMUXC_GPIO_EMC_B1_01_GPIO7_IO01 0x400E8014U, 0xAU, 0, 0, 0x400E8258U
238#define IOMUXC_GPIO_EMC_B1_01_SEMC_DATA01 0x400E8014U, 0x0U, 0, 0, 0x400E8258U
239#define IOMUXC_GPIO_EMC_B1_01_FLEXPWM4_PWM0_B 0x400E8014U, 0x1U, 0, 0, 0x400E8258U
240#define IOMUXC_GPIO_EMC_B1_01_GPIO_MUX1_IO01 0x400E8014U, 0x5U, 0, 0, 0x400E8258U
241#define IOMUXC_GPIO_EMC_B1_01_FLEXIO1_D01 0x400E8014U, 0x8U, 0, 0, 0x400E8258U
242
243#define IOMUXC_GPIO_EMC_B1_02_SEMC_DATA02 0x400E8018U, 0x0U, 0, 0, 0x400E825CU
244#define IOMUXC_GPIO_EMC_B1_02_FLEXPWM4_PWM1_A 0x400E8018U, 0x1U, 0, 0, 0x400E825CU
245#define IOMUXC_GPIO_EMC_B1_02_GPIO_MUX1_IO02 0x400E8018U, 0x5U, 0, 0, 0x400E825CU
246#define IOMUXC_GPIO_EMC_B1_02_FLEXIO1_D02 0x400E8018U, 0x8U, 0, 0, 0x400E825CU
247#define IOMUXC_GPIO_EMC_B1_02_GPIO7_IO02 0x400E8018U, 0xAU, 0, 0, 0x400E825CU
248
249#define IOMUXC_GPIO_EMC_B1_03_SEMC_DATA03 0x400E801CU, 0x0U, 0, 0, 0x400E8260U
250#define IOMUXC_GPIO_EMC_B1_03_FLEXPWM4_PWM1_B 0x400E801CU, 0x1U, 0, 0, 0x400E8260U
251#define IOMUXC_GPIO_EMC_B1_03_GPIO_MUX1_IO03 0x400E801CU, 0x5U, 0, 0, 0x400E8260U
252#define IOMUXC_GPIO_EMC_B1_03_FLEXIO1_D03 0x400E801CU, 0x8U, 0, 0, 0x400E8260U
253#define IOMUXC_GPIO_EMC_B1_03_GPIO7_IO03 0x400E801CU, 0xAU, 0, 0, 0x400E8260U
254
255#define IOMUXC_GPIO_EMC_B1_04_GPIO7_IO04 0x400E8020U, 0xAU, 0, 0, 0x400E8264U
256#define IOMUXC_GPIO_EMC_B1_04_SEMC_DATA04 0x400E8020U, 0x0U, 0, 0, 0x400E8264U
257#define IOMUXC_GPIO_EMC_B1_04_FLEXPWM4_PWM2_A 0x400E8020U, 0x1U, 0, 0, 0x400E8264U
258#define IOMUXC_GPIO_EMC_B1_04_GPIO_MUX1_IO04 0x400E8020U, 0x5U, 0, 0, 0x400E8264U
259#define IOMUXC_GPIO_EMC_B1_04_FLEXIO1_D04 0x400E8020U, 0x8U, 0, 0, 0x400E8264U
260
261#define IOMUXC_GPIO_EMC_B1_05_SEMC_DATA05 0x400E8024U, 0x0U, 0, 0, 0x400E8268U
262#define IOMUXC_GPIO_EMC_B1_05_FLEXPWM4_PWM2_B 0x400E8024U, 0x1U, 0, 0, 0x400E8268U
263#define IOMUXC_GPIO_EMC_B1_05_GPIO_MUX1_IO05 0x400E8024U, 0x5U, 0, 0, 0x400E8268U
264#define IOMUXC_GPIO_EMC_B1_05_FLEXIO1_D05 0x400E8024U, 0x8U, 0, 0, 0x400E8268U
265#define IOMUXC_GPIO_EMC_B1_05_GPIO7_IO05 0x400E8024U, 0xAU, 0, 0, 0x400E8268U
266
267#define IOMUXC_GPIO_EMC_B1_06_SEMC_DATA06 0x400E8028U, 0x0U, 0, 0, 0x400E826CU
268#define IOMUXC_GPIO_EMC_B1_06_FLEXPWM2_PWM0_A 0x400E8028U, 0x1U, 0x400E8518U, 0x0U, 0x400E826CU
269#define IOMUXC_GPIO_EMC_B1_06_GPIO_MUX1_IO06 0x400E8028U, 0x5U, 0, 0, 0x400E826CU
270#define IOMUXC_GPIO_EMC_B1_06_FLEXIO1_D06 0x400E8028U, 0x8U, 0, 0, 0x400E826CU
271#define IOMUXC_GPIO_EMC_B1_06_GPIO7_IO06 0x400E8028U, 0xAU, 0, 0, 0x400E826CU
272
273#define IOMUXC_GPIO_EMC_B1_07_GPIO7_IO07 0x400E802CU, 0xAU, 0, 0, 0x400E8270U
274#define IOMUXC_GPIO_EMC_B1_07_SEMC_DATA07 0x400E802CU, 0x0U, 0, 0, 0x400E8270U
275#define IOMUXC_GPIO_EMC_B1_07_FLEXPWM2_PWM0_B 0x400E802CU, 0x1U, 0x400E8524U, 0x0U, 0x400E8270U
276#define IOMUXC_GPIO_EMC_B1_07_GPIO_MUX1_IO07 0x400E802CU, 0x5U, 0, 0, 0x400E8270U
277#define IOMUXC_GPIO_EMC_B1_07_FLEXIO1_D07 0x400E802CU, 0x8U, 0, 0, 0x400E8270U
278
279#define IOMUXC_GPIO_EMC_B1_08_SEMC_DM00 0x400E8030U, 0x0U, 0, 0, 0x400E8274U
280#define IOMUXC_GPIO_EMC_B1_08_FLEXPWM2_PWM1_A 0x400E8030U, 0x1U, 0x400E851CU, 0x0U, 0x400E8274U
281#define IOMUXC_GPIO_EMC_B1_08_GPIO_MUX1_IO08 0x400E8030U, 0x5U, 0, 0, 0x400E8274U
282#define IOMUXC_GPIO_EMC_B1_08_FLEXIO1_D08 0x400E8030U, 0x8U, 0, 0, 0x400E8274U
283#define IOMUXC_GPIO_EMC_B1_08_GPIO7_IO08 0x400E8030U, 0xAU, 0, 0, 0x400E8274U
284
285#define IOMUXC_GPIO_EMC_B1_09_SEMC_ADDR00 0x400E8034U, 0x0U, 0, 0, 0x400E8278U
286#define IOMUXC_GPIO_EMC_B1_09_FLEXPWM2_PWM1_B 0x400E8034U, 0x1U, 0x400E8528U, 0x0U, 0x400E8278U
287#define IOMUXC_GPIO_EMC_B1_09_GPT5_CAPTURE1 0x400E8034U, 0x2U, 0, 0, 0x400E8278U
288#define IOMUXC_GPIO_EMC_B1_09_GPIO_MUX1_IO09 0x400E8034U, 0x5U, 0, 0, 0x400E8278U
289#define IOMUXC_GPIO_EMC_B1_09_FLEXIO1_D09 0x400E8034U, 0x8U, 0, 0, 0x400E8278U
290#define IOMUXC_GPIO_EMC_B1_09_GPIO7_IO09 0x400E8034U, 0xAU, 0, 0, 0x400E8278U
291
292#define IOMUXC_GPIO_EMC_B1_10_SEMC_ADDR01 0x400E8038U, 0x0U, 0, 0, 0x400E827CU
293#define IOMUXC_GPIO_EMC_B1_10_FLEXPWM2_PWM2_A 0x400E8038U, 0x1U, 0x400E8520U, 0x0U, 0x400E827CU
294#define IOMUXC_GPIO_EMC_B1_10_GPT5_CAPTURE2 0x400E8038U, 0x2U, 0, 0, 0x400E827CU
295#define IOMUXC_GPIO_EMC_B1_10_GPIO_MUX1_IO10 0x400E8038U, 0x5U, 0, 0, 0x400E827CU
296#define IOMUXC_GPIO_EMC_B1_10_FLEXIO1_D10 0x400E8038U, 0x8U, 0, 0, 0x400E827CU
297#define IOMUXC_GPIO_EMC_B1_10_GPIO7_IO10 0x400E8038U, 0xAU, 0, 0, 0x400E827CU
298
299#define IOMUXC_GPIO_EMC_B1_11_GPIO7_IO11 0x400E803CU, 0xAU, 0, 0, 0x400E8280U
300#define IOMUXC_GPIO_EMC_B1_11_SEMC_ADDR02 0x400E803CU, 0x0U, 0, 0, 0x400E8280U
301#define IOMUXC_GPIO_EMC_B1_11_FLEXPWM2_PWM2_B 0x400E803CU, 0x1U, 0x400E852CU, 0x0U, 0x400E8280U
302#define IOMUXC_GPIO_EMC_B1_11_GPT5_COMPARE1 0x400E803CU, 0x2U, 0, 0, 0x400E8280U
303#define IOMUXC_GPIO_EMC_B1_11_GPIO_MUX1_IO11 0x400E803CU, 0x5U, 0, 0, 0x400E8280U
304#define IOMUXC_GPIO_EMC_B1_11_FLEXIO1_D11 0x400E803CU, 0x8U, 0, 0, 0x400E8280U
305
306#define IOMUXC_GPIO_EMC_B1_12_SEMC_ADDR03 0x400E8040U, 0x0U, 0, 0, 0x400E8284U
307#define IOMUXC_GPIO_EMC_B1_12_XBAR1_INOUT04 0x400E8040U, 0x1U, 0, 0, 0x400E8284U
308#define IOMUXC_GPIO_EMC_B1_12_GPT5_COMPARE2 0x400E8040U, 0x2U, 0, 0, 0x400E8284U
309#define IOMUXC_GPIO_EMC_B1_12_GPIO_MUX1_IO12 0x400E8040U, 0x5U, 0, 0, 0x400E8284U
310#define IOMUXC_GPIO_EMC_B1_12_FLEXIO1_D12 0x400E8040U, 0x8U, 0, 0, 0x400E8284U
311#define IOMUXC_GPIO_EMC_B1_12_GPIO7_IO12 0x400E8040U, 0xAU, 0, 0, 0x400E8284U
312
313#define IOMUXC_GPIO_EMC_B1_13_SEMC_ADDR04 0x400E8044U, 0x0U, 0, 0, 0x400E8288U
314#define IOMUXC_GPIO_EMC_B1_13_XBAR1_INOUT05 0x400E8044U, 0x1U, 0, 0, 0x400E8288U
315#define IOMUXC_GPIO_EMC_B1_13_GPT5_COMPARE3 0x400E8044U, 0x2U, 0, 0, 0x400E8288U
316#define IOMUXC_GPIO_EMC_B1_13_GPIO_MUX1_IO13 0x400E8044U, 0x5U, 0, 0, 0x400E8288U
317#define IOMUXC_GPIO_EMC_B1_13_FLEXIO1_D13 0x400E8044U, 0x8U, 0, 0, 0x400E8288U
318#define IOMUXC_GPIO_EMC_B1_13_GPIO7_IO13 0x400E8044U, 0xAU, 0, 0, 0x400E8288U
319
320#define IOMUXC_GPIO_EMC_B1_14_GPIO7_IO14 0x400E8048U, 0xAU, 0, 0, 0x400E828CU
321#define IOMUXC_GPIO_EMC_B1_14_SEMC_ADDR05 0x400E8048U, 0x0U, 0, 0, 0x400E828CU
322#define IOMUXC_GPIO_EMC_B1_14_XBAR1_INOUT06 0x400E8048U, 0x1U, 0, 0, 0x400E828CU
323#define IOMUXC_GPIO_EMC_B1_14_GPT5_CLK 0x400E8048U, 0x2U, 0, 0, 0x400E828CU
324#define IOMUXC_GPIO_EMC_B1_14_GPIO_MUX1_IO14 0x400E8048U, 0x5U, 0, 0, 0x400E828CU
325#define IOMUXC_GPIO_EMC_B1_14_FLEXIO1_D14 0x400E8048U, 0x8U, 0, 0, 0x400E828CU
326
327#define IOMUXC_GPIO_EMC_B1_15_SEMC_ADDR06 0x400E804CU, 0x0U, 0, 0, 0x400E8290U
328#define IOMUXC_GPIO_EMC_B1_15_XBAR1_INOUT07 0x400E804CU, 0x1U, 0, 0, 0x400E8290U
329#define IOMUXC_GPIO_EMC_B1_15_GPIO_MUX1_IO15 0x400E804CU, 0x5U, 0, 0, 0x400E8290U
330#define IOMUXC_GPIO_EMC_B1_15_FLEXIO1_D15 0x400E804CU, 0x8U, 0, 0, 0x400E8290U
331#define IOMUXC_GPIO_EMC_B1_15_GPIO7_IO15 0x400E804CU, 0xAU, 0, 0, 0x400E8290U
332
333#define IOMUXC_GPIO_EMC_B1_16_SEMC_ADDR07 0x400E8050U, 0x0U, 0, 0, 0x400E8294U
334#define IOMUXC_GPIO_EMC_B1_16_XBAR1_INOUT08 0x400E8050U, 0x1U, 0, 0, 0x400E8294U
335#define IOMUXC_GPIO_EMC_B1_16_GPIO_MUX1_IO16 0x400E8050U, 0x5U, 0, 0, 0x400E8294U
336#define IOMUXC_GPIO_EMC_B1_16_FLEXIO1_D16 0x400E8050U, 0x8U, 0, 0, 0x400E8294U
337#define IOMUXC_GPIO_EMC_B1_16_GPIO7_IO16 0x400E8050U, 0xAU, 0, 0, 0x400E8294U
338
339#define IOMUXC_GPIO_EMC_B1_17_GPIO7_IO17 0x400E8054U, 0xAU, 0, 0, 0x400E8298U
340#define IOMUXC_GPIO_EMC_B1_17_SEMC_ADDR08 0x400E8054U, 0x0U, 0, 0, 0x400E8298U
341#define IOMUXC_GPIO_EMC_B1_17_FLEXPWM4_PWM3_A 0x400E8054U, 0x1U, 0, 0, 0x400E8298U
342#define IOMUXC_GPIO_EMC_B1_17_TMR1_TIMER0 0x400E8054U, 0x2U, 0x400E863CU, 0x0U, 0x400E8298U
343#define IOMUXC_GPIO_EMC_B1_17_GPIO_MUX1_IO17 0x400E8054U, 0x5U, 0, 0, 0x400E8298U
344#define IOMUXC_GPIO_EMC_B1_17_FLEXIO1_D17 0x400E8054U, 0x8U, 0, 0, 0x400E8298U
345
346#define IOMUXC_GPIO_EMC_B1_18_SEMC_ADDR09 0x400E8058U, 0x0U, 0, 0, 0x400E829CU
347#define IOMUXC_GPIO_EMC_B1_18_FLEXPWM4_PWM3_B 0x400E8058U, 0x1U, 0, 0, 0x400E829CU
348#define IOMUXC_GPIO_EMC_B1_18_TMR2_TIMER0 0x400E8058U, 0x2U, 0x400E8648U, 0x0U, 0x400E829CU
349#define IOMUXC_GPIO_EMC_B1_18_GPIO_MUX1_IO18 0x400E8058U, 0x5U, 0, 0, 0x400E829CU
350#define IOMUXC_GPIO_EMC_B1_18_FLEXIO1_D18 0x400E8058U, 0x8U, 0, 0, 0x400E829CU
351#define IOMUXC_GPIO_EMC_B1_18_GPIO7_IO18 0x400E8058U, 0xAU, 0, 0, 0x400E829CU
352
353#define IOMUXC_GPIO_EMC_B1_19_SEMC_ADDR11 0x400E805CU, 0x0U, 0, 0, 0x400E82A0U
354#define IOMUXC_GPIO_EMC_B1_19_FLEXPWM2_PWM3_A 0x400E805CU, 0x1U, 0, 0, 0x400E82A0U
355#define IOMUXC_GPIO_EMC_B1_19_TMR3_TIMER0 0x400E805CU, 0x2U, 0x400E8654U, 0x0U, 0x400E82A0U
356#define IOMUXC_GPIO_EMC_B1_19_GPIO_MUX1_IO19 0x400E805CU, 0x5U, 0, 0, 0x400E82A0U
357#define IOMUXC_GPIO_EMC_B1_19_FLEXIO1_D19 0x400E805CU, 0x8U, 0, 0, 0x400E82A0U
358#define IOMUXC_GPIO_EMC_B1_19_GPIO7_IO19 0x400E805CU, 0xAU, 0, 0, 0x400E82A0U
359
360#define IOMUXC_GPIO_EMC_B1_20_SEMC_ADDR12 0x400E8060U, 0x0U, 0, 0, 0x400E82A4U
361#define IOMUXC_GPIO_EMC_B1_20_FLEXPWM2_PWM3_B 0x400E8060U, 0x1U, 0, 0, 0x400E82A4U
362#define IOMUXC_GPIO_EMC_B1_20_TMR4_TIMER0 0x400E8060U, 0x2U, 0x400E8660U, 0x0U, 0x400E82A4U
363#define IOMUXC_GPIO_EMC_B1_20_GPIO_MUX1_IO20 0x400E8060U, 0x5U, 0, 0, 0x400E82A4U
364#define IOMUXC_GPIO_EMC_B1_20_FLEXIO1_D20 0x400E8060U, 0x8U, 0, 0, 0x400E82A4U
365#define IOMUXC_GPIO_EMC_B1_20_GPIO7_IO20 0x400E8060U, 0xAU, 0, 0, 0x400E82A4U
366
367#define IOMUXC_GPIO_EMC_B1_21_GPIO7_IO21 0x400E8064U, 0xAU, 0, 0, 0x400E82A8U
368#define IOMUXC_GPIO_EMC_B1_21_SEMC_BA0 0x400E8064U, 0x0U, 0, 0, 0x400E82A8U
369#define IOMUXC_GPIO_EMC_B1_21_FLEXPWM3_PWM3_A 0x400E8064U, 0x1U, 0x400E853CU, 0x0U, 0x400E82A8U
370#define IOMUXC_GPIO_EMC_B1_21_GPIO_MUX1_IO21 0x400E8064U, 0x5U, 0, 0, 0x400E82A8U
371#define IOMUXC_GPIO_EMC_B1_21_FLEXIO1_D21 0x400E8064U, 0x8U, 0, 0, 0x400E82A8U
372
373#define IOMUXC_GPIO_EMC_B1_22_GPIO7_IO22 0x400E8068U, 0xAU, 0, 0, 0x400E82ACU
374#define IOMUXC_GPIO_EMC_B1_22_SEMC_BA1 0x400E8068U, 0x0U, 0, 0, 0x400E82ACU
375#define IOMUXC_GPIO_EMC_B1_22_FLEXPWM3_PWM3_B 0x400E8068U, 0x1U, 0x400E854CU, 0x0U, 0x400E82ACU
376#define IOMUXC_GPIO_EMC_B1_22_GPIO_MUX1_IO22 0x400E8068U, 0x5U, 0, 0, 0x400E82ACU
377#define IOMUXC_GPIO_EMC_B1_22_FLEXIO1_D22 0x400E8068U, 0x8U, 0, 0, 0x400E82ACU
378
379#define IOMUXC_GPIO_EMC_B1_23_SEMC_ADDR10 0x400E806CU, 0x0U, 0, 0, 0x400E82B0U
380#define IOMUXC_GPIO_EMC_B1_23_FLEXPWM1_PWM0_A 0x400E806CU, 0x1U, 0x400E8500U, 0x0U, 0x400E82B0U
381#define IOMUXC_GPIO_EMC_B1_23_GPIO_MUX1_IO23 0x400E806CU, 0x5U, 0, 0, 0x400E82B0U
382#define IOMUXC_GPIO_EMC_B1_23_FLEXIO1_D23 0x400E806CU, 0x8U, 0, 0, 0x400E82B0U
383#define IOMUXC_GPIO_EMC_B1_23_GPIO7_IO23 0x400E806CU, 0xAU, 0, 0, 0x400E82B0U
384
385#define IOMUXC_GPIO_EMC_B1_24_GPIO7_IO24 0x400E8070U, 0xAU, 0, 0, 0x400E82B4U
386#define IOMUXC_GPIO_EMC_B1_24_SEMC_CAS 0x400E8070U, 0x0U, 0, 0, 0x400E82B4U
387#define IOMUXC_GPIO_EMC_B1_24_FLEXPWM1_PWM0_B 0x400E8070U, 0x1U, 0x400E850CU, 0x0U, 0x400E82B4U
388#define IOMUXC_GPIO_EMC_B1_24_GPIO_MUX1_IO24 0x400E8070U, 0x5U, 0, 0, 0x400E82B4U
389#define IOMUXC_GPIO_EMC_B1_24_FLEXIO1_D24 0x400E8070U, 0x8U, 0, 0, 0x400E82B4U
390
391#define IOMUXC_GPIO_EMC_B1_25_GPIO7_IO25 0x400E8074U, 0xAU, 0, 0, 0x400E82B8U
392#define IOMUXC_GPIO_EMC_B1_25_SEMC_RAS 0x400E8074U, 0x0U, 0, 0, 0x400E82B8U
393#define IOMUXC_GPIO_EMC_B1_25_FLEXPWM1_PWM1_A 0x400E8074U, 0x1U, 0x400E8504U, 0x0U, 0x400E82B8U
394#define IOMUXC_GPIO_EMC_B1_25_GPIO_MUX1_IO25 0x400E8074U, 0x5U, 0, 0, 0x400E82B8U
395#define IOMUXC_GPIO_EMC_B1_25_FLEXIO1_D25 0x400E8074U, 0x8U, 0, 0, 0x400E82B8U
396
397#define IOMUXC_GPIO_EMC_B1_26_SEMC_CLK 0x400E8078U, 0x0U, 0, 0, 0x400E82BCU
398#define IOMUXC_GPIO_EMC_B1_26_FLEXPWM1_PWM1_B 0x400E8078U, 0x1U, 0x400E8510U, 0x0U, 0x400E82BCU
399#define IOMUXC_GPIO_EMC_B1_26_GPIO_MUX1_IO26 0x400E8078U, 0x5U, 0, 0, 0x400E82BCU
400#define IOMUXC_GPIO_EMC_B1_26_FLEXIO1_D26 0x400E8078U, 0x8U, 0, 0, 0x400E82BCU
401#define IOMUXC_GPIO_EMC_B1_26_GPIO7_IO26 0x400E8078U, 0xAU, 0, 0, 0x400E82BCU
402
403#define IOMUXC_GPIO_EMC_B1_27_GPIO7_IO27 0x400E807CU, 0xAU, 0, 0, 0x400E82C0U
404#define IOMUXC_GPIO_EMC_B1_27_SEMC_CKE 0x400E807CU, 0x0U, 0, 0, 0x400E82C0U
405#define IOMUXC_GPIO_EMC_B1_27_FLEXPWM1_PWM2_A 0x400E807CU, 0x1U, 0x400E8508U, 0x0U, 0x400E82C0U
406#define IOMUXC_GPIO_EMC_B1_27_GPIO_MUX1_IO27 0x400E807CU, 0x5U, 0, 0, 0x400E82C0U
407#define IOMUXC_GPIO_EMC_B1_27_FLEXIO1_D27 0x400E807CU, 0x8U, 0, 0, 0x400E82C0U
408
409#define IOMUXC_GPIO_EMC_B1_28_GPIO7_IO28 0x400E8080U, 0xAU, 0, 0, 0x400E82C4U
410#define IOMUXC_GPIO_EMC_B1_28_SEMC_WE 0x400E8080U, 0x0U, 0, 0, 0x400E82C4U
411#define IOMUXC_GPIO_EMC_B1_28_FLEXPWM1_PWM2_B 0x400E8080U, 0x1U, 0x400E8514U, 0x0U, 0x400E82C4U
412#define IOMUXC_GPIO_EMC_B1_28_GPIO_MUX1_IO28 0x400E8080U, 0x5U, 0, 0, 0x400E82C4U
413#define IOMUXC_GPIO_EMC_B1_28_FLEXIO1_D28 0x400E8080U, 0x8U, 0, 0, 0x400E82C4U
414
415#define IOMUXC_GPIO_EMC_B1_29_SEMC_CS0 0x400E8084U, 0x0U, 0, 0, 0x400E82C8U
416#define IOMUXC_GPIO_EMC_B1_29_FLEXPWM3_PWM0_A 0x400E8084U, 0x1U, 0x400E8530U, 0x0U, 0x400E82C8U
417#define IOMUXC_GPIO_EMC_B1_29_GPIO_MUX1_IO29 0x400E8084U, 0x5U, 0, 0, 0x400E82C8U
418#define IOMUXC_GPIO_EMC_B1_29_FLEXIO1_D29 0x400E8084U, 0x8U, 0, 0, 0x400E82C8U
419#define IOMUXC_GPIO_EMC_B1_29_GPIO7_IO29 0x400E8084U, 0xAU, 0, 0, 0x400E82C8U
420
421#define IOMUXC_GPIO_EMC_B1_30_SEMC_DATA08 0x400E8088U, 0x0U, 0, 0, 0x400E82CCU
422#define IOMUXC_GPIO_EMC_B1_30_FLEXPWM3_PWM0_B 0x400E8088U, 0x1U, 0x400E8540U, 0x0U, 0x400E82CCU
423#define IOMUXC_GPIO_EMC_B1_30_GPIO_MUX1_IO30 0x400E8088U, 0x5U, 0, 0, 0x400E82CCU
424#define IOMUXC_GPIO_EMC_B1_30_FLEXIO1_D30 0x400E8088U, 0x8U, 0, 0, 0x400E82CCU
425#define IOMUXC_GPIO_EMC_B1_30_GPIO7_IO30 0x400E8088U, 0xAU, 0, 0, 0x400E82CCU
426
427#define IOMUXC_GPIO_EMC_B1_31_GPIO7_IO31 0x400E808CU, 0xAU, 0, 0, 0x400E82D0U
428#define IOMUXC_GPIO_EMC_B1_31_SEMC_DATA09 0x400E808CU, 0x0U, 0, 0, 0x400E82D0U
429#define IOMUXC_GPIO_EMC_B1_31_FLEXPWM3_PWM1_A 0x400E808CU, 0x1U, 0x400E8534U, 0x0U, 0x400E82D0U
430#define IOMUXC_GPIO_EMC_B1_31_GPIO_MUX1_IO31 0x400E808CU, 0x5U, 0, 0, 0x400E82D0U
431#define IOMUXC_GPIO_EMC_B1_31_FLEXIO1_D31 0x400E808CU, 0x8U, 0, 0, 0x400E82D0U
432
433#define IOMUXC_GPIO_EMC_B1_32_GPIO8_IO00 0x400E8090U, 0xAU, 0, 0, 0x400E82D4U
434#define IOMUXC_GPIO_EMC_B1_32_SEMC_DATA10 0x400E8090U, 0x0U, 0, 0, 0x400E82D4U
435#define IOMUXC_GPIO_EMC_B1_32_FLEXPWM3_PWM1_B 0x400E8090U, 0x1U, 0x400E8544U, 0x0U, 0x400E82D4U
436#define IOMUXC_GPIO_EMC_B1_32_GPIO_MUX2_IO00 0x400E8090U, 0x5U, 0, 0, 0x400E82D4U
437
438#define IOMUXC_GPIO_EMC_B1_33_SEMC_DATA11 0x400E8094U, 0x0U, 0, 0, 0x400E82D8U
439#define IOMUXC_GPIO_EMC_B1_33_FLEXPWM3_PWM2_A 0x400E8094U, 0x1U, 0x400E8538U, 0x0U, 0x400E82D8U
440#define IOMUXC_GPIO_EMC_B1_33_GPIO_MUX2_IO01 0x400E8094U, 0x5U, 0, 0, 0x400E82D8U
441#define IOMUXC_GPIO_EMC_B1_33_GPIO8_IO01 0x400E8094U, 0xAU, 0, 0, 0x400E82D8U
442
443#define IOMUXC_GPIO_EMC_B1_34_GPIO8_IO02 0x400E8098U, 0xAU, 0, 0, 0x400E82DCU
444#define IOMUXC_GPIO_EMC_B1_34_SEMC_DATA12 0x400E8098U, 0x0U, 0, 0, 0x400E82DCU
445#define IOMUXC_GPIO_EMC_B1_34_FLEXPWM3_PWM2_B 0x400E8098U, 0x1U, 0x400E8548U, 0x0U, 0x400E82DCU
446#define IOMUXC_GPIO_EMC_B1_34_GPIO_MUX2_IO02 0x400E8098U, 0x5U, 0, 0, 0x400E82DCU
447
448#define IOMUXC_GPIO_EMC_B1_35_GPIO8_IO03 0x400E809CU, 0xAU, 0, 0, 0x400E82E0U
449#define IOMUXC_GPIO_EMC_B1_35_SEMC_DATA13 0x400E809CU, 0x0U, 0, 0, 0x400E82E0U
450#define IOMUXC_GPIO_EMC_B1_35_XBAR1_INOUT09 0x400E809CU, 0x1U, 0, 0, 0x400E82E0U
451#define IOMUXC_GPIO_EMC_B1_35_GPIO_MUX2_IO03 0x400E809CU, 0x5U, 0, 0, 0x400E82E0U
452
453#define IOMUXC_GPIO_EMC_B1_36_SEMC_DATA14 0x400E80A0U, 0x0U, 0, 0, 0x400E82E4U
454#define IOMUXC_GPIO_EMC_B1_36_XBAR1_INOUT10 0x400E80A0U, 0x1U, 0, 0, 0x400E82E4U
455#define IOMUXC_GPIO_EMC_B1_36_GPIO_MUX2_IO04 0x400E80A0U, 0x5U, 0, 0, 0x400E82E4U
456#define IOMUXC_GPIO_EMC_B1_36_GPIO8_IO04 0x400E80A0U, 0xAU, 0, 0, 0x400E82E4U
457
458#define IOMUXC_GPIO_EMC_B1_37_GPIO8_IO05 0x400E80A4U, 0xAU, 0, 0, 0x400E82E8U
459#define IOMUXC_GPIO_EMC_B1_37_SEMC_DATA15 0x400E80A4U, 0x0U, 0, 0, 0x400E82E8U
460#define IOMUXC_GPIO_EMC_B1_37_XBAR1_INOUT11 0x400E80A4U, 0x1U, 0, 0, 0x400E82E8U
461#define IOMUXC_GPIO_EMC_B1_37_GPIO_MUX2_IO05 0x400E80A4U, 0x5U, 0, 0, 0x400E82E8U
462
463#define IOMUXC_GPIO_EMC_B1_38_GPIO8_IO06 0x400E80A8U, 0xAU, 0, 0, 0x400E82ECU
464#define IOMUXC_GPIO_EMC_B1_38_SEMC_DM01 0x400E80A8U, 0x0U, 0, 0, 0x400E82ECU
465#define IOMUXC_GPIO_EMC_B1_38_FLEXPWM1_PWM3_A 0x400E80A8U, 0x1U, 0, 0, 0x400E82ECU
466#define IOMUXC_GPIO_EMC_B1_38_TMR1_TIMER1 0x400E80A8U, 0x2U, 0x400E8640U, 0x0U, 0x400E82ECU
467#define IOMUXC_GPIO_EMC_B1_38_GPIO_MUX2_IO06 0x400E80A8U, 0x5U, 0, 0, 0x400E82ECU
468
469#define IOMUXC_GPIO_EMC_B1_39_SEMC_DQS 0x400E80ACU, 0x0U, 0, 0, 0x400E82F0U
470#define IOMUXC_GPIO_EMC_B1_39_FLEXPWM1_PWM3_B 0x400E80ACU, 0x1U, 0, 0, 0x400E82F0U
471#define IOMUXC_GPIO_EMC_B1_39_TMR2_TIMER1 0x400E80ACU, 0x2U, 0x400E864CU, 0x0U, 0x400E82F0U
472#define IOMUXC_GPIO_EMC_B1_39_GPIO_MUX2_IO07 0x400E80ACU, 0x5U, 0, 0, 0x400E82F0U
473#define IOMUXC_GPIO_EMC_B1_39_GPIO8_IO07 0x400E80ACU, 0xAU, 0, 0, 0x400E82F0U
474
475#define IOMUXC_GPIO_EMC_B1_40_SEMC_RDY 0x400E80B0U, 0x0U, 0, 0, 0x400E82F4U
476#define IOMUXC_GPIO_EMC_B1_40_XBAR1_INOUT12 0x400E80B0U, 0x1U, 0, 0, 0x400E82F4U
477#define IOMUXC_GPIO_EMC_B1_40_MQS_RIGHT 0x400E80B0U, 0x2U, 0, 0, 0x400E82F4U
478#define IOMUXC_GPIO_EMC_B1_40_LPUART6_TXD 0x400E80B0U, 0x3U, 0, 0, 0x400E82F4U
479#define IOMUXC_GPIO_EMC_B1_40_GPIO_MUX2_IO08 0x400E80B0U, 0x5U, 0, 0, 0x400E82F4U
480#define IOMUXC_GPIO_EMC_B1_40_ENET_1G_MDC 0x400E80B0U, 0x7U, 0, 0, 0x400E82F4U
481#define IOMUXC_GPIO_EMC_B1_40_CCM_CLKO1 0x400E80B0U, 0x9U, 0, 0, 0x400E82F4U
482#define IOMUXC_GPIO_EMC_B1_40_GPIO8_IO08 0x400E80B0U, 0xAU, 0, 0, 0x400E82F4U
483
484#define IOMUXC_GPIO_EMC_B1_41_GPIO8_IO09 0x400E80B4U, 0xAU, 0, 0, 0x400E82F8U
485#define IOMUXC_GPIO_EMC_B1_41_SEMC_CSX00 0x400E80B4U, 0x0U, 0, 0, 0x400E82F8U
486#define IOMUXC_GPIO_EMC_B1_41_XBAR1_INOUT13 0x400E80B4U, 0x1U, 0, 0, 0x400E82F8U
487#define IOMUXC_GPIO_EMC_B1_41_MQS_LEFT 0x400E80B4U, 0x2U, 0, 0, 0x400E82F8U
488#define IOMUXC_GPIO_EMC_B1_41_LPUART6_RXD 0x400E80B4U, 0x3U, 0, 0, 0x400E82F8U
489#define IOMUXC_GPIO_EMC_B1_41_FLEXSPI2_B_DATA07 0x400E80B4U, 0x4U, 0, 0, 0x400E82F8U
490#define IOMUXC_GPIO_EMC_B1_41_GPIO_MUX2_IO09 0x400E80B4U, 0x5U, 0, 0, 0x400E82F8U
491#define IOMUXC_GPIO_EMC_B1_41_ENET_1G_MDIO 0x400E80B4U, 0x7U, 0x400E84C8U, 0x0U, 0x400E82F8U
492#define IOMUXC_GPIO_EMC_B1_41_CCM_CLKO2 0x400E80B4U, 0x9U, 0, 0, 0x400E82F8U
493
494#define IOMUXC_GPIO_EMC_B2_00_SEMC_DATA16 0x400E80B8U, 0x0U, 0, 0, 0x400E82FCU
495#define IOMUXC_GPIO_EMC_B2_00_CCM_ENET_REF_CLK_25M 0x400E80B8U, 0x1U, 0, 0, 0x400E82FCU
496#define IOMUXC_GPIO_EMC_B2_00_TMR3_TIMER1 0x400E80B8U, 0x2U, 0x400E8658U, 0x0U, 0x400E82FCU
497#define IOMUXC_GPIO_EMC_B2_00_LPUART6_CTS_B 0x400E80B8U, 0x3U, 0, 0, 0x400E82FCU
498#define IOMUXC_GPIO_EMC_B2_00_FLEXSPI2_B_DATA06 0x400E80B8U, 0x4U, 0, 0, 0x400E82FCU
499#define IOMUXC_GPIO_EMC_B2_00_GPIO_MUX2_IO10 0x400E80B8U, 0x5U, 0, 0, 0x400E82FCU
500#define IOMUXC_GPIO_EMC_B2_00_XBAR1_INOUT20 0x400E80B8U, 0x6U, 0x400E86D8U, 0x0U, 0x400E82FCU
501#define IOMUXC_GPIO_EMC_B2_00_ENET_QOS_1588_EVENT1_OUT 0x400E80B8U, 0x7U, 0, 0, 0x400E82FCU
502#define IOMUXC_GPIO_EMC_B2_00_LPSPI1_SCK 0x400E80B8U, 0x8U, 0x400E85D0U, 0x0U, 0x400E82FCU
503#define IOMUXC_GPIO_EMC_B2_00_LPI2C2_SCL 0x400E80B8U, 0x9U, 0x400E85B4U, 0x0U, 0x400E82FCU
504#define IOMUXC_GPIO_EMC_B2_00_GPIO8_IO10 0x400E80B8U, 0xAU, 0, 0, 0x400E82FCU
505#define IOMUXC_GPIO_EMC_B2_00_FLEXPWM3_PWM0_A 0x400E80B8U, 0xBU, 0x400E8530U, 0x1U, 0x400E82FCU
506
507#define IOMUXC_GPIO_EMC_B2_01_SEMC_DATA17 0x400E80BCU, 0x0U, 0, 0, 0x400E8300U
508#define IOMUXC_GPIO_EMC_B2_01_USDHC2_CD_B 0x400E80BCU, 0x1U, 0x400E86D0U, 0x0U, 0x400E8300U
509#define IOMUXC_GPIO_EMC_B2_01_TMR4_TIMER1 0x400E80BCU, 0x2U, 0x400E8664U, 0x0U, 0x400E8300U
510#define IOMUXC_GPIO_EMC_B2_01_LPUART6_RTS_B 0x400E80BCU, 0x3U, 0, 0, 0x400E8300U
511#define IOMUXC_GPIO_EMC_B2_01_FLEXSPI2_B_DATA05 0x400E80BCU, 0x4U, 0, 0, 0x400E8300U
512#define IOMUXC_GPIO_EMC_B2_01_GPIO_MUX2_IO11 0x400E80BCU, 0x5U, 0, 0, 0x400E8300U
513#define IOMUXC_GPIO_EMC_B2_01_XBAR1_INOUT21 0x400E80BCU, 0x6U, 0x400E86DCU, 0x0U, 0x400E8300U
514#define IOMUXC_GPIO_EMC_B2_01_ENET_QOS_1588_EVENT1_IN 0x400E80BCU, 0x7U, 0, 0, 0x400E8300U
515#define IOMUXC_GPIO_EMC_B2_01_LPSPI1_PCS0 0x400E80BCU, 0x8U, 0x400E85CCU, 0x0U, 0x400E8300U
516#define IOMUXC_GPIO_EMC_B2_01_LPI2C2_SDA 0x400E80BCU, 0x9U, 0x400E85B8U, 0x0U, 0x400E8300U
517#define IOMUXC_GPIO_EMC_B2_01_GPIO8_IO11 0x400E80BCU, 0xAU, 0, 0, 0x400E8300U
518#define IOMUXC_GPIO_EMC_B2_01_FLEXPWM3_PWM0_B 0x400E80BCU, 0xBU, 0x400E8540U, 0x1U, 0x400E8300U
519
520#define IOMUXC_GPIO_EMC_B2_02_SEMC_DATA18 0x400E80C0U, 0x0U, 0, 0, 0x400E8304U
521#define IOMUXC_GPIO_EMC_B2_02_USDHC2_WP 0x400E80C0U, 0x1U, 0x400E86D4U, 0x0U, 0x400E8304U
522#define IOMUXC_GPIO_EMC_B2_02_VIDEO_MUX_CSI_DATA23 0x400E80C0U, 0x3U, 0, 0, 0x400E8304U
523#define IOMUXC_GPIO_EMC_B2_02_FLEXSPI2_B_DATA04 0x400E80C0U, 0x4U, 0, 0, 0x400E8304U
524#define IOMUXC_GPIO_EMC_B2_02_GPIO_MUX2_IO12 0x400E80C0U, 0x5U, 0, 0, 0x400E8304U
525#define IOMUXC_GPIO_EMC_B2_02_XBAR1_INOUT22 0x400E80C0U, 0x6U, 0x400E86E0U, 0x0U, 0x400E8304U
526#define IOMUXC_GPIO_EMC_B2_02_ENET_QOS_1588_EVENT1_AUX_IN 0x400E80C0U, 0x7U, 0, 0, 0x400E8304U
527#define IOMUXC_GPIO_EMC_B2_02_LPSPI1_SOUT 0x400E80C0U, 0x8U, 0x400E85D8U, 0x0U, 0x400E8304U
528#define IOMUXC_GPIO_EMC_B2_02_GPIO8_IO12 0x400E80C0U, 0xAU, 0, 0, 0x400E8304U
529#define IOMUXC_GPIO_EMC_B2_02_FLEXPWM3_PWM1_A 0x400E80C0U, 0xBU, 0x400E8534U, 0x1U, 0x400E8304U
530
531#define IOMUXC_GPIO_EMC_B2_03_SEMC_DATA19 0x400E80C4U, 0x0U, 0, 0, 0x400E8308U
532#define IOMUXC_GPIO_EMC_B2_03_USDHC2_VSELECT 0x400E80C4U, 0x1U, 0, 0, 0x400E8308U
533#define IOMUXC_GPIO_EMC_B2_03_VIDEO_MUX_CSI_DATA22 0x400E80C4U, 0x3U, 0, 0, 0x400E8308U
534#define IOMUXC_GPIO_EMC_B2_03_FLEXSPI2_B_DATA03 0x400E80C4U, 0x4U, 0, 0, 0x400E8308U
535#define IOMUXC_GPIO_EMC_B2_03_GPIO_MUX2_IO13 0x400E80C4U, 0x5U, 0, 0, 0x400E8308U
536#define IOMUXC_GPIO_EMC_B2_03_XBAR1_INOUT23 0x400E80C4U, 0x6U, 0x400E86E4U, 0x0U, 0x400E8308U
537#define IOMUXC_GPIO_EMC_B2_03_ENET_1G_TX_DATA03 0x400E80C4U, 0x7U, 0, 0, 0x400E8308U
538#define IOMUXC_GPIO_EMC_B2_03_LPSPI1_SIN 0x400E80C4U, 0x8U, 0x400E85D4U, 0x0U, 0x400E8308U
539#define IOMUXC_GPIO_EMC_B2_03_GPIO8_IO13 0x400E80C4U, 0xAU, 0, 0, 0x400E8308U
540#define IOMUXC_GPIO_EMC_B2_03_FLEXPWM3_PWM1_B 0x400E80C4U, 0xBU, 0x400E8544U, 0x1U, 0x400E8308U
541
542#define IOMUXC_GPIO_EMC_B2_04_SEMC_DATA20 0x400E80C8U, 0x0U, 0, 0, 0x400E830CU
543#define IOMUXC_GPIO_EMC_B2_04_USDHC2_RESET_B 0x400E80C8U, 0x1U, 0, 0, 0x400E830CU
544#define IOMUXC_GPIO_EMC_B2_04_SAI2_MCLK 0x400E80C8U, 0x2U, 0, 0, 0x400E830CU
545#define IOMUXC_GPIO_EMC_B2_04_VIDEO_MUX_CSI_DATA21 0x400E80C8U, 0x3U, 0, 0, 0x400E830CU
546#define IOMUXC_GPIO_EMC_B2_04_FLEXSPI2_B_DATA02 0x400E80C8U, 0x4U, 0, 0, 0x400E830CU
547#define IOMUXC_GPIO_EMC_B2_04_GPIO_MUX2_IO14 0x400E80C8U, 0x5U, 0, 0, 0x400E830CU
548#define IOMUXC_GPIO_EMC_B2_04_XBAR1_INOUT24 0x400E80C8U, 0x6U, 0x400E86E8U, 0x0U, 0x400E830CU
549#define IOMUXC_GPIO_EMC_B2_04_ENET_1G_TX_DATA02 0x400E80C8U, 0x7U, 0, 0, 0x400E830CU
550#define IOMUXC_GPIO_EMC_B2_04_LPSPI3_SCK 0x400E80C8U, 0x8U, 0x400E8600U, 0x0U, 0x400E830CU
551#define IOMUXC_GPIO_EMC_B2_04_GPIO8_IO14 0x400E80C8U, 0xAU, 0, 0, 0x400E830CU
552#define IOMUXC_GPIO_EMC_B2_04_FLEXPWM3_PWM2_A 0x400E80C8U, 0xBU, 0x400E8538U, 0x1U, 0x400E830CU
553
554#define IOMUXC_GPIO_EMC_B2_05_SEMC_DATA21 0x400E80CCU, 0x0U, 0, 0, 0x400E8310U
555#define IOMUXC_GPIO_EMC_B2_05_GPT3_CLK 0x400E80CCU, 0x1U, 0x400E8598U, 0x0U, 0x400E8310U
556#define IOMUXC_GPIO_EMC_B2_05_SAI2_RX_SYNC 0x400E80CCU, 0x2U, 0, 0, 0x400E8310U
557#define IOMUXC_GPIO_EMC_B2_05_VIDEO_MUX_CSI_DATA20 0x400E80CCU, 0x3U, 0, 0, 0x400E8310U
558#define IOMUXC_GPIO_EMC_B2_05_FLEXSPI2_B_DATA01 0x400E80CCU, 0x4U, 0, 0, 0x400E8310U
559#define IOMUXC_GPIO_EMC_B2_05_GPIO_MUX2_IO15 0x400E80CCU, 0x5U, 0, 0, 0x400E8310U
560#define IOMUXC_GPIO_EMC_B2_05_XBAR1_INOUT25 0x400E80CCU, 0x6U, 0x400E86ECU, 0x0U, 0x400E8310U
561#define IOMUXC_GPIO_EMC_B2_05_ENET_1G_RX_CLK 0x400E80CCU, 0x7U, 0x400E84CCU, 0x0U, 0x400E8310U
562#define IOMUXC_GPIO_EMC_B2_05_LPSPI3_PCS0 0x400E80CCU, 0x8U, 0x400E85F0U, 0x0U, 0x400E8310U
563#define IOMUXC_GPIO_EMC_B2_05_PIT1_TRIGGER0 0x400E80CCU, 0x9U, 0, 0, 0x400E8310U
564#define IOMUXC_GPIO_EMC_B2_05_GPIO8_IO15 0x400E80CCU, 0xAU, 0, 0, 0x400E8310U
565#define IOMUXC_GPIO_EMC_B2_05_FLEXPWM3_PWM2_B 0x400E80CCU, 0xBU, 0x400E8548U, 0x1U, 0x400E8310U
566
567#define IOMUXC_GPIO_EMC_B2_06_SEMC_DATA22 0x400E80D0U, 0x0U, 0, 0, 0x400E8314U
568#define IOMUXC_GPIO_EMC_B2_06_GPT3_CAPTURE1 0x400E80D0U, 0x1U, 0x400E8590U, 0x0U, 0x400E8314U
569#define IOMUXC_GPIO_EMC_B2_06_GPIO8_IO16 0x400E80D0U, 0xAU, 0, 0, 0x400E8314U
570#define IOMUXC_GPIO_EMC_B2_06_SAI2_RX_BCLK 0x400E80D0U, 0x2U, 0, 0, 0x400E8314U
571#define IOMUXC_GPIO_EMC_B2_06_FLEXPWM3_PWM3_A 0x400E80D0U, 0xBU, 0x400E853CU, 0x1U, 0x400E8314U
572#define IOMUXC_GPIO_EMC_B2_06_VIDEO_MUX_CSI_DATA19 0x400E80D0U, 0x3U, 0, 0, 0x400E8314U
573#define IOMUXC_GPIO_EMC_B2_06_FLEXSPI2_B_DATA00 0x400E80D0U, 0x4U, 0, 0, 0x400E8314U
574#define IOMUXC_GPIO_EMC_B2_06_GPIO_MUX2_IO16 0x400E80D0U, 0x5U, 0, 0, 0x400E8314U
575#define IOMUXC_GPIO_EMC_B2_06_XBAR1_INOUT26 0x400E80D0U, 0x6U, 0x400E86F0U, 0x0U, 0x400E8314U
576#define IOMUXC_GPIO_EMC_B2_06_ENET_1G_TX_ER 0x400E80D0U, 0x7U, 0, 0, 0x400E8314U
577#define IOMUXC_GPIO_EMC_B2_06_LPSPI3_SOUT 0x400E80D0U, 0x8U, 0x400E8608U, 0x0U, 0x400E8314U
578#define IOMUXC_GPIO_EMC_B2_06_PIT1_TRIGGER1 0x400E80D0U, 0x9U, 0, 0, 0x400E8314U
579
580#define IOMUXC_GPIO_EMC_B2_07_SEMC_DATA23 0x400E80D4U, 0x0U, 0, 0, 0x400E8318U
581#define IOMUXC_GPIO_EMC_B2_07_GPT3_CAPTURE2 0x400E80D4U, 0x1U, 0x400E8594U, 0x0U, 0x400E8318U
582#define IOMUXC_GPIO_EMC_B2_07_SAI2_RX_DATA 0x400E80D4U, 0x2U, 0, 0, 0x400E8318U
583#define IOMUXC_GPIO_EMC_B2_07_VIDEO_MUX_CSI_DATA18 0x400E80D4U, 0x3U, 0, 0, 0x400E8318U
584#define IOMUXC_GPIO_EMC_B2_07_FLEXSPI2_B_DQS 0x400E80D4U, 0x4U, 0, 0, 0x400E8318U
585#define IOMUXC_GPIO_EMC_B2_07_GPIO_MUX2_IO17 0x400E80D4U, 0x5U, 0, 0, 0x400E8318U
586#define IOMUXC_GPIO_EMC_B2_07_XBAR1_INOUT27 0x400E80D4U, 0x6U, 0x400E86F4U, 0x0U, 0x400E8318U
587#define IOMUXC_GPIO_EMC_B2_07_ENET_1G_RX_DATA03 0x400E80D4U, 0x7U, 0x400E84DCU, 0x0U, 0x400E8318U
588#define IOMUXC_GPIO_EMC_B2_07_LPSPI3_SIN 0x400E80D4U, 0x8U, 0x400E8604U, 0x0U, 0x400E8318U
589#define IOMUXC_GPIO_EMC_B2_07_PIT1_TRIGGER2 0x400E80D4U, 0x9U, 0, 0, 0x400E8318U
590#define IOMUXC_GPIO_EMC_B2_07_GPIO8_IO17 0x400E80D4U, 0xAU, 0, 0, 0x400E8318U
591#define IOMUXC_GPIO_EMC_B2_07_FLEXPWM3_PWM3_B 0x400E80D4U, 0xBU, 0x400E854CU, 0x1U, 0x400E8318U
592
593#define IOMUXC_GPIO_EMC_B2_08_SEMC_DM02 0x400E80D8U, 0x0U, 0, 0, 0x400E831CU
594#define IOMUXC_GPIO_EMC_B2_08_GPT3_COMPARE1 0x400E80D8U, 0x1U, 0, 0, 0x400E831CU
595#define IOMUXC_GPIO_EMC_B2_08_SAI2_TX_DATA 0x400E80D8U, 0x2U, 0, 0, 0x400E831CU
596#define IOMUXC_GPIO_EMC_B2_08_VIDEO_MUX_CSI_DATA17 0x400E80D8U, 0x3U, 0, 0, 0x400E831CU
597#define IOMUXC_GPIO_EMC_B2_08_FLEXSPI2_B_SS0_B 0x400E80D8U, 0x4U, 0, 0, 0x400E831CU
598#define IOMUXC_GPIO_EMC_B2_08_GPIO_MUX2_IO18 0x400E80D8U, 0x5U, 0, 0, 0x400E831CU
599#define IOMUXC_GPIO_EMC_B2_08_XBAR1_INOUT28 0x400E80D8U, 0x6U, 0x400E86F8U, 0x0U, 0x400E831CU
600#define IOMUXC_GPIO_EMC_B2_08_ENET_1G_RX_DATA02 0x400E80D8U, 0x7U, 0x400E84D8U, 0x0U, 0x400E831CU
601#define IOMUXC_GPIO_EMC_B2_08_LPSPI3_PCS1 0x400E80D8U, 0x8U, 0x400E85F4U, 0x0U, 0x400E831CU
602#define IOMUXC_GPIO_EMC_B2_08_PIT1_TRIGGER3 0x400E80D8U, 0x9U, 0, 0, 0x400E831CU
603#define IOMUXC_GPIO_EMC_B2_08_GPIO8_IO18 0x400E80D8U, 0xAU, 0, 0, 0x400E831CU
604
605#define IOMUXC_GPIO_EMC_B2_09_GPIO8_IO19 0x400E80DCU, 0xAU, 0, 0, 0x400E8320U
606#define IOMUXC_GPIO_EMC_B2_09_SEMC_DATA24 0x400E80DCU, 0x0U, 0, 0, 0x400E8320U
607#define IOMUXC_GPIO_EMC_B2_09_GPT3_COMPARE2 0x400E80DCU, 0x1U, 0, 0, 0x400E8320U
608#define IOMUXC_GPIO_EMC_B2_09_SAI2_TX_BCLK 0x400E80DCU, 0x2U, 0, 0, 0x400E8320U
609#define IOMUXC_GPIO_EMC_B2_09_VIDEO_MUX_CSI_DATA16 0x400E80DCU, 0x3U, 0, 0, 0x400E8320U
610#define IOMUXC_GPIO_EMC_B2_09_FLEXSPI2_B_SCLK 0x400E80DCU, 0x4U, 0, 0, 0x400E8320U
611#define IOMUXC_GPIO_EMC_B2_09_GPIO_MUX2_IO19 0x400E80DCU, 0x5U, 0, 0, 0x400E8320U
612#define IOMUXC_GPIO_EMC_B2_09_XBAR1_INOUT29 0x400E80DCU, 0x6U, 0x400E86FCU, 0x0U, 0x400E8320U
613#define IOMUXC_GPIO_EMC_B2_09_ENET_1G_CRS 0x400E80DCU, 0x7U, 0, 0, 0x400E8320U
614#define IOMUXC_GPIO_EMC_B2_09_LPSPI3_PCS2 0x400E80DCU, 0x8U, 0x400E85F8U, 0x0U, 0x400E8320U
615#define IOMUXC_GPIO_EMC_B2_09_TMR1_TIMER0 0x400E80DCU, 0x9U, 0x400E863CU, 0x1U, 0x400E8320U
616
617#define IOMUXC_GPIO_EMC_B2_10_GPIO8_IO20 0x400E80E0U, 0xAU, 0, 0, 0x400E8324U
618#define IOMUXC_GPIO_EMC_B2_10_SEMC_DATA25 0x400E80E0U, 0x0U, 0, 0, 0x400E8324U
619#define IOMUXC_GPIO_EMC_B2_10_GPT3_COMPARE3 0x400E80E0U, 0x1U, 0, 0, 0x400E8324U
620#define IOMUXC_GPIO_EMC_B2_10_SAI2_TX_SYNC 0x400E80E0U, 0x2U, 0, 0, 0x400E8324U
621#define IOMUXC_GPIO_EMC_B2_10_VIDEO_MUX_CSI_FIELD 0x400E80E0U, 0x3U, 0, 0, 0x400E8324U
622#define IOMUXC_GPIO_EMC_B2_10_FLEXSPI2_A_SCLK 0x400E80E0U, 0x4U, 0x400E858CU, 0x0U, 0x400E8324U
623#define IOMUXC_GPIO_EMC_B2_10_GPIO_MUX2_IO20 0x400E80E0U, 0x5U, 0, 0, 0x400E8324U
624#define IOMUXC_GPIO_EMC_B2_10_XBAR1_INOUT30 0x400E80E0U, 0x6U, 0x400E8700U, 0x0U, 0x400E8324U
625#define IOMUXC_GPIO_EMC_B2_10_ENET_1G_COL 0x400E80E0U, 0x7U, 0, 0, 0x400E8324U
626#define IOMUXC_GPIO_EMC_B2_10_LPSPI3_PCS3 0x400E80E0U, 0x8U, 0x400E85FCU, 0x0U, 0x400E8324U
627#define IOMUXC_GPIO_EMC_B2_10_TMR1_TIMER1 0x400E80E0U, 0x9U, 0x400E8640U, 0x1U, 0x400E8324U
628
629#define IOMUXC_GPIO_EMC_B2_11_SEMC_DATA26 0x400E80E4U, 0x0U, 0, 0, 0x400E8328U
630#define IOMUXC_GPIO_EMC_B2_11_SPDIF_IN 0x400E80E4U, 0x1U, 0x400E86B4U, 0x0U, 0x400E8328U
631#define IOMUXC_GPIO_EMC_B2_11_ENET_1G_TX_DATA00 0x400E80E4U, 0x2U, 0, 0, 0x400E8328U
632#define IOMUXC_GPIO_EMC_B2_11_SAI3_RX_SYNC 0x400E80E4U, 0x3U, 0, 0, 0x400E8328U
633#define IOMUXC_GPIO_EMC_B2_11_FLEXSPI2_A_SS0_B 0x400E80E4U, 0x4U, 0, 0, 0x400E8328U
634#define IOMUXC_GPIO_EMC_B2_11_GPIO_MUX2_IO21 0x400E80E4U, 0x5U, 0, 0, 0x400E8328U
635#define IOMUXC_GPIO_EMC_B2_11_XBAR1_INOUT31 0x400E80E4U, 0x6U, 0x400E8704U, 0x0U, 0x400E8328U
636#define IOMUXC_GPIO_EMC_B2_11_EMVSIM1_IO 0x400E80E4U, 0x8U, 0x400E869CU, 0x0U, 0x400E8328U
637#define IOMUXC_GPIO_EMC_B2_11_TMR1_TIMER2 0x400E80E4U, 0x9U, 0x400E8644U, 0x0U, 0x400E8328U
638#define IOMUXC_GPIO_EMC_B2_11_GPIO8_IO21 0x400E80E4U, 0xAU, 0, 0, 0x400E8328U
639
640#define IOMUXC_GPIO_EMC_B2_12_SEMC_DATA27 0x400E80E8U, 0x0U, 0, 0, 0x400E832CU
641#define IOMUXC_GPIO_EMC_B2_12_SPDIF_OUT 0x400E80E8U, 0x1U, 0, 0, 0x400E832CU
642#define IOMUXC_GPIO_EMC_B2_12_ENET_1G_TX_DATA01 0x400E80E8U, 0x2U, 0, 0, 0x400E832CU
643#define IOMUXC_GPIO_EMC_B2_12_SAI3_RX_BCLK 0x400E80E8U, 0x3U, 0, 0, 0x400E832CU
644#define IOMUXC_GPIO_EMC_B2_12_FLEXSPI2_A_DQS 0x400E80E8U, 0x4U, 0, 0, 0x400E832CU
645#define IOMUXC_GPIO_EMC_B2_12_GPIO_MUX2_IO22 0x400E80E8U, 0x5U, 0, 0, 0x400E832CU
646#define IOMUXC_GPIO_EMC_B2_12_XBAR1_INOUT32 0x400E80E8U, 0x6U, 0x400E8708U, 0x0U, 0x400E832CU
647#define IOMUXC_GPIO_EMC_B2_12_EMVSIM1_CLK 0x400E80E8U, 0x8U, 0, 0, 0x400E832CU
648#define IOMUXC_GPIO_EMC_B2_12_TMR1_TIMER3 0x400E80E8U, 0x9U, 0, 0, 0x400E832CU
649#define IOMUXC_GPIO_EMC_B2_12_GPIO8_IO22 0x400E80E8U, 0xAU, 0, 0, 0x400E832CU
650
651#define IOMUXC_GPIO_EMC_B2_13_GPIO8_IO23 0x400E80ECU, 0xAU, 0, 0, 0x400E8330U
652#define IOMUXC_GPIO_EMC_B2_13_SEMC_DATA28 0x400E80ECU, 0x0U, 0, 0, 0x400E8330U
653#define IOMUXC_GPIO_EMC_B2_13_ENET_1G_TX_EN 0x400E80ECU, 0x2U, 0, 0, 0x400E8330U
654#define IOMUXC_GPIO_EMC_B2_13_SAI3_RX_DATA 0x400E80ECU, 0x3U, 0, 0, 0x400E8330U
655#define IOMUXC_GPIO_EMC_B2_13_FLEXSPI2_A_DATA00 0x400E80ECU, 0x4U, 0x400E857CU, 0x0U, 0x400E8330U
656#define IOMUXC_GPIO_EMC_B2_13_GPIO_MUX2_IO23 0x400E80ECU, 0x5U, 0, 0, 0x400E8330U
657#define IOMUXC_GPIO_EMC_B2_13_XBAR1_INOUT33 0x400E80ECU, 0x6U, 0x400E870CU, 0x0U, 0x400E8330U
658#define IOMUXC_GPIO_EMC_B2_13_EMVSIM1_RST 0x400E80ECU, 0x8U, 0, 0, 0x400E8330U
659#define IOMUXC_GPIO_EMC_B2_13_TMR2_TIMER0 0x400E80ECU, 0x9U, 0x400E8648U, 0x1U, 0x400E8330U
660
661#define IOMUXC_GPIO_EMC_B2_14_SEMC_DATA29 0x400E80F0U, 0x0U, 0, 0, 0x400E8334U
662#define IOMUXC_GPIO_EMC_B2_14_ENET_1G_TX_CLK_IO 0x400E80F0U, 0x2U, 0x400E84E8U, 0x0U, 0x400E8334U
663#define IOMUXC_GPIO_EMC_B2_14_SAI3_TX_DATA 0x400E80F0U, 0x3U, 0, 0, 0x400E8334U
664#define IOMUXC_GPIO_EMC_B2_14_FLEXSPI2_A_DATA01 0x400E80F0U, 0x4U, 0x400E8580U, 0x0U, 0x400E8334U
665#define IOMUXC_GPIO_EMC_B2_14_GPIO_MUX2_IO24 0x400E80F0U, 0x5U, 0, 0, 0x400E8334U
666#define IOMUXC_GPIO_EMC_B2_14_XBAR1_INOUT34 0x400E80F0U, 0x6U, 0x400E8710U, 0x0U, 0x400E8334U
667#define IOMUXC_GPIO_EMC_B2_14_SFA_ipp_do_atx_clk_under_test 0x400E80F0U, 0x7U, 0, 0, 0x400E8334U
668#define IOMUXC_GPIO_EMC_B2_14_EMVSIM1_SVEN 0x400E80F0U, 0x8U, 0, 0, 0x400E8334U
669#define IOMUXC_GPIO_EMC_B2_14_TMR2_TIMER1 0x400E80F0U, 0x9U, 0x400E864CU, 0x1U, 0x400E8334U
670#define IOMUXC_GPIO_EMC_B2_14_GPIO8_IO24 0x400E80F0U, 0xAU, 0, 0, 0x400E8334U
671
672#define IOMUXC_GPIO_EMC_B2_15_SEMC_DATA30 0x400E80F4U, 0x0U, 0, 0, 0x400E8338U
673#define IOMUXC_GPIO_EMC_B2_15_ENET_1G_RX_DATA00 0x400E80F4U, 0x2U, 0x400E84D0U, 0x0U, 0x400E8338U
674#define IOMUXC_GPIO_EMC_B2_15_SAI3_TX_BCLK 0x400E80F4U, 0x3U, 0, 0, 0x400E8338U
675#define IOMUXC_GPIO_EMC_B2_15_FLEXSPI2_A_DATA02 0x400E80F4U, 0x4U, 0x400E8584U, 0x0U, 0x400E8338U
676#define IOMUXC_GPIO_EMC_B2_15_GPIO_MUX2_IO25 0x400E80F4U, 0x5U, 0, 0, 0x400E8338U
677#define IOMUXC_GPIO_EMC_B2_15_XBAR1_INOUT35 0x400E80F4U, 0x6U, 0x400E8714U, 0x0U, 0x400E8338U
678#define IOMUXC_GPIO_EMC_B2_15_EMVSIM1_PD 0x400E80F4U, 0x8U, 0x400E86A0U, 0x0U, 0x400E8338U
679#define IOMUXC_GPIO_EMC_B2_15_TMR2_TIMER2 0x400E80F4U, 0x9U, 0x400E8650U, 0x0U, 0x400E8338U
680#define IOMUXC_GPIO_EMC_B2_15_GPIO8_IO25 0x400E80F4U, 0xAU, 0, 0, 0x400E8338U
681
682#define IOMUXC_GPIO_EMC_B2_16_GPIO8_IO26 0x400E80F8U, 0xAU, 0, 0, 0x400E833CU
683#define IOMUXC_GPIO_EMC_B2_16_SEMC_DATA31 0x400E80F8U, 0x0U, 0, 0, 0x400E833CU
684#define IOMUXC_GPIO_EMC_B2_16_XBAR1_INOUT14 0x400E80F8U, 0x1U, 0, 0, 0x400E833CU
685#define IOMUXC_GPIO_EMC_B2_16_ENET_1G_RX_DATA01 0x400E80F8U, 0x2U, 0x400E84D4U, 0x0U, 0x400E833CU
686#define IOMUXC_GPIO_EMC_B2_16_SAI3_TX_SYNC 0x400E80F8U, 0x3U, 0, 0, 0x400E833CU
687#define IOMUXC_GPIO_EMC_B2_16_FLEXSPI2_A_DATA03 0x400E80F8U, 0x4U, 0x400E8588U, 0x0U, 0x400E833CU
688#define IOMUXC_GPIO_EMC_B2_16_GPIO_MUX2_IO26 0x400E80F8U, 0x5U, 0, 0, 0x400E833CU
689#define IOMUXC_GPIO_EMC_B2_16_EMVSIM1_POWER_FAIL 0x400E80F8U, 0x8U, 0x400E86A4U, 0x0U, 0x400E833CU
690#define IOMUXC_GPIO_EMC_B2_16_TMR2_TIMER3 0x400E80F8U, 0x9U, 0, 0, 0x400E833CU
691
692#define IOMUXC_GPIO_EMC_B2_17_SEMC_DM03 0x400E80FCU, 0x0U, 0, 0, 0x400E8340U
693#define IOMUXC_GPIO_EMC_B2_17_XBAR1_INOUT15 0x400E80FCU, 0x1U, 0, 0, 0x400E8340U
694#define IOMUXC_GPIO_EMC_B2_17_ENET_1G_RX_EN 0x400E80FCU, 0x2U, 0x400E84E0U, 0x0U, 0x400E8340U
695#define IOMUXC_GPIO_EMC_B2_17_SAI3_MCLK 0x400E80FCU, 0x3U, 0, 0, 0x400E8340U
696#define IOMUXC_GPIO_EMC_B2_17_FLEXSPI2_A_DATA04 0x400E80FCU, 0x4U, 0, 0, 0x400E8340U
697#define IOMUXC_GPIO_EMC_B2_17_GPIO_MUX2_IO27 0x400E80FCU, 0x5U, 0, 0, 0x400E8340U
698#define IOMUXC_GPIO_EMC_B2_17_WDOG1_ANY 0x400E80FCU, 0x8U, 0, 0, 0x400E8340U
699#define IOMUXC_GPIO_EMC_B2_17_TMR3_TIMER0 0x400E80FCU, 0x9U, 0x400E8654U, 0x1U, 0x400E8340U
700#define IOMUXC_GPIO_EMC_B2_17_GPIO8_IO27 0x400E80FCU, 0xAU, 0, 0, 0x400E8340U
701
702#define IOMUXC_GPIO_EMC_B2_18_SEMC_DQS4 0x400E8100U, 0x0U, 0, 0, 0x400E8344U
703#define IOMUXC_GPIO_EMC_B2_18_XBAR1_INOUT16 0x400E8100U, 0x1U, 0, 0, 0x400E8344U
704#define IOMUXC_GPIO_EMC_B2_18_ENET_1G_RX_ER 0x400E8100U, 0x2U, 0x400E84E4U, 0x0U, 0x400E8344U
705#define IOMUXC_GPIO_EMC_B2_18_EWM_OUT_B 0x400E8100U, 0x3U, 0, 0, 0x400E8344U
706#define IOMUXC_GPIO_EMC_B2_18_FLEXSPI2_A_DATA05 0x400E8100U, 0x4U, 0, 0, 0x400E8344U
707#define IOMUXC_GPIO_EMC_B2_18_GPIO_MUX2_IO28 0x400E8100U, 0x5U, 0, 0, 0x400E8344U
708#define IOMUXC_GPIO_EMC_B2_18_FLEXSPI1_A_DQS 0x400E8100U, 0x6U, 0x400E8550U, 0x0U, 0x400E8344U
709#define IOMUXC_GPIO_EMC_B2_18_WDOG1_B 0x400E8100U, 0x8U, 0, 0, 0x400E8344U
710#define IOMUXC_GPIO_EMC_B2_18_TMR3_TIMER1 0x400E8100U, 0x9U, 0x400E8658U, 0x1U, 0x400E8344U
711#define IOMUXC_GPIO_EMC_B2_18_GPIO8_IO28 0x400E8100U, 0xAU, 0, 0, 0x400E8344U
712
713#define IOMUXC_GPIO_EMC_B2_19_GPIO8_IO29 0x400E8104U, 0xAU, 0, 0, 0x400E8348U
714#define IOMUXC_GPIO_EMC_B2_19_SEMC_CLKX00 0x400E8104U, 0x0U, 0, 0, 0x400E8348U
715#define IOMUXC_GPIO_EMC_B2_19_ENET_MDC 0x400E8104U, 0x1U, 0, 0, 0x400E8348U
716#define IOMUXC_GPIO_EMC_B2_19_ENET_1G_MDC 0x400E8104U, 0x2U, 0, 0, 0x400E8348U
717#define IOMUXC_GPIO_EMC_B2_19_ENET_1G_REF_CLK 0x400E8104U, 0x3U, 0x400E84C4U, 0x0U, 0x400E8348U
718#define IOMUXC_GPIO_EMC_B2_19_FLEXSPI2_A_DATA06 0x400E8104U, 0x4U, 0, 0, 0x400E8348U
719#define IOMUXC_GPIO_EMC_B2_19_GPIO_MUX2_IO29 0x400E8104U, 0x5U, 0, 0, 0x400E8348U
720#define IOMUXC_GPIO_EMC_B2_19_ENET_QOS_MDC 0x400E8104U, 0x8U, 0, 0, 0x400E8348U
721#define IOMUXC_GPIO_EMC_B2_19_TMR3_TIMER2 0x400E8104U, 0x9U, 0x400E865CU, 0x0U, 0x400E8348U
722
723#define IOMUXC_GPIO_EMC_B2_20_GPIO8_IO30 0x400E8108U, 0xAU, 0, 0, 0x400E834CU
724#define IOMUXC_GPIO_EMC_B2_20_SEMC_CLKX01 0x400E8108U, 0x0U, 0, 0, 0x400E834CU
725#define IOMUXC_GPIO_EMC_B2_20_ENET_MDIO 0x400E8108U, 0x1U, 0x400E84ACU, 0x0U, 0x400E834CU
726#define IOMUXC_GPIO_EMC_B2_20_ENET_1G_MDIO 0x400E8108U, 0x2U, 0x400E84C8U, 0x1U, 0x400E834CU
727#define IOMUXC_GPIO_EMC_B2_20_ENET_QOS_REF_CLK 0x400E8108U, 0x3U, 0x400E84A0U, 0x0U, 0x400E834CU
728#define IOMUXC_GPIO_EMC_B2_20_FLEXSPI2_A_DATA07 0x400E8108U, 0x4U, 0, 0, 0x400E834CU
729#define IOMUXC_GPIO_EMC_B2_20_GPIO_MUX2_IO30 0x400E8108U, 0x5U, 0, 0, 0x400E834CU
730#define IOMUXC_GPIO_EMC_B2_20_ENET_QOS_MDIO 0x400E8108U, 0x8U, 0x400E84ECU, 0x0U, 0x400E834CU
731#define IOMUXC_GPIO_EMC_B2_20_TMR3_TIMER3 0x400E8108U, 0x9U, 0, 0, 0x400E834CU
732
733#define IOMUXC_GPIO_AD_00_GPIO8_IO31 0x400E810CU, 0xAU, 0, 0, 0x400E8350U
734#define IOMUXC_GPIO_AD_00_EMVSIM1_IO 0x400E810CU, 0x0U, 0x400E869CU, 0x1U, 0x400E8350U
735#define IOMUXC_GPIO_AD_00_FLEXCAN2_TX 0x400E810CU, 0x1U, 0, 0, 0x400E8350U
736#define IOMUXC_GPIO_AD_00_ENET_1G_1588_EVENT1_IN 0x400E810CU, 0x2U, 0, 0, 0x400E8350U
737#define IOMUXC_GPIO_AD_00_GPT2_CAPTURE1 0x400E810CU, 0x3U, 0, 0, 0x400E8350U
738#define IOMUXC_GPIO_AD_00_FLEXPWM1_PWM0_A 0x400E810CU, 0x4U, 0x400E8500U, 0x1U, 0x400E8350U
739#define IOMUXC_GPIO_AD_00_GPIO_MUX2_IO31 0x400E810CU, 0x5U, 0, 0, 0x400E8350U
740#define IOMUXC_GPIO_AD_00_LPUART7_TXD 0x400E810CU, 0x6U, 0x400E8630U, 0x0U, 0x400E8350U
741#define IOMUXC_GPIO_AD_00_FLEXIO2_D00 0x400E810CU, 0x8U, 0, 0, 0x400E8350U
742#define IOMUXC_GPIO_AD_00_FLEXSPI2_B_SS1_B 0x400E810CU, 0x9U, 0, 0, 0x400E8350U
743
744#define IOMUXC_GPIO_AD_01_GPIO9_IO00 0x400E8110U, 0xAU, 0, 0, 0x400E8354U
745#define IOMUXC_GPIO_AD_01_EMVSIM1_CLK 0x400E8110U, 0x0U, 0, 0, 0x400E8354U
746#define IOMUXC_GPIO_AD_01_FLEXCAN2_RX 0x400E8110U, 0x1U, 0x400E849CU, 0x0U, 0x400E8354U
747#define IOMUXC_GPIO_AD_01_ENET_1G_1588_EVENT1_OUT 0x400E8110U, 0x2U, 0, 0, 0x400E8354U
748#define IOMUXC_GPIO_AD_01_GPT2_CAPTURE2 0x400E8110U, 0x3U, 0, 0, 0x400E8354U
749#define IOMUXC_GPIO_AD_01_FLEXPWM1_PWM0_B 0x400E8110U, 0x4U, 0x400E850CU, 0x1U, 0x400E8354U
750#define IOMUXC_GPIO_AD_01_GPIO_MUX3_IO00 0x400E8110U, 0x5U, 0, 0, 0x400E8354U
751#define IOMUXC_GPIO_AD_01_LPUART7_RXD 0x400E8110U, 0x6U, 0x400E862CU, 0x0U, 0x400E8354U
752#define IOMUXC_GPIO_AD_01_FLEXIO2_D01 0x400E8110U, 0x8U, 0, 0, 0x400E8354U
753#define IOMUXC_GPIO_AD_01_FLEXSPI2_A_SS1_B 0x400E8110U, 0x9U, 0, 0, 0x400E8354U
754
755#define IOMUXC_GPIO_AD_02_GPIO9_IO01 0x400E8114U, 0xAU, 0, 0, 0x400E8358U
756#define IOMUXC_GPIO_AD_02_EMVSIM1_RST 0x400E8114U, 0x0U, 0, 0, 0x400E8358U
757#define IOMUXC_GPIO_AD_02_LPUART7_CTS_B 0x400E8114U, 0x1U, 0, 0, 0x400E8358U
758#define IOMUXC_GPIO_AD_02_ENET_1G_1588_EVENT2_IN 0x400E8114U, 0x2U, 0, 0, 0x400E8358U
759#define IOMUXC_GPIO_AD_02_GPT2_COMPARE1 0x400E8114U, 0x3U, 0, 0, 0x400E8358U
760#define IOMUXC_GPIO_AD_02_FLEXPWM1_PWM1_A 0x400E8114U, 0x4U, 0x400E8504U, 0x1U, 0x400E8358U
761#define IOMUXC_GPIO_AD_02_GPIO_MUX3_IO01 0x400E8114U, 0x5U, 0, 0, 0x400E8358U
762#define IOMUXC_GPIO_AD_02_LPUART8_TXD 0x400E8114U, 0x6U, 0x400E8638U, 0x0U, 0x400E8358U
763#define IOMUXC_GPIO_AD_02_FLEXIO2_D02 0x400E8114U, 0x8U, 0, 0, 0x400E8358U
764#define IOMUXC_GPIO_AD_02_VIDEO_MUX_EXT_DCIC1 0x400E8114U, 0x9U, 0, 0, 0x400E8358U
765
766#define IOMUXC_GPIO_AD_03_GPIO9_IO02 0x400E8118U, 0xAU, 0, 0, 0x400E835CU
767#define IOMUXC_GPIO_AD_03_EMVSIM1_SVEN 0x400E8118U, 0x0U, 0, 0, 0x400E835CU
768#define IOMUXC_GPIO_AD_03_LPUART7_RTS_B 0x400E8118U, 0x1U, 0, 0, 0x400E835CU
769#define IOMUXC_GPIO_AD_03_ENET_1G_1588_EVENT2_OUT 0x400E8118U, 0x2U, 0, 0, 0x400E835CU
770#define IOMUXC_GPIO_AD_03_GPT2_COMPARE2 0x400E8118U, 0x3U, 0, 0, 0x400E835CU
771#define IOMUXC_GPIO_AD_03_FLEXPWM1_PWM1_B 0x400E8118U, 0x4U, 0x400E8510U, 0x1U, 0x400E835CU
772#define IOMUXC_GPIO_AD_03_GPIO_MUX3_IO02 0x400E8118U, 0x5U, 0, 0, 0x400E835CU
773#define IOMUXC_GPIO_AD_03_LPUART8_RXD 0x400E8118U, 0x6U, 0x400E8634U, 0x0U, 0x400E835CU
774#define IOMUXC_GPIO_AD_03_FLEXIO2_D03 0x400E8118U, 0x8U, 0, 0, 0x400E835CU
775#define IOMUXC_GPIO_AD_03_VIDEO_MUX_EXT_DCIC2 0x400E8118U, 0x9U, 0, 0, 0x400E835CU
776
777#define IOMUXC_GPIO_AD_04_EMVSIM1_PD 0x400E811CU, 0x0U, 0x400E86A0U, 0x1U, 0x400E8360U
778#define IOMUXC_GPIO_AD_04_LPUART8_CTS_B 0x400E811CU, 0x1U, 0, 0, 0x400E8360U
779#define IOMUXC_GPIO_AD_04_ENET_1G_1588_EVENT3_IN 0x400E811CU, 0x2U, 0, 0, 0x400E8360U
780#define IOMUXC_GPIO_AD_04_GPT2_COMPARE3 0x400E811CU, 0x3U, 0, 0, 0x400E8360U
781#define IOMUXC_GPIO_AD_04_FLEXPWM1_PWM2_A 0x400E811CU, 0x4U, 0x400E8508U, 0x1U, 0x400E8360U
782#define IOMUXC_GPIO_AD_04_GPIO_MUX3_IO03 0x400E811CU, 0x5U, 0, 0, 0x400E8360U
783#define IOMUXC_GPIO_AD_04_WDOG1_B 0x400E811CU, 0x6U, 0, 0, 0x400E8360U
784#define IOMUXC_GPIO_AD_04_FLEXIO2_D04 0x400E811CU, 0x8U, 0, 0, 0x400E8360U
785#define IOMUXC_GPIO_AD_04_TMR4_TIMER0 0x400E811CU, 0x9U, 0x400E8660U, 0x1U, 0x400E8360U
786#define IOMUXC_GPIO_AD_04_GPIO9_IO03 0x400E811CU, 0xAU, 0, 0, 0x400E8360U
787
788#define IOMUXC_GPIO_AD_05_EMVSIM1_POWER_FAIL 0x400E8120U, 0x0U, 0x400E86A4U, 0x1U, 0x400E8364U
789#define IOMUXC_GPIO_AD_05_LPUART8_RTS_B 0x400E8120U, 0x1U, 0, 0, 0x400E8364U
790#define IOMUXC_GPIO_AD_05_ENET_1G_1588_EVENT3_OUT 0x400E8120U, 0x2U, 0, 0, 0x400E8364U
791#define IOMUXC_GPIO_AD_05_GPT2_CLK 0x400E8120U, 0x3U, 0, 0, 0x400E8364U
792#define IOMUXC_GPIO_AD_05_FLEXPWM1_PWM2_B 0x400E8120U, 0x4U, 0x400E8514U, 0x1U, 0x400E8364U
793#define IOMUXC_GPIO_AD_05_GPIO_MUX3_IO04 0x400E8120U, 0x5U, 0, 0, 0x400E8364U
794#define IOMUXC_GPIO_AD_05_WDOG2_B 0x400E8120U, 0x6U, 0, 0, 0x400E8364U
795#define IOMUXC_GPIO_AD_05_FLEXIO2_D05 0x400E8120U, 0x8U, 0, 0, 0x400E8364U
796#define IOMUXC_GPIO_AD_05_TMR4_TIMER1 0x400E8120U, 0x9U, 0x400E8664U, 0x1U, 0x400E8364U
797#define IOMUXC_GPIO_AD_05_GPIO9_IO04 0x400E8120U, 0xAU, 0, 0, 0x400E8364U
798
799#define IOMUXC_GPIO_AD_06_USB_OTG2_OC 0x400E8124U, 0x0U, 0x400E86B8U, 0x0U, 0x400E8368U
800#define IOMUXC_GPIO_AD_06_FLEXCAN1_TX 0x400E8124U, 0x1U, 0, 0, 0x400E8368U
801#define IOMUXC_GPIO_AD_06_EMVSIM2_IO 0x400E8124U, 0x2U, 0x400E86A8U, 0x0U, 0x400E8368U
802#define IOMUXC_GPIO_AD_06_GPT3_CAPTURE1 0x400E8124U, 0x3U, 0x400E8590U, 0x1U, 0x400E8368U
803#define IOMUXC_GPIO_AD_06_VIDEO_MUX_CSI_DATA15 0x400E8124U, 0x4U, 0, 0, 0x400E8368U
804#define IOMUXC_GPIO_AD_06_GPIO_MUX3_IO05 0x400E8124U, 0x5U, 0, 0, 0x400E8368U
805#define IOMUXC_GPIO_AD_06_ENET_1588_EVENT1_IN 0x400E8124U, 0x6U, 0, 0, 0x400E8368U
806#define IOMUXC_GPIO_AD_06_FLEXIO2_D06 0x400E8124U, 0x8U, 0, 0, 0x400E8368U
807#define IOMUXC_GPIO_AD_06_TMR4_TIMER2 0x400E8124U, 0x9U, 0x400E8668U, 0x0U, 0x400E8368U
808#define IOMUXC_GPIO_AD_06_GPIO9_IO05 0x400E8124U, 0xAU, 0, 0, 0x400E8368U
809#define IOMUXC_GPIO_AD_06_FLEXPWM1_PWM0_X 0x400E8124U, 0xBU, 0, 0, 0x400E8368U
810
811#define IOMUXC_GPIO_AD_07_USB_OTG2_PWR 0x400E8128U, 0x0U, 0, 0, 0x400E836CU
812#define IOMUXC_GPIO_AD_07_FLEXCAN1_RX 0x400E8128U, 0x1U, 0x400E8498U, 0x0U, 0x400E836CU
813#define IOMUXC_GPIO_AD_07_EMVSIM2_CLK 0x400E8128U, 0x2U, 0, 0, 0x400E836CU
814#define IOMUXC_GPIO_AD_07_GPT3_CAPTURE2 0x400E8128U, 0x3U, 0x400E8594U, 0x1U, 0x400E836CU
815#define IOMUXC_GPIO_AD_07_VIDEO_MUX_CSI_DATA14 0x400E8128U, 0x4U, 0, 0, 0x400E836CU
816#define IOMUXC_GPIO_AD_07_GPIO_MUX3_IO06 0x400E8128U, 0x5U, 0, 0, 0x400E836CU
817#define IOMUXC_GPIO_AD_07_ENET_1588_EVENT1_OUT 0x400E8128U, 0x6U, 0, 0, 0x400E836CU
818#define IOMUXC_GPIO_AD_07_FLEXIO2_D07 0x400E8128U, 0x8U, 0, 0, 0x400E836CU
819#define IOMUXC_GPIO_AD_07_TMR4_TIMER3 0x400E8128U, 0x9U, 0, 0, 0x400E836CU
820#define IOMUXC_GPIO_AD_07_GPIO9_IO06 0x400E8128U, 0xAU, 0, 0, 0x400E836CU
821#define IOMUXC_GPIO_AD_07_FLEXPWM1_PWM1_X 0x400E8128U, 0xBU, 0, 0, 0x400E836CU
822
823#define IOMUXC_GPIO_AD_08_USBPHY2_OTG_ID 0x400E812CU, 0x0U, 0x400E86C4U, 0x0U, 0x400E8370U
824#define IOMUXC_GPIO_AD_08_LPI2C1_SCL 0x400E812CU, 0x1U, 0x400E85ACU, 0x0U, 0x400E8370U
825#define IOMUXC_GPIO_AD_08_EMVSIM2_RST 0x400E812CU, 0x2U, 0, 0, 0x400E8370U
826#define IOMUXC_GPIO_AD_08_GPT3_COMPARE1 0x400E812CU, 0x3U, 0, 0, 0x400E8370U
827#define IOMUXC_GPIO_AD_08_VIDEO_MUX_CSI_DATA13 0x400E812CU, 0x4U, 0, 0, 0x400E8370U
828#define IOMUXC_GPIO_AD_08_GPIO_MUX3_IO07 0x400E812CU, 0x5U, 0, 0, 0x400E8370U
829#define IOMUXC_GPIO_AD_08_ENET_1588_EVENT2_IN 0x400E812CU, 0x6U, 0, 0, 0x400E8370U
830#define IOMUXC_GPIO_AD_08_FLEXIO2_D08 0x400E812CU, 0x8U, 0, 0, 0x400E8370U
831#define IOMUXC_GPIO_AD_08_GPIO9_IO07 0x400E812CU, 0xAU, 0, 0, 0x400E8370U
832#define IOMUXC_GPIO_AD_08_FLEXPWM1_PWM2_X 0x400E812CU, 0xBU, 0, 0, 0x400E8370U
833
834#define IOMUXC_GPIO_AD_09_USBPHY1_OTG_ID 0x400E8130U, 0x0U, 0x400E86C0U, 0x0U, 0x400E8374U
835#define IOMUXC_GPIO_AD_09_LPI2C1_SDA 0x400E8130U, 0x1U, 0x400E85B0U, 0x0U, 0x400E8374U
836#define IOMUXC_GPIO_AD_09_EMVSIM2_SVEN 0x400E8130U, 0x2U, 0, 0, 0x400E8374U
837#define IOMUXC_GPIO_AD_09_GPT3_COMPARE2 0x400E8130U, 0x3U, 0, 0, 0x400E8374U
838#define IOMUXC_GPIO_AD_09_VIDEO_MUX_CSI_DATA12 0x400E8130U, 0x4U, 0, 0, 0x400E8374U
839#define IOMUXC_GPIO_AD_09_GPIO_MUX3_IO08 0x400E8130U, 0x5U, 0, 0, 0x400E8374U
840#define IOMUXC_GPIO_AD_09_ENET_1588_EVENT2_OUT 0x400E8130U, 0x6U, 0, 0, 0x400E8374U
841#define IOMUXC_GPIO_AD_09_FLEXIO2_D09 0x400E8130U, 0x8U, 0, 0, 0x400E8374U
842#define IOMUXC_GPIO_AD_09_GPIO9_IO08 0x400E8130U, 0xAU, 0, 0, 0x400E8374U
843#define IOMUXC_GPIO_AD_09_FLEXPWM1_PWM3_X 0x400E8130U, 0xBU, 0, 0, 0x400E8374U
844
845#define IOMUXC_GPIO_AD_10_USB_OTG1_PWR 0x400E8134U, 0x0U, 0, 0, 0x400E8378U
846#define IOMUXC_GPIO_AD_10_LPI2C1_SCLS 0x400E8134U, 0x1U, 0, 0, 0x400E8378U
847#define IOMUXC_GPIO_AD_10_EMVSIM2_PD 0x400E8134U, 0x2U, 0x400E86ACU, 0x0U, 0x400E8378U
848#define IOMUXC_GPIO_AD_10_GPT3_COMPARE3 0x400E8134U, 0x3U, 0, 0, 0x400E8378U
849#define IOMUXC_GPIO_AD_10_VIDEO_MUX_CSI_DATA11 0x400E8134U, 0x4U, 0, 0, 0x400E8378U
850#define IOMUXC_GPIO_AD_10_GPIO_MUX3_IO09 0x400E8134U, 0x5U, 0, 0, 0x400E8378U
851#define IOMUXC_GPIO_AD_10_ENET_1588_EVENT3_IN 0x400E8134U, 0x6U, 0, 0, 0x400E8378U
852#define IOMUXC_GPIO_AD_10_FLEXIO2_D10 0x400E8134U, 0x8U, 0, 0, 0x400E8378U
853#define IOMUXC_GPIO_AD_10_GPIO9_IO09 0x400E8134U, 0xAU, 0, 0, 0x400E8378U
854#define IOMUXC_GPIO_AD_10_FLEXPWM2_PWM0_X 0x400E8134U, 0xBU, 0, 0, 0x400E8378U
855
856#define IOMUXC_GPIO_AD_11_USB_OTG1_OC 0x400E8138U, 0x0U, 0x400E86BCU, 0x0U, 0x400E837CU
857#define IOMUXC_GPIO_AD_11_LPI2C1_SDAS 0x400E8138U, 0x1U, 0, 0, 0x400E837CU
858#define IOMUXC_GPIO_AD_11_EMVSIM2_POWER_FAIL 0x400E8138U, 0x2U, 0x400E86B0U, 0x0U, 0x400E837CU
859#define IOMUXC_GPIO_AD_11_GPT3_CLK 0x400E8138U, 0x3U, 0x400E8598U, 0x1U, 0x400E837CU
860#define IOMUXC_GPIO_AD_11_VIDEO_MUX_CSI_DATA10 0x400E8138U, 0x4U, 0, 0, 0x400E837CU
861#define IOMUXC_GPIO_AD_11_GPIO_MUX3_IO10 0x400E8138U, 0x5U, 0, 0, 0x400E837CU
862#define IOMUXC_GPIO_AD_11_ENET_1588_EVENT3_OUT 0x400E8138U, 0x6U, 0, 0, 0x400E837CU
863#define IOMUXC_GPIO_AD_11_FLEXIO2_D11 0x400E8138U, 0x8U, 0, 0, 0x400E837CU
864#define IOMUXC_GPIO_AD_11_GPIO9_IO10 0x400E8138U, 0xAU, 0, 0, 0x400E837CU
865#define IOMUXC_GPIO_AD_11_FLEXPWM2_PWM1_X 0x400E8138U, 0xBU, 0, 0, 0x400E837CU
866
867#define IOMUXC_GPIO_AD_12_SPDIF_LOCK 0x400E813CU, 0x0U, 0, 0, 0x400E8380U
868#define IOMUXC_GPIO_AD_12_LPI2C1_HREQ 0x400E813CU, 0x1U, 0, 0, 0x400E8380U
869#define IOMUXC_GPIO_AD_12_GPT1_CAPTURE1 0x400E813CU, 0x2U, 0, 0, 0x400E8380U
870#define IOMUXC_GPIO_AD_12_FLEXSPI1_B_DATA03 0x400E813CU, 0x3U, 0x400E8570U, 0x0U, 0x400E8380U
871#define IOMUXC_GPIO_AD_12_VIDEO_MUX_CSI_PIXCLK 0x400E813CU, 0x4U, 0, 0, 0x400E8380U
872#define IOMUXC_GPIO_AD_12_GPIO_MUX3_IO11 0x400E813CU, 0x5U, 0, 0, 0x400E8380U
873#define IOMUXC_GPIO_AD_12_ENET_TX_DATA03 0x400E813CU, 0x6U, 0, 0, 0x400E8380U
874#define IOMUXC_GPIO_AD_12_FLEXIO2_D12 0x400E813CU, 0x8U, 0, 0, 0x400E8380U
875#define IOMUXC_GPIO_AD_12_EWM_OUT_B 0x400E813CU, 0x9U, 0, 0, 0x400E8380U
876#define IOMUXC_GPIO_AD_12_GPIO9_IO11 0x400E813CU, 0xAU, 0, 0, 0x400E8380U
877#define IOMUXC_GPIO_AD_12_FLEXPWM2_PWM2_X 0x400E813CU, 0xBU, 0, 0, 0x400E8380U
878
879#define IOMUXC_GPIO_AD_13_SPDIF_SR_CLK 0x400E8140U, 0x0U, 0, 0, 0x400E8384U
880#define IOMUXC_GPIO_AD_13_PIT1_TRIGGER0 0x400E8140U, 0x1U, 0, 0, 0x400E8384U
881#define IOMUXC_GPIO_AD_13_GPT1_CAPTURE2 0x400E8140U, 0x2U, 0, 0, 0x400E8384U
882#define IOMUXC_GPIO_AD_13_FLEXSPI1_B_DATA02 0x400E8140U, 0x3U, 0x400E856CU, 0x0U, 0x400E8384U
883#define IOMUXC_GPIO_AD_13_VIDEO_MUX_CSI_MCLK 0x400E8140U, 0x4U, 0, 0, 0x400E8384U
884#define IOMUXC_GPIO_AD_13_GPIO_MUX3_IO12 0x400E8140U, 0x5U, 0, 0, 0x400E8384U
885#define IOMUXC_GPIO_AD_13_ENET_TX_DATA02 0x400E8140U, 0x6U, 0, 0, 0x400E8384U
886#define IOMUXC_GPIO_AD_13_FLEXIO2_D13 0x400E8140U, 0x8U, 0, 0, 0x400E8384U
887#define IOMUXC_GPIO_AD_13_REF_CLK_32K 0x400E8140U, 0x9U, 0, 0, 0x400E8384U
888#define IOMUXC_GPIO_AD_13_GPIO9_IO12 0x400E8140U, 0xAU, 0, 0, 0x400E8384U
889#define IOMUXC_GPIO_AD_13_FLEXPWM2_PWM3_X 0x400E8140U, 0xBU, 0, 0, 0x400E8384U
890
891#define IOMUXC_GPIO_AD_14_SPDIF_EXT_CLK 0x400E8144U, 0x0U, 0, 0, 0x400E8388U
892#define IOMUXC_GPIO_AD_14_REF_CLK_24M 0x400E8144U, 0x1U, 0, 0, 0x400E8388U
893#define IOMUXC_GPIO_AD_14_GPT1_COMPARE1 0x400E8144U, 0x2U, 0, 0, 0x400E8388U
894#define IOMUXC_GPIO_AD_14_FLEXSPI1_B_DATA01 0x400E8144U, 0x3U, 0x400E8568U, 0x0U, 0x400E8388U
895#define IOMUXC_GPIO_AD_14_VIDEO_MUX_CSI_VSYNC 0x400E8144U, 0x4U, 0, 0, 0x400E8388U
896#define IOMUXC_GPIO_AD_14_GPIO_MUX3_IO13 0x400E8144U, 0x5U, 0, 0, 0x400E8388U
897#define IOMUXC_GPIO_AD_14_ENET_RX_CLK 0x400E8144U, 0x6U, 0, 0, 0x400E8388U
898#define IOMUXC_GPIO_AD_14_FLEXIO2_D14 0x400E8144U, 0x8U, 0, 0, 0x400E8388U
899#define IOMUXC_GPIO_AD_14_CCM_ENET_REF_CLK_25M 0x400E8144U, 0x9U, 0, 0, 0x400E8388U
900#define IOMUXC_GPIO_AD_14_GPIO9_IO13 0x400E8144U, 0xAU, 0, 0, 0x400E8388U
901#define IOMUXC_GPIO_AD_14_FLEXPWM3_PWM0_X 0x400E8144U, 0xBU, 0, 0, 0x400E8388U
902
903#define IOMUXC_GPIO_AD_15_GPIO9_IO14 0x400E8148U, 0xAU, 0, 0, 0x400E838CU
904#define IOMUXC_GPIO_AD_15_FLEXPWM3_PWM1_X 0x400E8148U, 0xBU, 0, 0, 0x400E838CU
905#define IOMUXC_GPIO_AD_15_SPDIF_IN 0x400E8148U, 0x0U, 0x400E86B4U, 0x1U, 0x400E838CU
906#define IOMUXC_GPIO_AD_15_LPUART10_TXD 0x400E8148U, 0x1U, 0x400E8628U, 0x0U, 0x400E838CU
907#define IOMUXC_GPIO_AD_15_GPT1_COMPARE2 0x400E8148U, 0x2U, 0, 0, 0x400E838CU
908#define IOMUXC_GPIO_AD_15_FLEXSPI1_B_DATA00 0x400E8148U, 0x3U, 0x400E8564U, 0x0U, 0x400E838CU
909#define IOMUXC_GPIO_AD_15_VIDEO_MUX_CSI_HSYNC 0x400E8148U, 0x4U, 0, 0, 0x400E838CU
910#define IOMUXC_GPIO_AD_15_GPIO_MUX3_IO14 0x400E8148U, 0x5U, 0, 0, 0x400E838CU
911#define IOMUXC_GPIO_AD_15_ENET_TX_ER 0x400E8148U, 0x6U, 0, 0, 0x400E838CU
912#define IOMUXC_GPIO_AD_15_FLEXIO2_D15 0x400E8148U, 0x8U, 0, 0, 0x400E838CU
913
914#define IOMUXC_GPIO_AD_16_SPDIF_OUT 0x400E814CU, 0x0U, 0, 0, 0x400E8390U
915#define IOMUXC_GPIO_AD_16_LPUART10_RXD 0x400E814CU, 0x1U, 0x400E8624U, 0x0U, 0x400E8390U
916#define IOMUXC_GPIO_AD_16_GPT1_COMPARE3 0x400E814CU, 0x2U, 0, 0, 0x400E8390U
917#define IOMUXC_GPIO_AD_16_FLEXSPI1_B_SCLK 0x400E814CU, 0x3U, 0x400E8578U, 0x0U, 0x400E8390U
918#define IOMUXC_GPIO_AD_16_VIDEO_MUX_CSI_DATA09 0x400E814CU, 0x4U, 0, 0, 0x400E8390U
919#define IOMUXC_GPIO_AD_16_GPIO_MUX3_IO15 0x400E814CU, 0x5U, 0, 0, 0x400E8390U
920#define IOMUXC_GPIO_AD_16_ENET_RX_DATA03 0x400E814CU, 0x6U, 0, 0, 0x400E8390U
921#define IOMUXC_GPIO_AD_16_FLEXIO2_D16 0x400E814CU, 0x8U, 0, 0, 0x400E8390U
922#define IOMUXC_GPIO_AD_16_ENET_1G_MDC 0x400E814CU, 0x9U, 0, 0, 0x400E8390U
923#define IOMUXC_GPIO_AD_16_GPIO9_IO15 0x400E814CU, 0xAU, 0, 0, 0x400E8390U
924#define IOMUXC_GPIO_AD_16_FLEXPWM3_PWM2_X 0x400E814CU, 0xBU, 0, 0, 0x400E8390U
925
926#define IOMUXC_GPIO_AD_17_SAI1_MCLK 0x400E8150U, 0x0U, 0x400E866CU, 0x0U, 0x400E8394U
927#define IOMUXC_GPIO_AD_17_ACMP1_OUT 0x400E8150U, 0x1U, 0, 0, 0x400E8394U
928#define IOMUXC_GPIO_AD_17_GPT1_CLK 0x400E8150U, 0x2U, 0, 0, 0x400E8394U
929#define IOMUXC_GPIO_AD_17_FLEXSPI1_A_DQS 0x400E8150U, 0x3U, 0x400E8550U, 0x1U, 0x400E8394U
930#define IOMUXC_GPIO_AD_17_VIDEO_MUX_CSI_DATA08 0x400E8150U, 0x4U, 0, 0, 0x400E8394U
931#define IOMUXC_GPIO_AD_17_GPIO_MUX3_IO16 0x400E8150U, 0x5U, 0, 0, 0x400E8394U
932#define IOMUXC_GPIO_AD_17_ENET_RX_DATA02 0x400E8150U, 0x6U, 0, 0, 0x400E8394U
933#define IOMUXC_GPIO_AD_17_FLEXIO2_D17 0x400E8150U, 0x8U, 0, 0, 0x400E8394U
934#define IOMUXC_GPIO_AD_17_ENET_1G_MDIO 0x400E8150U, 0x9U, 0x400E84C8U, 0x2U, 0x400E8394U
935#define IOMUXC_GPIO_AD_17_GPIO9_IO16 0x400E8150U, 0xAU, 0, 0, 0x400E8394U
936#define IOMUXC_GPIO_AD_17_FLEXPWM3_PWM3_X 0x400E8150U, 0xBU, 0, 0, 0x400E8394U
937
938#define IOMUXC_GPIO_AD_18_GPIO9_IO17 0x400E8154U, 0xAU, 0, 0, 0x400E8398U
939#define IOMUXC_GPIO_AD_18_FLEXPWM4_PWM0_X 0x400E8154U, 0xBU, 0, 0, 0x400E8398U
940#define IOMUXC_GPIO_AD_18_SAI1_RX_SYNC 0x400E8154U, 0x0U, 0x400E8678U, 0x0U, 0x400E8398U
941#define IOMUXC_GPIO_AD_18_ACMP2_OUT 0x400E8154U, 0x1U, 0, 0, 0x400E8398U
942#define IOMUXC_GPIO_AD_18_LPSPI1_PCS1 0x400E8154U, 0x2U, 0, 0, 0x400E8398U
943#define IOMUXC_GPIO_AD_18_FLEXSPI1_A_SS0_B 0x400E8154U, 0x3U, 0, 0, 0x400E8398U
944#define IOMUXC_GPIO_AD_18_VIDEO_MUX_CSI_DATA07 0x400E8154U, 0x4U, 0, 0, 0x400E8398U
945#define IOMUXC_GPIO_AD_18_GPIO_MUX3_IO17 0x400E8154U, 0x5U, 0, 0, 0x400E8398U
946#define IOMUXC_GPIO_AD_18_ENET_CRS 0x400E8154U, 0x6U, 0, 0, 0x400E8398U
947#define IOMUXC_GPIO_AD_18_FLEXIO2_D18 0x400E8154U, 0x8U, 0, 0, 0x400E8398U
948#define IOMUXC_GPIO_AD_18_LPI2C2_SCL 0x400E8154U, 0x9U, 0x400E85B4U, 0x1U, 0x400E8398U
949
950#define IOMUXC_GPIO_AD_19_SAI1_RX_BCLK 0x400E8158U, 0x0U, 0x400E8670U, 0x0U, 0x400E839CU
951#define IOMUXC_GPIO_AD_19_ACMP3_OUT 0x400E8158U, 0x1U, 0, 0, 0x400E839CU
952#define IOMUXC_GPIO_AD_19_LPSPI1_PCS2 0x400E8158U, 0x2U, 0, 0, 0x400E839CU
953#define IOMUXC_GPIO_AD_19_FLEXSPI1_A_SCLK 0x400E8158U, 0x3U, 0x400E8574U, 0x0U, 0x400E839CU
954#define IOMUXC_GPIO_AD_19_VIDEO_MUX_CSI_DATA06 0x400E8158U, 0x4U, 0, 0, 0x400E839CU
955#define IOMUXC_GPIO_AD_19_GPIO_MUX3_IO18 0x400E8158U, 0x5U, 0, 0, 0x400E839CU
956#define IOMUXC_GPIO_AD_19_ENET_COL 0x400E8158U, 0x6U, 0, 0, 0x400E839CU
957#define IOMUXC_GPIO_AD_19_FLEXIO2_D19 0x400E8158U, 0x8U, 0, 0, 0x400E839CU
958#define IOMUXC_GPIO_AD_19_LPI2C2_SDA 0x400E8158U, 0x9U, 0x400E85B8U, 0x1U, 0x400E839CU
959#define IOMUXC_GPIO_AD_19_GPIO9_IO18 0x400E8158U, 0xAU, 0, 0, 0x400E839CU
960#define IOMUXC_GPIO_AD_19_FLEXPWM4_PWM1_X 0x400E8158U, 0xBU, 0, 0, 0x400E839CU
961
962#define IOMUXC_GPIO_AD_20_SAI1_RX_DATA00 0x400E815CU, 0x0U, 0x400E8674U, 0x0U, 0x400E83A0U
963#define IOMUXC_GPIO_AD_20_ACMP4_OUT 0x400E815CU, 0x1U, 0, 0, 0x400E83A0U
964#define IOMUXC_GPIO_AD_20_LPSPI1_PCS3 0x400E815CU, 0x2U, 0, 0, 0x400E83A0U
965#define IOMUXC_GPIO_AD_20_FLEXSPI1_A_DATA00 0x400E815CU, 0x3U, 0x400E8554U, 0x0U, 0x400E83A0U
966#define IOMUXC_GPIO_AD_20_VIDEO_MUX_CSI_DATA05 0x400E815CU, 0x4U, 0, 0, 0x400E83A0U
967#define IOMUXC_GPIO_AD_20_GPIO_MUX3_IO19 0x400E815CU, 0x5U, 0, 0, 0x400E83A0U
968#define IOMUXC_GPIO_AD_20_KPP_ROW07 0x400E815CU, 0x6U, 0x400E85A8U, 0x0U, 0x400E83A0U
969#define IOMUXC_GPIO_AD_20_FLEXIO2_D20 0x400E815CU, 0x8U, 0, 0, 0x400E83A0U
970#define IOMUXC_GPIO_AD_20_ENET_QOS_1588_EVENT2_OUT 0x400E815CU, 0x9U, 0, 0, 0x400E83A0U
971#define IOMUXC_GPIO_AD_20_GPIO9_IO19 0x400E815CU, 0xAU, 0, 0, 0x400E83A0U
972#define IOMUXC_GPIO_AD_20_FLEXPWM4_PWM2_X 0x400E815CU, 0xBU, 0, 0, 0x400E83A0U
973
974#define IOMUXC_GPIO_AD_21_SAI1_TX_DATA00 0x400E8160U, 0x0U, 0, 0, 0x400E83A4U
975#define IOMUXC_GPIO_AD_21_LPSPI2_PCS1 0x400E8160U, 0x2U, 0x400E85E0U, 0x0U, 0x400E83A4U
976#define IOMUXC_GPIO_AD_21_FLEXSPI1_A_DATA01 0x400E8160U, 0x3U, 0x400E8558U, 0x0U, 0x400E83A4U
977#define IOMUXC_GPIO_AD_21_VIDEO_MUX_CSI_DATA04 0x400E8160U, 0x4U, 0, 0, 0x400E83A4U
978#define IOMUXC_GPIO_AD_21_GPIO_MUX3_IO20 0x400E8160U, 0x5U, 0, 0, 0x400E83A4U
979#define IOMUXC_GPIO_AD_21_KPP_COL07 0x400E8160U, 0x6U, 0x400E85A0U, 0x0U, 0x400E83A4U
980#define IOMUXC_GPIO_AD_21_FLEXIO2_D21 0x400E8160U, 0x8U, 0, 0, 0x400E83A4U
981#define IOMUXC_GPIO_AD_21_ENET_QOS_1588_EVENT2_IN 0x400E8160U, 0x9U, 0, 0, 0x400E83A4U
982#define IOMUXC_GPIO_AD_21_GPIO9_IO20 0x400E8160U, 0xAU, 0, 0, 0x400E83A4U
983#define IOMUXC_GPIO_AD_21_FLEXPWM4_PWM3_X 0x400E8160U, 0xBU, 0, 0, 0x400E83A4U
984
985#define IOMUXC_GPIO_AD_22_GPIO9_IO21 0x400E8164U, 0xAU, 0, 0, 0x400E83A8U
986#define IOMUXC_GPIO_AD_22_SAI1_TX_BCLK 0x400E8164U, 0x0U, 0x400E867CU, 0x0U, 0x400E83A8U
987#define IOMUXC_GPIO_AD_22_LPSPI2_PCS2 0x400E8164U, 0x2U, 0, 0, 0x400E83A8U
988#define IOMUXC_GPIO_AD_22_FLEXSPI1_A_DATA02 0x400E8164U, 0x3U, 0x400E855CU, 0x0U, 0x400E83A8U
989#define IOMUXC_GPIO_AD_22_VIDEO_MUX_CSI_DATA03 0x400E8164U, 0x4U, 0, 0, 0x400E83A8U
990#define IOMUXC_GPIO_AD_22_GPIO_MUX3_IO21 0x400E8164U, 0x5U, 0, 0, 0x400E83A8U
991#define IOMUXC_GPIO_AD_22_KPP_ROW06 0x400E8164U, 0x6U, 0x400E85A4U, 0x0U, 0x400E83A8U
992#define IOMUXC_GPIO_AD_22_FLEXIO2_D22 0x400E8164U, 0x8U, 0, 0, 0x400E83A8U
993#define IOMUXC_GPIO_AD_22_ENET_QOS_1588_EVENT3_OUT 0x400E8164U, 0x9U, 0, 0, 0x400E83A8U
994
995#define IOMUXC_GPIO_AD_23_SAI1_TX_SYNC 0x400E8168U, 0x0U, 0x400E8680U, 0x0U, 0x400E83ACU
996#define IOMUXC_GPIO_AD_23_LPSPI2_PCS3 0x400E8168U, 0x2U, 0, 0, 0x400E83ACU
997#define IOMUXC_GPIO_AD_23_FLEXSPI1_A_DATA03 0x400E8168U, 0x3U, 0x400E8560U, 0x0U, 0x400E83ACU
998#define IOMUXC_GPIO_AD_23_VIDEO_MUX_CSI_DATA02 0x400E8168U, 0x4U, 0, 0, 0x400E83ACU
999#define IOMUXC_GPIO_AD_23_GPIO_MUX3_IO22 0x400E8168U, 0x5U, 0, 0, 0x400E83ACU
1000#define IOMUXC_GPIO_AD_23_KPP_COL06 0x400E8168U, 0x6U, 0x400E859CU, 0x0U, 0x400E83ACU
1001#define IOMUXC_GPIO_AD_23_FLEXIO2_D23 0x400E8168U, 0x8U, 0, 0, 0x400E83ACU
1002#define IOMUXC_GPIO_AD_23_ENET_QOS_1588_EVENT3_IN 0x400E8168U, 0x9U, 0, 0, 0x400E83ACU
1003#define IOMUXC_GPIO_AD_23_GPIO9_IO22 0x400E8168U, 0xAU, 0, 0, 0x400E83ACU
1004
1005#define IOMUXC_GPIO_AD_24_LPUART1_TXD 0x400E816CU, 0x0U, 0x400E8620U, 0x0U, 0x400E83B0U
1006#define IOMUXC_GPIO_AD_24_LPSPI2_SCK 0x400E816CU, 0x1U, 0x400E85E4U, 0x0U, 0x400E83B0U
1007#define IOMUXC_GPIO_AD_24_VIDEO_MUX_CSI_DATA00 0x400E816CU, 0x2U, 0, 0, 0x400E83B0U
1008#define IOMUXC_GPIO_AD_24_ENET_RX_EN 0x400E816CU, 0x3U, 0x400E84B8U, 0x0U, 0x400E83B0U
1009#define IOMUXC_GPIO_AD_24_FLEXPWM2_PWM0_A 0x400E816CU, 0x4U, 0x400E8518U, 0x1U, 0x400E83B0U
1010#define IOMUXC_GPIO_AD_24_GPIO_MUX3_IO23 0x400E816CU, 0x5U, 0, 0, 0x400E83B0U
1011#define IOMUXC_GPIO_AD_24_KPP_ROW05 0x400E816CU, 0x6U, 0, 0, 0x400E83B0U
1012#define IOMUXC_GPIO_AD_24_FLEXIO2_D24 0x400E816CU, 0x8U, 0, 0, 0x400E83B0U
1013#define IOMUXC_GPIO_AD_24_LPI2C4_SCL 0x400E816CU, 0x9U, 0x400E85C4U, 0x0U, 0x400E83B0U
1014#define IOMUXC_GPIO_AD_24_GPIO9_IO23 0x400E816CU, 0xAU, 0, 0, 0x400E83B0U
1015
1016#define IOMUXC_GPIO_AD_25_GPIO9_IO24 0x400E8170U, 0xAU, 0, 0, 0x400E83B4U
1017#define IOMUXC_GPIO_AD_25_LPUART1_RXD 0x400E8170U, 0x0U, 0x400E861CU, 0x0U, 0x400E83B4U
1018#define IOMUXC_GPIO_AD_25_LPSPI2_PCS0 0x400E8170U, 0x1U, 0x400E85DCU, 0x0U, 0x400E83B4U
1019#define IOMUXC_GPIO_AD_25_VIDEO_MUX_CSI_DATA01 0x400E8170U, 0x2U, 0, 0, 0x400E83B4U
1020#define IOMUXC_GPIO_AD_25_ENET_RX_ER 0x400E8170U, 0x3U, 0x400E84BCU, 0x0U, 0x400E83B4U
1021#define IOMUXC_GPIO_AD_25_FLEXPWM2_PWM0_B 0x400E8170U, 0x4U, 0x400E8524U, 0x1U, 0x400E83B4U
1022#define IOMUXC_GPIO_AD_25_GPIO_MUX3_IO24 0x400E8170U, 0x5U, 0, 0, 0x400E83B4U
1023#define IOMUXC_GPIO_AD_25_KPP_COL05 0x400E8170U, 0x6U, 0, 0, 0x400E83B4U
1024#define IOMUXC_GPIO_AD_25_FLEXIO2_D25 0x400E8170U, 0x8U, 0, 0, 0x400E83B4U
1025#define IOMUXC_GPIO_AD_25_LPI2C4_SDA 0x400E8170U, 0x9U, 0x400E85C8U, 0x0U, 0x400E83B4U
1026
1027#define IOMUXC_GPIO_AD_26_LPUART1_CTS_B 0x400E8174U, 0x0U, 0, 0, 0x400E83B8U
1028#define IOMUXC_GPIO_AD_26_LPSPI2_SOUT 0x400E8174U, 0x1U, 0x400E85ECU, 0x0U, 0x400E83B8U
1029#define IOMUXC_GPIO_AD_26_SEMC_CSX01 0x400E8174U, 0x2U, 0, 0, 0x400E83B8U
1030#define IOMUXC_GPIO_AD_26_ENET_RX_DATA00 0x400E8174U, 0x3U, 0x400E84B0U, 0x0U, 0x400E83B8U
1031#define IOMUXC_GPIO_AD_26_FLEXPWM2_PWM1_A 0x400E8174U, 0x4U, 0x400E851CU, 0x1U, 0x400E83B8U
1032#define IOMUXC_GPIO_AD_26_GPIO_MUX3_IO25 0x400E8174U, 0x5U, 0, 0, 0x400E83B8U
1033#define IOMUXC_GPIO_AD_26_KPP_ROW04 0x400E8174U, 0x6U, 0, 0, 0x400E83B8U
1034#define IOMUXC_GPIO_AD_26_FLEXIO2_D26 0x400E8174U, 0x8U, 0, 0, 0x400E83B8U
1035#define IOMUXC_GPIO_AD_26_ENET_QOS_MDC 0x400E8174U, 0x9U, 0, 0, 0x400E83B8U
1036#define IOMUXC_GPIO_AD_26_GPIO9_IO25 0x400E8174U, 0xAU, 0, 0, 0x400E83B8U
1037#define IOMUXC_GPIO_AD_26_USDHC2_CD_B 0x400E8174U, 0xBU, 0x400E86D0U, 0x1U, 0x400E83B8U
1038
1039#define IOMUXC_GPIO_AD_27_LPUART1_RTS_B 0x400E8178U, 0x0U, 0, 0, 0x400E83BCU
1040#define IOMUXC_GPIO_AD_27_LPSPI2_SIN 0x400E8178U, 0x1U, 0x400E85E8U, 0x0U, 0x400E83BCU
1041#define IOMUXC_GPIO_AD_27_SEMC_CSX02 0x400E8178U, 0x2U, 0, 0, 0x400E83BCU
1042#define IOMUXC_GPIO_AD_27_ENET_RX_DATA01 0x400E8178U, 0x3U, 0x400E84B4U, 0x0U, 0x400E83BCU
1043#define IOMUXC_GPIO_AD_27_FLEXPWM2_PWM1_B 0x400E8178U, 0x4U, 0x400E8528U, 0x1U, 0x400E83BCU
1044#define IOMUXC_GPIO_AD_27_GPIO_MUX3_IO26 0x400E8178U, 0x5U, 0, 0, 0x400E83BCU
1045#define IOMUXC_GPIO_AD_27_KPP_COL04 0x400E8178U, 0x6U, 0, 0, 0x400E83BCU
1046#define IOMUXC_GPIO_AD_27_FLEXIO2_D27 0x400E8178U, 0x8U, 0, 0, 0x400E83BCU
1047#define IOMUXC_GPIO_AD_27_ENET_QOS_MDIO 0x400E8178U, 0x9U, 0x400E84ECU, 0x1U, 0x400E83BCU
1048#define IOMUXC_GPIO_AD_27_GPIO9_IO26 0x400E8178U, 0xAU, 0, 0, 0x400E83BCU
1049#define IOMUXC_GPIO_AD_27_USDHC2_WP 0x400E8178U, 0xBU, 0x400E86D4U, 0x1U, 0x400E83BCU
1050
1051#define IOMUXC_GPIO_AD_28_GPIO9_IO27 0x400E817CU, 0xAU, 0, 0, 0x400E83C0U
1052#define IOMUXC_GPIO_AD_28_USDHC2_VSELECT 0x400E817CU, 0xBU, 0, 0, 0x400E83C0U
1053#define IOMUXC_GPIO_AD_28_LPSPI1_SCK 0x400E817CU, 0x0U, 0x400E85D0U, 0x1U, 0x400E83C0U
1054#define IOMUXC_GPIO_AD_28_LPUART5_TXD 0x400E817CU, 0x1U, 0, 0, 0x400E83C0U
1055#define IOMUXC_GPIO_AD_28_SEMC_CSX03 0x400E817CU, 0x2U, 0, 0, 0x400E83C0U
1056#define IOMUXC_GPIO_AD_28_ENET_TX_EN 0x400E817CU, 0x3U, 0, 0, 0x400E83C0U
1057#define IOMUXC_GPIO_AD_28_FLEXPWM2_PWM2_A 0x400E817CU, 0x4U, 0x400E8520U, 0x1U, 0x400E83C0U
1058#define IOMUXC_GPIO_AD_28_GPIO_MUX3_IO27 0x400E817CU, 0x5U, 0, 0, 0x400E83C0U
1059#define IOMUXC_GPIO_AD_28_KPP_ROW03 0x400E817CU, 0x6U, 0, 0, 0x400E83C0U
1060#define IOMUXC_GPIO_AD_28_FLEXIO2_D28 0x400E817CU, 0x8U, 0, 0, 0x400E83C0U
1061#define IOMUXC_GPIO_AD_28_VIDEO_MUX_EXT_DCIC1 0x400E817CU, 0x9U, 0, 0, 0x400E83C0U
1062
1063#define IOMUXC_GPIO_AD_29_LPSPI1_PCS0 0x400E8180U, 0x0U, 0x400E85CCU, 0x1U, 0x400E83C4U
1064#define IOMUXC_GPIO_AD_29_LPUART5_RXD 0x400E8180U, 0x1U, 0, 0, 0x400E83C4U
1065#define IOMUXC_GPIO_AD_29_ENET_REF_CLK 0x400E8180U, 0x2U, 0x400E84A8U, 0x0U, 0x400E83C4U
1066#define IOMUXC_GPIO_AD_29_ENET_TX_CLK 0x400E8180U, 0x3U, 0x400E84C0U, 0x0U, 0x400E83C4U
1067#define IOMUXC_GPIO_AD_29_FLEXPWM2_PWM2_B 0x400E8180U, 0x4U, 0x400E852CU, 0x1U, 0x400E83C4U
1068#define IOMUXC_GPIO_AD_29_GPIO_MUX3_IO28 0x400E8180U, 0x5U, 0, 0, 0x400E83C4U
1069#define IOMUXC_GPIO_AD_29_KPP_COL03 0x400E8180U, 0x6U, 0, 0, 0x400E83C4U
1070#define IOMUXC_GPIO_AD_29_FLEXIO2_D29 0x400E8180U, 0x8U, 0, 0, 0x400E83C4U
1071#define IOMUXC_GPIO_AD_29_VIDEO_MUX_EXT_DCIC2 0x400E8180U, 0x9U, 0, 0, 0x400E83C4U
1072#define IOMUXC_GPIO_AD_29_GPIO9_IO28 0x400E8180U, 0xAU, 0, 0, 0x400E83C4U
1073#define IOMUXC_GPIO_AD_29_USDHC2_RESET_B 0x400E8180U, 0xBU, 0, 0, 0x400E83C4U
1074
1075#define IOMUXC_GPIO_AD_30_LPSPI1_SOUT 0x400E8184U, 0x0U, 0x400E85D8U, 0x1U, 0x400E83C8U
1076#define IOMUXC_GPIO_AD_30_USB_OTG2_OC 0x400E8184U, 0x1U, 0x400E86B8U, 0x1U, 0x400E83C8U
1077#define IOMUXC_GPIO_AD_30_FLEXCAN2_TX 0x400E8184U, 0x2U, 0, 0, 0x400E83C8U
1078#define IOMUXC_GPIO_AD_30_ENET_TX_DATA00 0x400E8184U, 0x3U, 0, 0, 0x400E83C8U
1079#define IOMUXC_GPIO_AD_30_LPUART3_TXD 0x400E8184U, 0x4U, 0, 0, 0x400E83C8U
1080#define IOMUXC_GPIO_AD_30_GPIO_MUX3_IO29 0x400E8184U, 0x5U, 0, 0, 0x400E83C8U
1081#define IOMUXC_GPIO_AD_30_KPP_ROW02 0x400E8184U, 0x6U, 0, 0, 0x400E83C8U
1082#define IOMUXC_GPIO_AD_30_FLEXIO2_D30 0x400E8184U, 0x8U, 0, 0, 0x400E83C8U
1083#define IOMUXC_GPIO_AD_30_WDOG2_RESET_B_DEB 0x400E8184U, 0x9U, 0, 0, 0x400E83C8U
1084#define IOMUXC_GPIO_AD_30_GPIO9_IO29 0x400E8184U, 0xAU, 0, 0, 0x400E83C8U
1085
1086#define IOMUXC_GPIO_AD_31_LPSPI1_SIN 0x400E8188U, 0x0U, 0x400E85D4U, 0x1U, 0x400E83CCU
1087#define IOMUXC_GPIO_AD_31_USB_OTG2_PWR 0x400E8188U, 0x1U, 0, 0, 0x400E83CCU
1088#define IOMUXC_GPIO_AD_31_FLEXCAN2_RX 0x400E8188U, 0x2U, 0x400E849CU, 0x1U, 0x400E83CCU
1089#define IOMUXC_GPIO_AD_31_ENET_TX_DATA01 0x400E8188U, 0x3U, 0, 0, 0x400E83CCU
1090#define IOMUXC_GPIO_AD_31_LPUART3_RXD 0x400E8188U, 0x4U, 0, 0, 0x400E83CCU
1091#define IOMUXC_GPIO_AD_31_GPIO_MUX3_IO30 0x400E8188U, 0x5U, 0, 0, 0x400E83CCU
1092#define IOMUXC_GPIO_AD_31_KPP_COL02 0x400E8188U, 0x6U, 0, 0, 0x400E83CCU
1093#define IOMUXC_GPIO_AD_31_FLEXIO2_D31 0x400E8188U, 0x8U, 0, 0, 0x400E83CCU
1094#define IOMUXC_GPIO_AD_31_WDOG1_RESET_B_DEB 0x400E8188U, 0x9U, 0, 0, 0x400E83CCU
1095#define IOMUXC_GPIO_AD_31_GPIO9_IO30 0x400E8188U, 0xAU, 0, 0, 0x400E83CCU
1096
1097#define IOMUXC_GPIO_AD_32_GPIO9_IO31 0x400E818CU, 0xAU, 0, 0, 0x400E83D0U
1098#define IOMUXC_GPIO_AD_32_LPI2C1_SCL 0x400E818CU, 0x0U, 0x400E85ACU, 0x1U, 0x400E83D0U
1099#define IOMUXC_GPIO_AD_32_USBPHY2_OTG_ID 0x400E818CU, 0x1U, 0x400E86C4U, 0x1U, 0x400E83D0U
1100#define IOMUXC_GPIO_AD_32_PGMC_PMIC_RDY 0x400E818CU, 0x2U, 0, 0, 0x400E83D0U
1101#define IOMUXC_GPIO_AD_32_ENET_MDC 0x400E818CU, 0x3U, 0, 0, 0x400E83D0U
1102#define IOMUXC_GPIO_AD_32_USDHC1_CD_B 0x400E818CU, 0x4U, 0x400E86C8U, 0x0U, 0x400E83D0U
1103#define IOMUXC_GPIO_AD_32_GPIO_MUX3_IO31 0x400E818CU, 0x5U, 0, 0, 0x400E83D0U
1104#define IOMUXC_GPIO_AD_32_KPP_ROW01 0x400E818CU, 0x6U, 0, 0, 0x400E83D0U
1105#define IOMUXC_GPIO_AD_32_LPUART10_TXD 0x400E818CU, 0x8U, 0x400E8628U, 0x1U, 0x400E83D0U
1106#define IOMUXC_GPIO_AD_32_ENET_1G_MDC 0x400E818CU, 0x9U, 0, 0, 0x400E83D0U
1107
1108#define IOMUXC_GPIO_AD_33_LPI2C1_SDA 0x400E8190U, 0x0U, 0x400E85B0U, 0x1U, 0x400E83D4U
1109#define IOMUXC_GPIO_AD_33_USBPHY1_OTG_ID 0x400E8190U, 0x1U, 0x400E86C0U, 0x1U, 0x400E83D4U
1110#define IOMUXC_GPIO_AD_33_XBAR1_INOUT17 0x400E8190U, 0x2U, 0, 0, 0x400E83D4U
1111#define IOMUXC_GPIO_AD_33_ENET_MDIO 0x400E8190U, 0x3U, 0x400E84ACU, 0x1U, 0x400E83D4U
1112#define IOMUXC_GPIO_AD_33_USDHC1_WP 0x400E8190U, 0x4U, 0x400E86CCU, 0x0U, 0x400E83D4U
1113#define IOMUXC_GPIO_AD_33_GPIO_MUX4_IO00 0x400E8190U, 0x5U, 0, 0, 0x400E83D4U
1114#define IOMUXC_GPIO_AD_33_KPP_COL01 0x400E8190U, 0x6U, 0, 0, 0x400E83D4U
1115#define IOMUXC_GPIO_AD_33_LPUART10_RXD 0x400E8190U, 0x8U, 0x400E8624U, 0x1U, 0x400E83D4U
1116#define IOMUXC_GPIO_AD_33_ENET_1G_MDIO 0x400E8190U, 0x9U, 0x400E84C8U, 0x3U, 0x400E83D4U
1117#define IOMUXC_GPIO_AD_33_GPIO10_IO00 0x400E8190U, 0xAU, 0, 0, 0x400E83D4U
1118
1119#define IOMUXC_GPIO_AD_34_ENET_1G_1588_EVENT0_IN 0x400E8194U, 0x0U, 0, 0, 0x400E83D8U
1120#define IOMUXC_GPIO_AD_34_USB_OTG1_PWR 0x400E8194U, 0x1U, 0, 0, 0x400E83D8U
1121#define IOMUXC_GPIO_AD_34_XBAR1_INOUT18 0x400E8194U, 0x2U, 0, 0, 0x400E83D8U
1122#define IOMUXC_GPIO_AD_34_ENET_1588_EVENT0_IN 0x400E8194U, 0x3U, 0, 0, 0x400E83D8U
1123#define IOMUXC_GPIO_AD_34_USDHC1_VSELECT 0x400E8194U, 0x4U, 0, 0, 0x400E83D8U
1124#define IOMUXC_GPIO_AD_34_GPIO_MUX4_IO01 0x400E8194U, 0x5U, 0, 0, 0x400E83D8U
1125#define IOMUXC_GPIO_AD_34_KPP_ROW00 0x400E8194U, 0x6U, 0, 0, 0x400E83D8U
1126#define IOMUXC_GPIO_AD_34_LPUART10_CTS_B 0x400E8194U, 0x8U, 0, 0, 0x400E83D8U
1127#define IOMUXC_GPIO_AD_34_WDOG1_ANY 0x400E8194U, 0x9U, 0, 0, 0x400E83D8U
1128#define IOMUXC_GPIO_AD_34_GPIO10_IO01 0x400E8194U, 0xAU, 0, 0, 0x400E83D8U
1129
1130#define IOMUXC_GPIO_AD_35_GPIO10_IO02 0x400E8198U, 0xAU, 0, 0, 0x400E83DCU
1131#define IOMUXC_GPIO_AD_35_ENET_1G_1588_EVENT0_OUT 0x400E8198U, 0x0U, 0, 0, 0x400E83DCU
1132#define IOMUXC_GPIO_AD_35_USB_OTG1_OC 0x400E8198U, 0x1U, 0x400E86BCU, 0x1U, 0x400E83DCU
1133#define IOMUXC_GPIO_AD_35_XBAR1_INOUT19 0x400E8198U, 0x2U, 0, 0, 0x400E83DCU
1134#define IOMUXC_GPIO_AD_35_ENET_1588_EVENT0_OUT 0x400E8198U, 0x3U, 0, 0, 0x400E83DCU
1135#define IOMUXC_GPIO_AD_35_USDHC1_RESET_B 0x400E8198U, 0x4U, 0, 0, 0x400E83DCU
1136#define IOMUXC_GPIO_AD_35_GPIO_MUX4_IO02 0x400E8198U, 0x5U, 0, 0, 0x400E83DCU
1137#define IOMUXC_GPIO_AD_35_KPP_COL00 0x400E8198U, 0x6U, 0, 0, 0x400E83DCU
1138#define IOMUXC_GPIO_AD_35_LPUART10_RTS_B 0x400E8198U, 0x8U, 0, 0, 0x400E83DCU
1139#define IOMUXC_GPIO_AD_35_FLEXSPI1_B_SS1_B 0x400E8198U, 0x9U, 0, 0, 0x400E83DCU
1140
1141#define IOMUXC_GPIO_SD_B1_00_USDHC1_CMD 0x400E819CU, 0x0U, 0, 0, 0x400E83E0U
1142#define IOMUXC_GPIO_SD_B1_00_XBAR1_INOUT20 0x400E819CU, 0x2U, 0x400E86D8U, 0x1U, 0x400E83E0U
1143#define IOMUXC_GPIO_SD_B1_00_GPT4_CAPTURE1 0x400E819CU, 0x3U, 0, 0, 0x400E83E0U
1144#define IOMUXC_GPIO_SD_B1_00_GPIO_MUX4_IO03 0x400E819CU, 0x5U, 0, 0, 0x400E83E0U
1145#define IOMUXC_GPIO_SD_B1_00_FLEXSPI2_A_SS0_B 0x400E819CU, 0x6U, 0, 0, 0x400E83E0U
1146#define IOMUXC_GPIO_SD_B1_00_KPP_ROW07 0x400E819CU, 0x8U, 0x400E85A8U, 0x1U, 0x400E83E0U
1147#define IOMUXC_GPIO_SD_B1_00_GPIO10_IO03 0x400E819CU, 0xAU, 0, 0, 0x400E83E0U
1148
1149#define IOMUXC_GPIO_SD_B1_01_USDHC1_CLK 0x400E81A0U, 0x0U, 0, 0, 0x400E83E4U
1150#define IOMUXC_GPIO_SD_B1_01_XBAR1_INOUT21 0x400E81A0U, 0x2U, 0x400E86DCU, 0x1U, 0x400E83E4U
1151#define IOMUXC_GPIO_SD_B1_01_GPT4_CAPTURE2 0x400E81A0U, 0x3U, 0, 0, 0x400E83E4U
1152#define IOMUXC_GPIO_SD_B1_01_GPIO_MUX4_IO04 0x400E81A0U, 0x5U, 0, 0, 0x400E83E4U
1153#define IOMUXC_GPIO_SD_B1_01_FLEXSPI2_A_SCLK 0x400E81A0U, 0x6U, 0x400E858CU, 0x1U, 0x400E83E4U
1154#define IOMUXC_GPIO_SD_B1_01_KPP_COL07 0x400E81A0U, 0x8U, 0x400E85A0U, 0x1U, 0x400E83E4U
1155#define IOMUXC_GPIO_SD_B1_01_GPIO10_IO04 0x400E81A0U, 0xAU, 0, 0, 0x400E83E4U
1156
1157#define IOMUXC_GPIO_SD_B1_02_GPIO10_IO05 0x400E81A4U, 0xAU, 0, 0, 0x400E83E8U
1158#define IOMUXC_GPIO_SD_B1_02_USDHC1_DATA0 0x400E81A4U, 0x0U, 0, 0, 0x400E83E8U
1159#define IOMUXC_GPIO_SD_B1_02_XBAR1_INOUT22 0x400E81A4U, 0x2U, 0x400E86E0U, 0x1U, 0x400E83E8U
1160#define IOMUXC_GPIO_SD_B1_02_GPT4_COMPARE1 0x400E81A4U, 0x3U, 0, 0, 0x400E83E8U
1161#define IOMUXC_GPIO_SD_B1_02_GPIO_MUX4_IO05 0x400E81A4U, 0x5U, 0, 0, 0x400E83E8U
1162#define IOMUXC_GPIO_SD_B1_02_FLEXSPI2_A_DATA00 0x400E81A4U, 0x6U, 0x400E857CU, 0x1U, 0x400E83E8U
1163#define IOMUXC_GPIO_SD_B1_02_KPP_ROW06 0x400E81A4U, 0x8U, 0x400E85A4U, 0x1U, 0x400E83E8U
1164#define IOMUXC_GPIO_SD_B1_02_FLEXSPI1_A_SS1_B 0x400E81A4U, 0x9U, 0, 0, 0x400E83E8U
1165
1166#define IOMUXC_GPIO_SD_B1_03_USDHC1_DATA1 0x400E81A8U, 0x0U, 0, 0, 0x400E83ECU
1167#define IOMUXC_GPIO_SD_B1_03_XBAR1_INOUT23 0x400E81A8U, 0x2U, 0x400E86E4U, 0x1U, 0x400E83ECU
1168#define IOMUXC_GPIO_SD_B1_03_GPT4_COMPARE2 0x400E81A8U, 0x3U, 0, 0, 0x400E83ECU
1169#define IOMUXC_GPIO_SD_B1_03_GPIO_MUX4_IO06 0x400E81A8U, 0x5U, 0, 0, 0x400E83ECU
1170#define IOMUXC_GPIO_SD_B1_03_FLEXSPI2_A_DATA01 0x400E81A8U, 0x6U, 0x400E8580U, 0x1U, 0x400E83ECU
1171#define IOMUXC_GPIO_SD_B1_03_KPP_COL06 0x400E81A8U, 0x8U, 0x400E859CU, 0x1U, 0x400E83ECU
1172#define IOMUXC_GPIO_SD_B1_03_FLEXSPI1_B_SS1_B 0x400E81A8U, 0x9U, 0, 0, 0x400E83ECU
1173#define IOMUXC_GPIO_SD_B1_03_GPIO10_IO06 0x400E81A8U, 0xAU, 0, 0, 0x400E83ECU
1174
1175#define IOMUXC_GPIO_SD_B1_04_USDHC1_DATA2 0x400E81ACU, 0x0U, 0, 0, 0x400E83F0U
1176#define IOMUXC_GPIO_SD_B1_04_XBAR1_INOUT24 0x400E81ACU, 0x2U, 0x400E86E8U, 0x1U, 0x400E83F0U
1177#define IOMUXC_GPIO_SD_B1_04_GPT4_COMPARE3 0x400E81ACU, 0x3U, 0, 0, 0x400E83F0U
1178#define IOMUXC_GPIO_SD_B1_04_GPIO_MUX4_IO07 0x400E81ACU, 0x5U, 0, 0, 0x400E83F0U
1179#define IOMUXC_GPIO_SD_B1_04_FLEXSPI2_A_DATA02 0x400E81ACU, 0x6U, 0x400E8584U, 0x1U, 0x400E83F0U
1180#define IOMUXC_GPIO_SD_B1_04_FLEXSPI1_B_SS0_B 0x400E81ACU, 0x8U, 0, 0, 0x400E83F0U
1181#define IOMUXC_GPIO_SD_B1_04_ENET_QOS_1588_EVENT2_AUX_IN 0x400E81ACU, 0x9U, 0, 0, 0x400E83F0U
1182#define IOMUXC_GPIO_SD_B1_04_GPIO10_IO07 0x400E81ACU, 0xAU, 0, 0, 0x400E83F0U
1183
1184#define IOMUXC_GPIO_SD_B1_05_GPIO10_IO08 0x400E81B0U, 0xAU, 0, 0, 0x400E83F4U
1185#define IOMUXC_GPIO_SD_B1_05_USDHC1_DATA3 0x400E81B0U, 0x0U, 0, 0, 0x400E83F4U
1186#define IOMUXC_GPIO_SD_B1_05_XBAR1_INOUT25 0x400E81B0U, 0x2U, 0x400E86ECU, 0x1U, 0x400E83F4U
1187#define IOMUXC_GPIO_SD_B1_05_GPT4_CLK 0x400E81B0U, 0x3U, 0, 0, 0x400E83F4U
1188#define IOMUXC_GPIO_SD_B1_05_GPIO_MUX4_IO08 0x400E81B0U, 0x5U, 0, 0, 0x400E83F4U
1189#define IOMUXC_GPIO_SD_B1_05_FLEXSPI2_A_DATA03 0x400E81B0U, 0x6U, 0x400E8588U, 0x1U, 0x400E83F4U
1190#define IOMUXC_GPIO_SD_B1_05_FLEXSPI1_B_DQS 0x400E81B0U, 0x8U, 0, 0, 0x400E83F4U
1191#define IOMUXC_GPIO_SD_B1_05_ENET_QOS_1588_EVENT3_AUX_IN 0x400E81B0U, 0x9U, 0, 0, 0x400E83F4U
1192
1193#define IOMUXC_GPIO_SD_B2_00_GPIO10_IO09 0x400E81B4U, 0xAU, 0, 0, 0x400E83F8U
1194#define IOMUXC_GPIO_SD_B2_00_USDHC2_DATA3 0x400E81B4U, 0x0U, 0, 0, 0x400E83F8U
1195#define IOMUXC_GPIO_SD_B2_00_FLEXSPI1_B_DATA03 0x400E81B4U, 0x1U, 0x400E8570U, 0x1U, 0x400E83F8U
1196#define IOMUXC_GPIO_SD_B2_00_ENET_1G_RX_EN 0x400E81B4U, 0x2U, 0x400E84E0U, 0x1U, 0x400E83F8U
1197#define IOMUXC_GPIO_SD_B2_00_LPUART9_TXD 0x400E81B4U, 0x3U, 0, 0, 0x400E83F8U
1198#define IOMUXC_GPIO_SD_B2_00_LPSPI4_SCK 0x400E81B4U, 0x4U, 0x400E8610U, 0x0U, 0x400E83F8U
1199#define IOMUXC_GPIO_SD_B2_00_GPIO_MUX4_IO09 0x400E81B4U, 0x5U, 0, 0, 0x400E83F8U
1200
1201#define IOMUXC_GPIO_SD_B2_01_USDHC2_DATA2 0x400E81B8U, 0x0U, 0, 0, 0x400E83FCU
1202#define IOMUXC_GPIO_SD_B2_01_FLEXSPI1_B_DATA02 0x400E81B8U, 0x1U, 0x400E856CU, 0x1U, 0x400E83FCU
1203#define IOMUXC_GPIO_SD_B2_01_ENET_1G_RX_CLK 0x400E81B8U, 0x2U, 0x400E84CCU, 0x1U, 0x400E83FCU
1204#define IOMUXC_GPIO_SD_B2_01_LPUART9_RXD 0x400E81B8U, 0x3U, 0, 0, 0x400E83FCU
1205#define IOMUXC_GPIO_SD_B2_01_LPSPI4_PCS0 0x400E81B8U, 0x4U, 0x400E860CU, 0x0U, 0x400E83FCU
1206#define IOMUXC_GPIO_SD_B2_01_GPIO_MUX4_IO10 0x400E81B8U, 0x5U, 0, 0, 0x400E83FCU
1207#define IOMUXC_GPIO_SD_B2_01_GPIO10_IO10 0x400E81B8U, 0xAU, 0, 0, 0x400E83FCU
1208
1209#define IOMUXC_GPIO_SD_B2_02_GPIO10_IO11 0x400E81BCU, 0xAU, 0, 0, 0x400E8400U
1210#define IOMUXC_GPIO_SD_B2_02_USDHC2_DATA1 0x400E81BCU, 0x0U, 0, 0, 0x400E8400U
1211#define IOMUXC_GPIO_SD_B2_02_FLEXSPI1_B_DATA01 0x400E81BCU, 0x1U, 0x400E8568U, 0x1U, 0x400E8400U
1212#define IOMUXC_GPIO_SD_B2_02_ENET_1G_RX_DATA00 0x400E81BCU, 0x2U, 0x400E84D0U, 0x1U, 0x400E8400U
1213#define IOMUXC_GPIO_SD_B2_02_LPUART9_CTS_B 0x400E81BCU, 0x3U, 0, 0, 0x400E8400U
1214#define IOMUXC_GPIO_SD_B2_02_LPSPI4_SOUT 0x400E81BCU, 0x4U, 0x400E8618U, 0x0U, 0x400E8400U
1215#define IOMUXC_GPIO_SD_B2_02_GPIO_MUX4_IO11 0x400E81BCU, 0x5U, 0, 0, 0x400E8400U
1216
1217#define IOMUXC_GPIO_SD_B2_03_GPIO10_IO12 0x400E81C0U, 0xAU, 0, 0, 0x400E8404U
1218#define IOMUXC_GPIO_SD_B2_03_USDHC2_DATA0 0x400E81C0U, 0x0U, 0, 0, 0x400E8404U
1219#define IOMUXC_GPIO_SD_B2_03_FLEXSPI1_B_DATA00 0x400E81C0U, 0x1U, 0x400E8564U, 0x1U, 0x400E8404U
1220#define IOMUXC_GPIO_SD_B2_03_ENET_1G_RX_DATA01 0x400E81C0U, 0x2U, 0x400E84D4U, 0x1U, 0x400E8404U
1221#define IOMUXC_GPIO_SD_B2_03_LPUART9_RTS_B 0x400E81C0U, 0x3U, 0, 0, 0x400E8404U
1222#define IOMUXC_GPIO_SD_B2_03_LPSPI4_SIN 0x400E81C0U, 0x4U, 0x400E8614U, 0x0U, 0x400E8404U
1223#define IOMUXC_GPIO_SD_B2_03_GPIO_MUX4_IO12 0x400E81C0U, 0x5U, 0, 0, 0x400E8404U
1224
1225#define IOMUXC_GPIO_SD_B2_04_USDHC2_CLK 0x400E81C4U, 0x0U, 0, 0, 0x400E8408U
1226#define IOMUXC_GPIO_SD_B2_04_FLEXSPI1_B_SCLK 0x400E81C4U, 0x1U, 0x400E8578U, 0x1U, 0x400E8408U
1227#define IOMUXC_GPIO_SD_B2_04_ENET_1G_RX_DATA02 0x400E81C4U, 0x2U, 0x400E84D8U, 0x1U, 0x400E8408U
1228#define IOMUXC_GPIO_SD_B2_04_FLEXSPI1_A_SS1_B 0x400E81C4U, 0x3U, 0, 0, 0x400E8408U
1229#define IOMUXC_GPIO_SD_B2_04_LPSPI4_PCS1 0x400E81C4U, 0x4U, 0, 0, 0x400E8408U
1230#define IOMUXC_GPIO_SD_B2_04_GPIO_MUX4_IO13 0x400E81C4U, 0x5U, 0, 0, 0x400E8408U
1231#define IOMUXC_GPIO_SD_B2_04_GPIO10_IO13 0x400E81C4U, 0xAU, 0, 0, 0x400E8408U
1232
1233#define IOMUXC_GPIO_SD_B2_05_GPIO10_IO14 0x400E81C8U, 0xAU, 0, 0, 0x400E840CU
1234#define IOMUXC_GPIO_SD_B2_05_USDHC2_CMD 0x400E81C8U, 0x0U, 0, 0, 0x400E840CU
1235#define IOMUXC_GPIO_SD_B2_05_FLEXSPI1_A_DQS 0x400E81C8U, 0x1U, 0x400E8550U, 0x2U, 0x400E840CU
1236#define IOMUXC_GPIO_SD_B2_05_ENET_1G_RX_DATA03 0x400E81C8U, 0x2U, 0x400E84DCU, 0x1U, 0x400E840CU
1237#define IOMUXC_GPIO_SD_B2_05_FLEXSPI1_B_SS0_B 0x400E81C8U, 0x3U, 0, 0, 0x400E840CU
1238#define IOMUXC_GPIO_SD_B2_05_LPSPI4_PCS2 0x400E81C8U, 0x4U, 0, 0, 0x400E840CU
1239#define IOMUXC_GPIO_SD_B2_05_GPIO_MUX4_IO14 0x400E81C8U, 0x5U, 0, 0, 0x400E840CU
1240
1241#define IOMUXC_GPIO_SD_B2_06_GPIO10_IO15 0x400E81CCU, 0xAU, 0, 0, 0x400E8410U
1242#define IOMUXC_GPIO_SD_B2_06_USDHC2_RESET_B 0x400E81CCU, 0x0U, 0, 0, 0x400E8410U
1243#define IOMUXC_GPIO_SD_B2_06_FLEXSPI1_A_SS0_B 0x400E81CCU, 0x1U, 0, 0, 0x400E8410U
1244#define IOMUXC_GPIO_SD_B2_06_ENET_1G_TX_DATA03 0x400E81CCU, 0x2U, 0, 0, 0x400E8410U
1245#define IOMUXC_GPIO_SD_B2_06_LPSPI4_PCS3 0x400E81CCU, 0x3U, 0, 0, 0x400E8410U
1246#define IOMUXC_GPIO_SD_B2_06_GPT6_CAPTURE1 0x400E81CCU, 0x4U, 0, 0, 0x400E8410U
1247#define IOMUXC_GPIO_SD_B2_06_GPIO_MUX4_IO15 0x400E81CCU, 0x5U, 0, 0, 0x400E8410U
1248
1249#define IOMUXC_GPIO_SD_B2_07_USDHC2_STROBE 0x400E81D0U, 0x0U, 0, 0, 0x400E8414U
1250#define IOMUXC_GPIO_SD_B2_07_FLEXSPI1_A_SCLK 0x400E81D0U, 0x1U, 0x400E8574U, 0x1U, 0x400E8414U
1251#define IOMUXC_GPIO_SD_B2_07_ENET_1G_TX_DATA02 0x400E81D0U, 0x2U, 0, 0, 0x400E8414U
1252#define IOMUXC_GPIO_SD_B2_07_LPUART3_CTS_B 0x400E81D0U, 0x3U, 0, 0, 0x400E8414U
1253#define IOMUXC_GPIO_SD_B2_07_GPT6_CAPTURE2 0x400E81D0U, 0x4U, 0, 0, 0x400E8414U
1254#define IOMUXC_GPIO_SD_B2_07_GPIO_MUX4_IO16 0x400E81D0U, 0x5U, 0, 0, 0x400E8414U
1255#define IOMUXC_GPIO_SD_B2_07_LPSPI2_SCK 0x400E81D0U, 0x6U, 0x400E85E4U, 0x1U, 0x400E8414U
1256#define IOMUXC_GPIO_SD_B2_07_ENET_TX_ER 0x400E81D0U, 0x8U, 0, 0, 0x400E8414U
1257#define IOMUXC_GPIO_SD_B2_07_ENET_QOS_REF_CLK 0x400E81D0U, 0x9U, 0x400E84A0U, 0x1U, 0x400E8414U
1258#define IOMUXC_GPIO_SD_B2_07_GPIO10_IO16 0x400E81D0U, 0xAU, 0, 0, 0x400E8414U
1259
1260#define IOMUXC_GPIO_SD_B2_08_GPIO10_IO17 0x400E81D4U, 0xAU, 0, 0, 0x400E8418U
1261#define IOMUXC_GPIO_SD_B2_08_USDHC2_DATA4 0x400E81D4U, 0x0U, 0, 0, 0x400E8418U
1262#define IOMUXC_GPIO_SD_B2_08_FLEXSPI1_A_DATA00 0x400E81D4U, 0x1U, 0x400E8554U, 0x1U, 0x400E8418U
1263#define IOMUXC_GPIO_SD_B2_08_ENET_1G_TX_DATA01 0x400E81D4U, 0x2U, 0, 0, 0x400E8418U
1264#define IOMUXC_GPIO_SD_B2_08_LPUART3_RTS_B 0x400E81D4U, 0x3U, 0, 0, 0x400E8418U
1265#define IOMUXC_GPIO_SD_B2_08_GPT6_COMPARE1 0x400E81D4U, 0x4U, 0, 0, 0x400E8418U
1266#define IOMUXC_GPIO_SD_B2_08_GPIO_MUX4_IO17 0x400E81D4U, 0x5U, 0, 0, 0x400E8418U
1267#define IOMUXC_GPIO_SD_B2_08_LPSPI2_PCS0 0x400E81D4U, 0x6U, 0x400E85DCU, 0x1U, 0x400E8418U
1268
1269#define IOMUXC_GPIO_SD_B2_09_GPIO10_IO18 0x400E81D8U, 0xAU, 0, 0, 0x400E841CU
1270#define IOMUXC_GPIO_SD_B2_09_USDHC2_DATA5 0x400E81D8U, 0x0U, 0, 0, 0x400E841CU
1271#define IOMUXC_GPIO_SD_B2_09_FLEXSPI1_A_DATA01 0x400E81D8U, 0x1U, 0x400E8558U, 0x1U, 0x400E841CU
1272#define IOMUXC_GPIO_SD_B2_09_ENET_1G_TX_DATA00 0x400E81D8U, 0x2U, 0, 0, 0x400E841CU
1273#define IOMUXC_GPIO_SD_B2_09_LPUART5_CTS_B 0x400E81D8U, 0x3U, 0, 0, 0x400E841CU
1274#define IOMUXC_GPIO_SD_B2_09_GPT6_COMPARE2 0x400E81D8U, 0x4U, 0, 0, 0x400E841CU
1275#define IOMUXC_GPIO_SD_B2_09_GPIO_MUX4_IO18 0x400E81D8U, 0x5U, 0, 0, 0x400E841CU
1276#define IOMUXC_GPIO_SD_B2_09_LPSPI2_SOUT 0x400E81D8U, 0x6U, 0x400E85ECU, 0x1U, 0x400E841CU
1277
1278#define IOMUXC_GPIO_SD_B2_10_GPIO10_IO19 0x400E81DCU, 0xAU, 0, 0, 0x400E8420U
1279#define IOMUXC_GPIO_SD_B2_10_USDHC2_DATA6 0x400E81DCU, 0x0U, 0, 0, 0x400E8420U
1280#define IOMUXC_GPIO_SD_B2_10_FLEXSPI1_A_DATA02 0x400E81DCU, 0x1U, 0x400E855CU, 0x1U, 0x400E8420U
1281#define IOMUXC_GPIO_SD_B2_10_ENET_1G_TX_EN 0x400E81DCU, 0x2U, 0, 0, 0x400E8420U
1282#define IOMUXC_GPIO_SD_B2_10_LPUART5_RTS_B 0x400E81DCU, 0x3U, 0, 0, 0x400E8420U
1283#define IOMUXC_GPIO_SD_B2_10_GPT6_COMPARE3 0x400E81DCU, 0x4U, 0, 0, 0x400E8420U
1284#define IOMUXC_GPIO_SD_B2_10_GPIO_MUX4_IO19 0x400E81DCU, 0x5U, 0, 0, 0x400E8420U
1285#define IOMUXC_GPIO_SD_B2_10_LPSPI2_SIN 0x400E81DCU, 0x6U, 0x400E85E8U, 0x1U, 0x400E8420U
1286
1287#define IOMUXC_GPIO_SD_B2_11_USDHC2_DATA7 0x400E81E0U, 0x0U, 0, 0, 0x400E8424U
1288#define IOMUXC_GPIO_SD_B2_11_FLEXSPI1_A_DATA03 0x400E81E0U, 0x1U, 0x400E8560U, 0x1U, 0x400E8424U
1289#define IOMUXC_GPIO_SD_B2_11_ENET_1G_TX_CLK_IO 0x400E81E0U, 0x2U, 0x400E84E8U, 0x1U, 0x400E8424U
1290#define IOMUXC_GPIO_SD_B2_11_ENET_1G_REF_CLK 0x400E81E0U, 0x3U, 0x400E84C4U, 0x1U, 0x400E8424U
1291#define IOMUXC_GPIO_SD_B2_11_GPT6_CLK 0x400E81E0U, 0x4U, 0, 0, 0x400E8424U
1292#define IOMUXC_GPIO_SD_B2_11_GPIO_MUX4_IO20 0x400E81E0U, 0x5U, 0, 0, 0x400E8424U
1293#define IOMUXC_GPIO_SD_B2_11_LPSPI2_PCS1 0x400E81E0U, 0x6U, 0x400E85E0U, 0x1U, 0x400E8424U
1294#define IOMUXC_GPIO_SD_B2_11_GPIO10_IO20 0x400E81E0U, 0xAU, 0, 0, 0x400E8424U
1295
1296#define IOMUXC_GPIO_DISP_B1_00_VIDEO_MUX_LCDIF_CLK 0x400E81E4U, 0x0U, 0, 0, 0x400E8428U
1297#define IOMUXC_GPIO_DISP_B1_00_ENET_1G_RX_EN 0x400E81E4U, 0x1U, 0x400E84E0U, 0x2U, 0x400E8428U
1298#define IOMUXC_GPIO_DISP_B1_00_TMR1_TIMER0 0x400E81E4U, 0x3U, 0x400E863CU, 0x2U, 0x400E8428U
1299#define IOMUXC_GPIO_DISP_B1_00_XBAR1_INOUT26 0x400E81E4U, 0x4U, 0x400E86F0U, 0x1U, 0x400E8428U
1300#define IOMUXC_GPIO_DISP_B1_00_GPIO_MUX4_IO21 0x400E81E4U, 0x5U, 0, 0, 0x400E8428U
1301#define IOMUXC_GPIO_DISP_B1_00_ENET_QOS_RX_EN 0x400E81E4U, 0x8U, 0x400E84F8U, 0x0U, 0x400E8428U
1302#define IOMUXC_GPIO_DISP_B1_00_GPIO10_IO21 0x400E81E4U, 0xAU, 0, 0, 0x400E8428U
1303
1304#define IOMUXC_GPIO_DISP_B1_01_VIDEO_MUX_LCDIF_ENABLE 0x400E81E8U, 0x0U, 0, 0, 0x400E842CU
1305#define IOMUXC_GPIO_DISP_B1_01_ENET_1G_RX_CLK 0x400E81E8U, 0x1U, 0x400E84CCU, 0x2U, 0x400E842CU
1306#define IOMUXC_GPIO_DISP_B1_01_ENET_1G_RX_ER 0x400E81E8U, 0x2U, 0x400E84E4U, 0x1U, 0x400E842CU
1307#define IOMUXC_GPIO_DISP_B1_01_TMR1_TIMER1 0x400E81E8U, 0x3U, 0x400E8640U, 0x2U, 0x400E842CU
1308#define IOMUXC_GPIO_DISP_B1_01_XBAR1_INOUT27 0x400E81E8U, 0x4U, 0x400E86F4U, 0x1U, 0x400E842CU
1309#define IOMUXC_GPIO_DISP_B1_01_GPIO_MUX4_IO22 0x400E81E8U, 0x5U, 0, 0, 0x400E842CU
1310#define IOMUXC_GPIO_DISP_B1_01_ENET_QOS_RX_CLK 0x400E81E8U, 0x8U, 0, 0, 0x400E842CU
1311#define IOMUXC_GPIO_DISP_B1_01_ENET_QOS_RX_ER 0x400E81E8U, 0x9U, 0x400E84FCU, 0x0U, 0x400E842CU
1312#define IOMUXC_GPIO_DISP_B1_01_GPIO10_IO22 0x400E81E8U, 0xAU, 0, 0, 0x400E842CU
1313
1314#define IOMUXC_GPIO_DISP_B1_02_GPIO10_IO23 0x400E81ECU, 0xAU, 0, 0, 0x400E8430U
1315#define IOMUXC_GPIO_DISP_B1_02_VIDEO_MUX_LCDIF_HSYNC 0x400E81ECU, 0x0U, 0, 0, 0x400E8430U
1316#define IOMUXC_GPIO_DISP_B1_02_ENET_1G_RX_DATA00 0x400E81ECU, 0x1U, 0x400E84D0U, 0x2U, 0x400E8430U
1317#define IOMUXC_GPIO_DISP_B1_02_LPI2C3_SCL 0x400E81ECU, 0x2U, 0x400E85BCU, 0x0U, 0x400E8430U
1318#define IOMUXC_GPIO_DISP_B1_02_TMR1_TIMER2 0x400E81ECU, 0x3U, 0x400E8644U, 0x1U, 0x400E8430U
1319#define IOMUXC_GPIO_DISP_B1_02_XBAR1_INOUT28 0x400E81ECU, 0x4U, 0x400E86F8U, 0x1U, 0x400E8430U
1320#define IOMUXC_GPIO_DISP_B1_02_GPIO_MUX4_IO23 0x400E81ECU, 0x5U, 0, 0, 0x400E8430U
1321#define IOMUXC_GPIO_DISP_B1_02_ENET_QOS_RX_DATA00 0x400E81ECU, 0x8U, 0x400E84F0U, 0x0U, 0x400E8430U
1322#define IOMUXC_GPIO_DISP_B1_02_LPUART1_TXD 0x400E81ECU, 0x9U, 0x400E8620U, 0x1U, 0x400E8430U
1323
1324#define IOMUXC_GPIO_DISP_B1_03_VIDEO_MUX_LCDIF_VSYNC 0x400E81F0U, 0x0U, 0, 0, 0x400E8434U
1325#define IOMUXC_GPIO_DISP_B1_03_ENET_1G_RX_DATA01 0x400E81F0U, 0x1U, 0x400E84D4U, 0x2U, 0x400E8434U
1326#define IOMUXC_GPIO_DISP_B1_03_LPI2C3_SDA 0x400E81F0U, 0x2U, 0x400E85C0U, 0x0U, 0x400E8434U
1327#define IOMUXC_GPIO_DISP_B1_03_TMR2_TIMER0 0x400E81F0U, 0x3U, 0x400E8648U, 0x2U, 0x400E8434U
1328#define IOMUXC_GPIO_DISP_B1_03_XBAR1_INOUT29 0x400E81F0U, 0x4U, 0x400E86FCU, 0x1U, 0x400E8434U
1329#define IOMUXC_GPIO_DISP_B1_03_GPIO_MUX4_IO24 0x400E81F0U, 0x5U, 0, 0, 0x400E8434U
1330#define IOMUXC_GPIO_DISP_B1_03_ENET_QOS_RX_DATA01 0x400E81F0U, 0x8U, 0x400E84F4U, 0x0U, 0x400E8434U
1331#define IOMUXC_GPIO_DISP_B1_03_LPUART1_RXD 0x400E81F0U, 0x9U, 0x400E861CU, 0x1U, 0x400E8434U
1332#define IOMUXC_GPIO_DISP_B1_03_GPIO10_IO24 0x400E81F0U, 0xAU, 0, 0, 0x400E8434U
1333
1334#define IOMUXC_GPIO_DISP_B1_04_VIDEO_MUX_LCDIF_DATA00 0x400E81F4U, 0x0U, 0, 0, 0x400E8438U
1335#define IOMUXC_GPIO_DISP_B1_04_ENET_1G_RX_DATA02 0x400E81F4U, 0x1U, 0x400E84D8U, 0x2U, 0x400E8438U
1336#define IOMUXC_GPIO_DISP_B1_04_LPUART4_RXD 0x400E81F4U, 0x2U, 0, 0, 0x400E8438U
1337#define IOMUXC_GPIO_DISP_B1_04_TMR2_TIMER1 0x400E81F4U, 0x3U, 0x400E864CU, 0x2U, 0x400E8438U
1338#define IOMUXC_GPIO_DISP_B1_04_XBAR1_INOUT30 0x400E81F4U, 0x4U, 0x400E8700U, 0x1U, 0x400E8438U
1339#define IOMUXC_GPIO_DISP_B1_04_GPIO_MUX4_IO25 0x400E81F4U, 0x5U, 0, 0, 0x400E8438U
1340#define IOMUXC_GPIO_DISP_B1_04_ENET_QOS_RX_DATA02 0x400E81F4U, 0x8U, 0, 0, 0x400E8438U
1341#define IOMUXC_GPIO_DISP_B1_04_LPSPI3_SCK 0x400E81F4U, 0x9U, 0x400E8600U, 0x1U, 0x400E8438U
1342#define IOMUXC_GPIO_DISP_B1_04_GPIO10_IO25 0x400E81F4U, 0xAU, 0, 0, 0x400E8438U
1343
1344#define IOMUXC_GPIO_DISP_B1_05_GPIO10_IO26 0x400E81F8U, 0xAU, 0, 0, 0x400E843CU
1345#define IOMUXC_GPIO_DISP_B1_05_VIDEO_MUX_LCDIF_DATA01 0x400E81F8U, 0x0U, 0, 0, 0x400E843CU
1346#define IOMUXC_GPIO_DISP_B1_05_ENET_1G_RX_DATA03 0x400E81F8U, 0x1U, 0x400E84DCU, 0x2U, 0x400E843CU
1347#define IOMUXC_GPIO_DISP_B1_05_LPUART4_CTS_B 0x400E81F8U, 0x2U, 0, 0, 0x400E843CU
1348#define IOMUXC_GPIO_DISP_B1_05_TMR2_TIMER2 0x400E81F8U, 0x3U, 0x400E8650U, 0x1U, 0x400E843CU
1349#define IOMUXC_GPIO_DISP_B1_05_XBAR1_INOUT31 0x400E81F8U, 0x4U, 0x400E8704U, 0x1U, 0x400E843CU
1350#define IOMUXC_GPIO_DISP_B1_05_GPIO_MUX4_IO26 0x400E81F8U, 0x5U, 0, 0, 0x400E843CU
1351#define IOMUXC_GPIO_DISP_B1_05_ENET_QOS_RX_DATA03 0x400E81F8U, 0x8U, 0, 0, 0x400E843CU
1352#define IOMUXC_GPIO_DISP_B1_05_LPSPI3_SIN 0x400E81F8U, 0x9U, 0x400E8604U, 0x1U, 0x400E843CU
1353
1354#define IOMUXC_GPIO_DISP_B1_06_VIDEO_MUX_LCDIF_DATA02 0x400E81FCU, 0x0U, 0, 0, 0x400E8440U
1355#define IOMUXC_GPIO_DISP_B1_06_ENET_1G_TX_DATA03 0x400E81FCU, 0x1U, 0, 0, 0x400E8440U
1356#define IOMUXC_GPIO_DISP_B1_06_LPUART4_TXD 0x400E81FCU, 0x2U, 0, 0, 0x400E8440U
1357#define IOMUXC_GPIO_DISP_B1_06_TMR3_TIMER0 0x400E81FCU, 0x3U, 0x400E8654U, 0x2U, 0x400E8440U
1358#define IOMUXC_GPIO_DISP_B1_06_XBAR1_INOUT32 0x400E81FCU, 0x4U, 0x400E8708U, 0x1U, 0x400E8440U
1359#define IOMUXC_GPIO_DISP_B1_06_GPIO_MUX4_IO27 0x400E81FCU, 0x5U, 0, 0, 0x400E8440U
1360#define IOMUXC_GPIO_DISP_B1_06_SRC_BT_CFG00 0x400E81FCU, 0x6U, 0, 0, 0x400E8440U
1361#define IOMUXC_GPIO_DISP_B1_06_ENET_QOS_TX_DATA03 0x400E81FCU, 0x8U, 0, 0, 0x400E8440U
1362#define IOMUXC_GPIO_DISP_B1_06_LPSPI3_SOUT 0x400E81FCU, 0x9U, 0x400E8608U, 0x1U, 0x400E8440U
1363#define IOMUXC_GPIO_DISP_B1_06_GPIO10_IO27 0x400E81FCU, 0xAU, 0, 0, 0x400E8440U
1364
1365#define IOMUXC_GPIO_DISP_B1_07_VIDEO_MUX_LCDIF_DATA03 0x400E8200U, 0x0U, 0, 0, 0x400E8444U
1366#define IOMUXC_GPIO_DISP_B1_07_ENET_1G_TX_DATA02 0x400E8200U, 0x1U, 0, 0, 0x400E8444U
1367#define IOMUXC_GPIO_DISP_B1_07_LPUART4_RTS_B 0x400E8200U, 0x2U, 0, 0, 0x400E8444U
1368#define IOMUXC_GPIO_DISP_B1_07_TMR3_TIMER1 0x400E8200U, 0x3U, 0x400E8658U, 0x2U, 0x400E8444U
1369#define IOMUXC_GPIO_DISP_B1_07_XBAR1_INOUT33 0x400E8200U, 0x4U, 0x400E870CU, 0x1U, 0x400E8444U
1370#define IOMUXC_GPIO_DISP_B1_07_GPIO_MUX4_IO28 0x400E8200U, 0x5U, 0, 0, 0x400E8444U
1371#define IOMUXC_GPIO_DISP_B1_07_SRC_BT_CFG01 0x400E8200U, 0x6U, 0, 0, 0x400E8444U
1372#define IOMUXC_GPIO_DISP_B1_07_ENET_QOS_TX_DATA02 0x400E8200U, 0x8U, 0, 0, 0x400E8444U
1373#define IOMUXC_GPIO_DISP_B1_07_LPSPI3_PCS0 0x400E8200U, 0x9U, 0x400E85F0U, 0x1U, 0x400E8444U
1374#define IOMUXC_GPIO_DISP_B1_07_GPIO10_IO28 0x400E8200U, 0xAU, 0, 0, 0x400E8444U
1375
1376#define IOMUXC_GPIO_DISP_B1_08_GPIO10_IO29 0x400E8204U, 0xAU, 0, 0, 0x400E8448U
1377#define IOMUXC_GPIO_DISP_B1_08_VIDEO_MUX_LCDIF_DATA04 0x400E8204U, 0x0U, 0, 0, 0x400E8448U
1378#define IOMUXC_GPIO_DISP_B1_08_ENET_1G_TX_DATA01 0x400E8204U, 0x1U, 0, 0, 0x400E8448U
1379#define IOMUXC_GPIO_DISP_B1_08_USDHC1_CD_B 0x400E8204U, 0x2U, 0x400E86C8U, 0x1U, 0x400E8448U
1380#define IOMUXC_GPIO_DISP_B1_08_TMR3_TIMER2 0x400E8204U, 0x3U, 0x400E865CU, 0x1U, 0x400E8448U
1381#define IOMUXC_GPIO_DISP_B1_08_XBAR1_INOUT34 0x400E8204U, 0x4U, 0x400E8710U, 0x1U, 0x400E8448U
1382#define IOMUXC_GPIO_DISP_B1_08_GPIO_MUX4_IO29 0x400E8204U, 0x5U, 0, 0, 0x400E8448U
1383#define IOMUXC_GPIO_DISP_B1_08_SRC_BT_CFG02 0x400E8204U, 0x6U, 0, 0, 0x400E8448U
1384#define IOMUXC_GPIO_DISP_B1_08_ENET_QOS_TX_DATA01 0x400E8204U, 0x8U, 0, 0, 0x400E8448U
1385#define IOMUXC_GPIO_DISP_B1_08_LPSPI3_PCS1 0x400E8204U, 0x9U, 0x400E85F4U, 0x1U, 0x400E8448U
1386
1387#define IOMUXC_GPIO_DISP_B1_09_VIDEO_MUX_LCDIF_DATA05 0x400E8208U, 0x0U, 0, 0, 0x400E844CU
1388#define IOMUXC_GPIO_DISP_B1_09_ENET_1G_TX_DATA00 0x400E8208U, 0x1U, 0, 0, 0x400E844CU
1389#define IOMUXC_GPIO_DISP_B1_09_USDHC1_WP 0x400E8208U, 0x2U, 0x400E86CCU, 0x1U, 0x400E844CU
1390#define IOMUXC_GPIO_DISP_B1_09_TMR4_TIMER0 0x400E8208U, 0x3U, 0x400E8660U, 0x2U, 0x400E844CU
1391#define IOMUXC_GPIO_DISP_B1_09_XBAR1_INOUT35 0x400E8208U, 0x4U, 0x400E8714U, 0x1U, 0x400E844CU
1392#define IOMUXC_GPIO_DISP_B1_09_GPIO_MUX4_IO30 0x400E8208U, 0x5U, 0, 0, 0x400E844CU
1393#define IOMUXC_GPIO_DISP_B1_09_SRC_BT_CFG03 0x400E8208U, 0x6U, 0, 0, 0x400E844CU
1394#define IOMUXC_GPIO_DISP_B1_09_ENET_QOS_TX_DATA00 0x400E8208U, 0x8U, 0, 0, 0x400E844CU
1395#define IOMUXC_GPIO_DISP_B1_09_LPSPI3_PCS2 0x400E8208U, 0x9U, 0x400E85F8U, 0x1U, 0x400E844CU
1396#define IOMUXC_GPIO_DISP_B1_09_GPIO10_IO30 0x400E8208U, 0xAU, 0, 0, 0x400E844CU
1397
1398#define IOMUXC_GPIO_DISP_B1_10_VIDEO_MUX_LCDIF_DATA06 0x400E820CU, 0x0U, 0, 0, 0x400E8450U
1399#define IOMUXC_GPIO_DISP_B1_10_ENET_1G_TX_EN 0x400E820CU, 0x1U, 0, 0, 0x400E8450U
1400#define IOMUXC_GPIO_DISP_B1_10_USDHC1_RESET_B 0x400E820CU, 0x2U, 0, 0, 0x400E8450U
1401#define IOMUXC_GPIO_DISP_B1_10_TMR4_TIMER1 0x400E820CU, 0x3U, 0x400E8664U, 0x2U, 0x400E8450U
1402#define IOMUXC_GPIO_DISP_B1_10_XBAR1_INOUT36 0x400E820CU, 0x4U, 0, 0, 0x400E8450U
1403#define IOMUXC_GPIO_DISP_B1_10_GPIO_MUX4_IO31 0x400E820CU, 0x5U, 0, 0, 0x400E8450U
1404#define IOMUXC_GPIO_DISP_B1_10_SRC_BT_CFG04 0x400E820CU, 0x6U, 0, 0, 0x400E8450U
1405#define IOMUXC_GPIO_DISP_B1_10_ENET_QOS_TX_EN 0x400E820CU, 0x8U, 0, 0, 0x400E8450U
1406#define IOMUXC_GPIO_DISP_B1_10_LPSPI3_PCS3 0x400E820CU, 0x9U, 0x400E85FCU, 0x1U, 0x400E8450U
1407#define IOMUXC_GPIO_DISP_B1_10_GPIO10_IO31 0x400E820CU, 0xAU, 0, 0, 0x400E8450U
1408
1409#define IOMUXC_GPIO_DISP_B1_11_VIDEO_MUX_LCDIF_DATA07 0x400E8210U, 0x0U, 0, 0, 0x400E8454U
1410#define IOMUXC_GPIO_DISP_B1_11_ENET_1G_TX_CLK_IO 0x400E8210U, 0x1U, 0x400E84E8U, 0x2U, 0x400E8454U
1411#define IOMUXC_GPIO_DISP_B1_11_ENET_1G_REF_CLK 0x400E8210U, 0x2U, 0x400E84C4U, 0x2U, 0x400E8454U
1412#define IOMUXC_GPIO_DISP_B1_11_TMR4_TIMER2 0x400E8210U, 0x3U, 0x400E8668U, 0x1U, 0x400E8454U
1413#define IOMUXC_GPIO_DISP_B1_11_XBAR1_INOUT37 0x400E8210U, 0x4U, 0, 0, 0x400E8454U
1414#define IOMUXC_GPIO_DISP_B1_11_GPIO_MUX5_IO00 0x400E8210U, 0x5U, 0, 0, 0x400E8454U
1415#define IOMUXC_GPIO_DISP_B1_11_SRC_BT_CFG05 0x400E8210U, 0x6U, 0, 0, 0x400E8454U
1416#define IOMUXC_GPIO_DISP_B1_11_ENET_QOS_TX_CLK 0x400E8210U, 0x8U, 0x400E84A4U, 0x0U, 0x400E8454U
1417#define IOMUXC_GPIO_DISP_B1_11_ENET_QOS_REF_CLK 0x400E8210U, 0x9U, 0x400E84A0U, 0x2U, 0x400E8454U
1418#define IOMUXC_GPIO_DISP_B1_11_GPIO11_IO00 0x400E8210U, 0xAU, 0, 0, 0x400E8454U
1419
1420#define IOMUXC_GPIO_DISP_B2_00_GPIO11_IO01 0x400E8214U, 0xAU, 0, 0, 0x400E8458U
1421#define IOMUXC_GPIO_DISP_B2_00_VIDEO_MUX_LCDIF_DATA08 0x400E8214U, 0x0U, 0, 0, 0x400E8458U
1422#define IOMUXC_GPIO_DISP_B2_00_WDOG1_B 0x400E8214U, 0x1U, 0, 0, 0x400E8458U
1423#define IOMUXC_GPIO_DISP_B2_00_MQS_RIGHT 0x400E8214U, 0x2U, 0, 0, 0x400E8458U
1424#define IOMUXC_GPIO_DISP_B2_00_ENET_1G_TX_ER 0x400E8214U, 0x3U, 0, 0, 0x400E8458U
1425#define IOMUXC_GPIO_DISP_B2_00_SAI1_TX_DATA03 0x400E8214U, 0x4U, 0, 0, 0x400E8458U
1426#define IOMUXC_GPIO_DISP_B2_00_GPIO_MUX5_IO01 0x400E8214U, 0x5U, 0, 0, 0x400E8458U
1427#define IOMUXC_GPIO_DISP_B2_00_SRC_BT_CFG06 0x400E8214U, 0x6U, 0, 0, 0x400E8458U
1428#define IOMUXC_GPIO_DISP_B2_00_ENET_QOS_TX_ER 0x400E8214U, 0x8U, 0, 0, 0x400E8458U
1429
1430#define IOMUXC_GPIO_DISP_B2_01_VIDEO_MUX_LCDIF_DATA09 0x400E8218U, 0x0U, 0, 0, 0x400E845CU
1431#define IOMUXC_GPIO_DISP_B2_01_USDHC1_VSELECT 0x400E8218U, 0x1U, 0, 0, 0x400E845CU
1432#define IOMUXC_GPIO_DISP_B2_01_MQS_LEFT 0x400E8218U, 0x2U, 0, 0, 0x400E845CU
1433#define IOMUXC_GPIO_DISP_B2_01_WDOG2_B 0x400E8218U, 0x3U, 0, 0, 0x400E845CU
1434#define IOMUXC_GPIO_DISP_B2_01_SAI1_TX_DATA02 0x400E8218U, 0x4U, 0, 0, 0x400E845CU
1435#define IOMUXC_GPIO_DISP_B2_01_GPIO_MUX5_IO02 0x400E8218U, 0x5U, 0, 0, 0x400E845CU
1436#define IOMUXC_GPIO_DISP_B2_01_SRC_BT_CFG07 0x400E8218U, 0x6U, 0, 0, 0x400E845CU
1437#define IOMUXC_GPIO_DISP_B2_01_EWM_OUT_B 0x400E8218U, 0x8U, 0, 0, 0x400E845CU
1438#define IOMUXC_GPIO_DISP_B2_01_CCM_ENET_REF_CLK_25M 0x400E8218U, 0x9U, 0, 0, 0x400E845CU
1439#define IOMUXC_GPIO_DISP_B2_01_GPIO11_IO02 0x400E8218U, 0xAU, 0, 0, 0x400E845CU
1440
1441#define IOMUXC_GPIO_DISP_B2_02_GPIO11_IO03 0x400E821CU, 0xAU, 0, 0, 0x400E8460U
1442#define IOMUXC_GPIO_DISP_B2_02_VIDEO_MUX_LCDIF_DATA10 0x400E821CU, 0x0U, 0, 0, 0x400E8460U
1443#define IOMUXC_GPIO_DISP_B2_02_ENET_TX_DATA00 0x400E821CU, 0x1U, 0, 0, 0x400E8460U
1444#define IOMUXC_GPIO_DISP_B2_02_PIT1_TRIGGER3 0x400E821CU, 0x2U, 0, 0, 0x400E8460U
1445#define IOMUXC_GPIO_DISP_B2_02_ARM_TRACE00 0x400E821CU, 0x3U, 0, 0, 0x400E8460U
1446#define IOMUXC_GPIO_DISP_B2_02_SAI1_TX_DATA01 0x400E821CU, 0x4U, 0, 0, 0x400E8460U
1447#define IOMUXC_GPIO_DISP_B2_02_GPIO_MUX5_IO03 0x400E821CU, 0x5U, 0, 0, 0x400E8460U
1448#define IOMUXC_GPIO_DISP_B2_02_SRC_BT_CFG08 0x400E821CU, 0x6U, 0, 0, 0x400E8460U
1449#define IOMUXC_GPIO_DISP_B2_02_ENET_QOS_TX_DATA00 0x400E821CU, 0x8U, 0, 0, 0x400E8460U
1450
1451#define IOMUXC_GPIO_DISP_B2_03_GPIO11_IO04 0x400E8220U, 0xAU, 0, 0, 0x400E8464U
1452#define IOMUXC_GPIO_DISP_B2_03_VIDEO_MUX_LCDIF_DATA11 0x400E8220U, 0x0U, 0, 0, 0x400E8464U
1453#define IOMUXC_GPIO_DISP_B2_03_ENET_TX_DATA01 0x400E8220U, 0x1U, 0, 0, 0x400E8464U
1454#define IOMUXC_GPIO_DISP_B2_03_PIT1_TRIGGER2 0x400E8220U, 0x2U, 0, 0, 0x400E8464U
1455#define IOMUXC_GPIO_DISP_B2_03_ARM_TRACE01 0x400E8220U, 0x3U, 0, 0, 0x400E8464U
1456#define IOMUXC_GPIO_DISP_B2_03_SAI1_MCLK 0x400E8220U, 0x4U, 0x400E866CU, 0x1U, 0x400E8464U
1457#define IOMUXC_GPIO_DISP_B2_03_GPIO_MUX5_IO04 0x400E8220U, 0x5U, 0, 0, 0x400E8464U
1458#define IOMUXC_GPIO_DISP_B2_03_SRC_BT_CFG09 0x400E8220U, 0x6U, 0, 0, 0x400E8464U
1459#define IOMUXC_GPIO_DISP_B2_03_ENET_QOS_TX_DATA01 0x400E8220U, 0x8U, 0, 0, 0x400E8464U
1460
1461#define IOMUXC_GPIO_DISP_B2_04_VIDEO_MUX_LCDIF_DATA12 0x400E8224U, 0x0U, 0, 0, 0x400E8468U
1462#define IOMUXC_GPIO_DISP_B2_04_ENET_TX_EN 0x400E8224U, 0x1U, 0, 0, 0x400E8468U
1463#define IOMUXC_GPIO_DISP_B2_04_PIT1_TRIGGER1 0x400E8224U, 0x2U, 0, 0, 0x400E8468U
1464#define IOMUXC_GPIO_DISP_B2_04_ARM_TRACE02 0x400E8224U, 0x3U, 0, 0, 0x400E8468U
1465#define IOMUXC_GPIO_DISP_B2_04_SAI1_RX_SYNC 0x400E8224U, 0x4U, 0x400E8678U, 0x1U, 0x400E8468U
1466#define IOMUXC_GPIO_DISP_B2_04_GPIO_MUX5_IO05 0x400E8224U, 0x5U, 0, 0, 0x400E8468U
1467#define IOMUXC_GPIO_DISP_B2_04_SRC_BT_CFG10 0x400E8224U, 0x6U, 0, 0, 0x400E8468U
1468#define IOMUXC_GPIO_DISP_B2_04_ENET_QOS_TX_EN 0x400E8224U, 0x8U, 0, 0, 0x400E8468U
1469#define IOMUXC_GPIO_DISP_B2_04_GPIO11_IO05 0x400E8224U, 0xAU, 0, 0, 0x400E8468U
1470
1471#define IOMUXC_GPIO_DISP_B2_05_GPIO11_IO06 0x400E8228U, 0xAU, 0, 0, 0x400E846CU
1472#define IOMUXC_GPIO_DISP_B2_05_VIDEO_MUX_LCDIF_DATA13 0x400E8228U, 0x0U, 0, 0, 0x400E846CU
1473#define IOMUXC_GPIO_DISP_B2_05_ENET_TX_CLK 0x400E8228U, 0x1U, 0x400E84C0U, 0x1U, 0x400E846CU
1474#define IOMUXC_GPIO_DISP_B2_05_ENET_REF_CLK 0x400E8228U, 0x2U, 0x400E84A8U, 0x1U, 0x400E846CU
1475#define IOMUXC_GPIO_DISP_B2_05_ARM_TRACE03 0x400E8228U, 0x3U, 0, 0, 0x400E846CU
1476#define IOMUXC_GPIO_DISP_B2_05_SAI1_RX_BCLK 0x400E8228U, 0x4U, 0x400E8670U, 0x1U, 0x400E846CU
1477#define IOMUXC_GPIO_DISP_B2_05_GPIO_MUX5_IO06 0x400E8228U, 0x5U, 0, 0, 0x400E846CU
1478#define IOMUXC_GPIO_DISP_B2_05_SRC_BT_CFG11 0x400E8228U, 0x6U, 0, 0, 0x400E846CU
1479#define IOMUXC_GPIO_DISP_B2_05_ENET_QOS_TX_CLK 0x400E8228U, 0x8U, 0x400E84A4U, 0x1U, 0x400E846CU
1480
1481#define IOMUXC_GPIO_DISP_B2_06_GPIO11_IO07 0x400E822CU, 0xAU, 0, 0, 0x400E8470U
1482#define IOMUXC_GPIO_DISP_B2_06_VIDEO_MUX_LCDIF_DATA14 0x400E822CU, 0x0U, 0, 0, 0x400E8470U
1483#define IOMUXC_GPIO_DISP_B2_06_ENET_RX_DATA00 0x400E822CU, 0x1U, 0x400E84B0U, 0x1U, 0x400E8470U
1484#define IOMUXC_GPIO_DISP_B2_06_LPUART7_TXD 0x400E822CU, 0x2U, 0x400E8630U, 0x1U, 0x400E8470U
1485#define IOMUXC_GPIO_DISP_B2_06_ARM_TRACE_CLK 0x400E822CU, 0x3U, 0, 0, 0x400E8470U
1486#define IOMUXC_GPIO_DISP_B2_06_SAI1_RX_DATA00 0x400E822CU, 0x4U, 0x400E8674U, 0x1U, 0x400E8470U
1487#define IOMUXC_GPIO_DISP_B2_06_GPIO_MUX5_IO07 0x400E822CU, 0x5U, 0, 0, 0x400E8470U
1488#define IOMUXC_GPIO_DISP_B2_06_ENET_QOS_RX_DATA00 0x400E822CU, 0x8U, 0x400E84F0U, 0x1U, 0x400E8470U
1489
1490#define IOMUXC_GPIO_DISP_B2_07_VIDEO_MUX_LCDIF_DATA15 0x400E8230U, 0x0U, 0, 0, 0x400E8474U
1491#define IOMUXC_GPIO_DISP_B2_07_ENET_RX_DATA01 0x400E8230U, 0x1U, 0x400E84B4U, 0x1U, 0x400E8474U
1492#define IOMUXC_GPIO_DISP_B2_07_LPUART7_RXD 0x400E8230U, 0x2U, 0x400E862CU, 0x1U, 0x400E8474U
1493#define IOMUXC_GPIO_DISP_B2_07_ARM_TRACE_SWO 0x400E8230U, 0x3U, 0, 0, 0x400E8474U
1494#define IOMUXC_GPIO_DISP_B2_07_SAI1_TX_DATA00 0x400E8230U, 0x4U, 0, 0, 0x400E8474U
1495#define IOMUXC_GPIO_DISP_B2_07_GPIO_MUX5_IO08 0x400E8230U, 0x5U, 0, 0, 0x400E8474U
1496#define IOMUXC_GPIO_DISP_B2_07_ENET_QOS_RX_DATA01 0x400E8230U, 0x8U, 0x400E84F4U, 0x1U, 0x400E8474U
1497#define IOMUXC_GPIO_DISP_B2_07_GPIO11_IO08 0x400E8230U, 0xAU, 0, 0, 0x400E8474U
1498
1499#define IOMUXC_GPIO_DISP_B2_08_GPIO11_IO09 0x400E8234U, 0xAU, 0, 0, 0x400E8478U
1500#define IOMUXC_GPIO_DISP_B2_08_VIDEO_MUX_LCDIF_DATA16 0x400E8234U, 0x0U, 0, 0, 0x400E8478U
1501#define IOMUXC_GPIO_DISP_B2_08_ENET_RX_EN 0x400E8234U, 0x1U, 0x400E84B8U, 0x1U, 0x400E8478U
1502#define IOMUXC_GPIO_DISP_B2_08_LPUART8_TXD 0x400E8234U, 0x2U, 0x400E8638U, 0x1U, 0x400E8478U
1503#define IOMUXC_GPIO_DISP_B2_08_ARM_CM7_EVENTO 0x400E8234U, 0x3U, 0, 0, 0x400E8478U
1504#define IOMUXC_GPIO_DISP_B2_08_SAI1_TX_BCLK 0x400E8234U, 0x4U, 0x400E867CU, 0x1U, 0x400E8478U
1505#define IOMUXC_GPIO_DISP_B2_08_GPIO_MUX5_IO09 0x400E8234U, 0x5U, 0, 0, 0x400E8478U
1506#define IOMUXC_GPIO_DISP_B2_08_ENET_QOS_RX_EN 0x400E8234U, 0x8U, 0x400E84F8U, 0x1U, 0x400E8478U
1507#define IOMUXC_GPIO_DISP_B2_08_LPUART1_TXD 0x400E8234U, 0x9U, 0x400E8620U, 0x2U, 0x400E8478U
1508
1509#define IOMUXC_GPIO_DISP_B2_09_GPIO11_IO10 0x400E8238U, 0xAU, 0, 0, 0x400E847CU
1510#define IOMUXC_GPIO_DISP_B2_09_VIDEO_MUX_LCDIF_DATA17 0x400E8238U, 0x0U, 0, 0, 0x400E847CU
1511#define IOMUXC_GPIO_DISP_B2_09_ENET_RX_ER 0x400E8238U, 0x1U, 0x400E84BCU, 0x1U, 0x400E847CU
1512#define IOMUXC_GPIO_DISP_B2_09_LPUART8_RXD 0x400E8238U, 0x2U, 0x400E8634U, 0x1U, 0x400E847CU
1513#define IOMUXC_GPIO_DISP_B2_09_ARM_CM7_EVENTI 0x400E8238U, 0x3U, 0, 0, 0x400E847CU
1514#define IOMUXC_GPIO_DISP_B2_09_SAI1_TX_SYNC 0x400E8238U, 0x4U, 0x400E8680U, 0x1U, 0x400E847CU
1515#define IOMUXC_GPIO_DISP_B2_09_GPIO_MUX5_IO10 0x400E8238U, 0x5U, 0, 0, 0x400E847CU
1516#define IOMUXC_GPIO_DISP_B2_09_ENET_QOS_RX_ER 0x400E8238U, 0x8U, 0x400E84FCU, 0x1U, 0x400E847CU
1517#define IOMUXC_GPIO_DISP_B2_09_LPUART1_RXD 0x400E8238U, 0x9U, 0x400E861CU, 0x2U, 0x400E847CU
1518
1519#define IOMUXC_GPIO_DISP_B2_10_GPIO11_IO11 0x400E823CU, 0xAU, 0, 0, 0x400E8480U
1520#define IOMUXC_GPIO_DISP_B2_10_VIDEO_MUX_LCDIF_DATA18 0x400E823CU, 0x0U, 0, 0, 0x400E8480U
1521#define IOMUXC_GPIO_DISP_B2_10_EMVSIM2_IO 0x400E823CU, 0x1U, 0x400E86A8U, 0x1U, 0x400E8480U
1522#define IOMUXC_GPIO_DISP_B2_10_LPUART2_TXD 0x400E823CU, 0x2U, 0, 0, 0x400E8480U
1523#define IOMUXC_GPIO_DISP_B2_10_WDOG2_RESET_B_DEB 0x400E823CU, 0x3U, 0, 0, 0x400E8480U
1524#define IOMUXC_GPIO_DISP_B2_10_XBAR1_INOUT38 0x400E823CU, 0x4U, 0, 0, 0x400E8480U
1525#define IOMUXC_GPIO_DISP_B2_10_GPIO_MUX5_IO11 0x400E823CU, 0x5U, 0, 0, 0x400E8480U
1526#define IOMUXC_GPIO_DISP_B2_10_LPI2C3_SCL 0x400E823CU, 0x6U, 0x400E85BCU, 0x1U, 0x400E8480U
1527#define IOMUXC_GPIO_DISP_B2_10_ENET_QOS_RX_ER 0x400E823CU, 0x8U, 0x400E84FCU, 0x2U, 0x400E8480U
1528#define IOMUXC_GPIO_DISP_B2_10_SPDIF_IN 0x400E823CU, 0x9U, 0x400E86B4U, 0x2U, 0x400E8480U
1529
1530#define IOMUXC_GPIO_DISP_B2_11_VIDEO_MUX_LCDIF_DATA19 0x400E8240U, 0x0U, 0, 0, 0x400E8484U
1531#define IOMUXC_GPIO_DISP_B2_11_EMVSIM2_CLK 0x400E8240U, 0x1U, 0, 0, 0x400E8484U
1532#define IOMUXC_GPIO_DISP_B2_11_LPUART2_RXD 0x400E8240U, 0x2U, 0, 0, 0x400E8484U
1533#define IOMUXC_GPIO_DISP_B2_11_WDOG1_RESET_B_DEB 0x400E8240U, 0x3U, 0, 0, 0x400E8484U
1534#define IOMUXC_GPIO_DISP_B2_11_XBAR1_INOUT39 0x400E8240U, 0x4U, 0, 0, 0x400E8484U
1535#define IOMUXC_GPIO_DISP_B2_11_GPIO_MUX5_IO12 0x400E8240U, 0x5U, 0, 0, 0x400E8484U
1536#define IOMUXC_GPIO_DISP_B2_11_LPI2C3_SDA 0x400E8240U, 0x6U, 0x400E85C0U, 0x1U, 0x400E8484U
1537#define IOMUXC_GPIO_DISP_B2_11_ENET_QOS_CRS 0x400E8240U, 0x8U, 0, 0, 0x400E8484U
1538#define IOMUXC_GPIO_DISP_B2_11_SPDIF_OUT 0x400E8240U, 0x9U, 0, 0, 0x400E8484U
1539#define IOMUXC_GPIO_DISP_B2_11_GPIO11_IO12 0x400E8240U, 0xAU, 0, 0, 0x400E8484U
1540
1541#define IOMUXC_GPIO_DISP_B2_12_GPIO11_IO13 0x400E8244U, 0xAU, 0, 0, 0x400E8488U
1542#define IOMUXC_GPIO_DISP_B2_12_VIDEO_MUX_LCDIF_DATA20 0x400E8244U, 0x0U, 0, 0, 0x400E8488U
1543#define IOMUXC_GPIO_DISP_B2_12_EMVSIM2_RST 0x400E8244U, 0x1U, 0, 0, 0x400E8488U
1544#define IOMUXC_GPIO_DISP_B2_12_FLEXCAN1_TX 0x400E8244U, 0x2U, 0, 0, 0x400E8488U
1545#define IOMUXC_GPIO_DISP_B2_12_LPUART2_CTS_B 0x400E8244U, 0x3U, 0, 0, 0x400E8488U
1546#define IOMUXC_GPIO_DISP_B2_12_XBAR1_INOUT40 0x400E8244U, 0x4U, 0, 0, 0x400E8488U
1547#define IOMUXC_GPIO_DISP_B2_12_GPIO_MUX5_IO13 0x400E8244U, 0x5U, 0, 0, 0x400E8488U
1548#define IOMUXC_GPIO_DISP_B2_12_LPI2C4_SCL 0x400E8244U, 0x6U, 0x400E85C4U, 0x1U, 0x400E8488U
1549#define IOMUXC_GPIO_DISP_B2_12_ENET_QOS_COL 0x400E8244U, 0x8U, 0, 0, 0x400E8488U
1550#define IOMUXC_GPIO_DISP_B2_12_LPSPI4_SCK 0x400E8244U, 0x9U, 0x400E8610U, 0x1U, 0x400E8488U
1551
1552#define IOMUXC_GPIO_DISP_B2_13_GPIO11_IO14 0x400E8248U, 0xAU, 0, 0, 0x400E848CU
1553#define IOMUXC_GPIO_DISP_B2_13_VIDEO_MUX_LCDIF_DATA21 0x400E8248U, 0x0U, 0, 0, 0x400E848CU
1554#define IOMUXC_GPIO_DISP_B2_13_EMVSIM2_SVEN 0x400E8248U, 0x1U, 0, 0, 0x400E848CU
1555#define IOMUXC_GPIO_DISP_B2_13_FLEXCAN1_RX 0x400E8248U, 0x2U, 0x400E8498U, 0x1U, 0x400E848CU
1556#define IOMUXC_GPIO_DISP_B2_13_LPUART2_RTS_B 0x400E8248U, 0x3U, 0, 0, 0x400E848CU
1557#define IOMUXC_GPIO_DISP_B2_13_ENET_REF_CLK 0x400E8248U, 0x4U, 0x400E84A8U, 0x2U, 0x400E848CU
1558#define IOMUXC_GPIO_DISP_B2_13_GPIO_MUX5_IO14 0x400E8248U, 0x5U, 0, 0, 0x400E848CU
1559#define IOMUXC_GPIO_DISP_B2_13_LPI2C4_SDA 0x400E8248U, 0x6U, 0x400E85C8U, 0x1U, 0x400E848CU
1560#define IOMUXC_GPIO_DISP_B2_13_ENET_QOS_1588_EVENT0_OUT 0x400E8248U, 0x8U, 0, 0, 0x400E848CU
1561#define IOMUXC_GPIO_DISP_B2_13_LPSPI4_SIN 0x400E8248U, 0x9U, 0x400E8614U, 0x1U, 0x400E848CU
1562
1563#define IOMUXC_GPIO_DISP_B2_14_GPIO_MUX5_IO15 0x400E824CU, 0x5U, 0, 0, 0x400E8490U
1564#define IOMUXC_GPIO_DISP_B2_14_FLEXCAN1_TX 0x400E824CU, 0x6U, 0, 0, 0x400E8490U
1565#define IOMUXC_GPIO_DISP_B2_14_ENET_QOS_1588_EVENT0_IN 0x400E824CU, 0x8U, 0, 0, 0x400E8490U
1566#define IOMUXC_GPIO_DISP_B2_14_LPSPI4_SOUT 0x400E824CU, 0x9U, 0x400E8618U, 0x1U, 0x400E8490U
1567#define IOMUXC_GPIO_DISP_B2_14_GPIO11_IO15 0x400E824CU, 0xAU, 0, 0, 0x400E8490U
1568#define IOMUXC_GPIO_DISP_B2_14_VIDEO_MUX_LCDIF_DATA22 0x400E824CU, 0x0U, 0, 0, 0x400E8490U
1569#define IOMUXC_GPIO_DISP_B2_14_EMVSIM2_PD 0x400E824CU, 0x1U, 0x400E86ACU, 0x1U, 0x400E8490U
1570#define IOMUXC_GPIO_DISP_B2_14_WDOG2_B 0x400E824CU, 0x2U, 0, 0, 0x400E8490U
1571#define IOMUXC_GPIO_DISP_B2_14_VIDEO_MUX_EXT_DCIC1 0x400E824CU, 0x3U, 0, 0, 0x400E8490U
1572#define IOMUXC_GPIO_DISP_B2_14_ENET_1G_REF_CLK 0x400E824CU, 0x4U, 0x400E84C4U, 0x3U, 0x400E8490U
1573
1574#define IOMUXC_GPIO_DISP_B2_15_VIDEO_MUX_LCDIF_DATA23 0x400E8250U, 0x0U, 0, 0, 0x400E8494U
1575#define IOMUXC_GPIO_DISP_B2_15_EMVSIM2_POWER_FAIL 0x400E8250U, 0x1U, 0x400E86B0U, 0x1U, 0x400E8494U
1576#define IOMUXC_GPIO_DISP_B2_15_WDOG1_B 0x400E8250U, 0x2U, 0, 0, 0x400E8494U
1577#define IOMUXC_GPIO_DISP_B2_15_VIDEO_MUX_EXT_DCIC2 0x400E8250U, 0x3U, 0, 0, 0x400E8494U
1578#define IOMUXC_GPIO_DISP_B2_15_PIT1_TRIGGER0 0x400E8250U, 0x4U, 0, 0, 0x400E8494U
1579#define IOMUXC_GPIO_DISP_B2_15_GPIO_MUX5_IO16 0x400E8250U, 0x5U, 0, 0, 0x400E8494U
1580#define IOMUXC_GPIO_DISP_B2_15_FLEXCAN1_RX 0x400E8250U, 0x6U, 0x400E8498U, 0x2U, 0x400E8494U
1581#define IOMUXC_GPIO_DISP_B2_15_ENET_QOS_1588_EVENT0_AUX_IN 0x400E8250U, 0x8U, 0, 0, 0x400E8494U
1582#define IOMUXC_GPIO_DISP_B2_15_LPSPI4_PCS0 0x400E8250U, 0x9U, 0x400E860CU, 0x1U, 0x400E8494U
1583#define IOMUXC_GPIO_DISP_B2_15_GPIO11_IO16 0x400E8250U, 0xAU, 0, 0, 0x400E8494U
1584
1586
1587#define IOMUXC_GPR_SAIMCLK_LOWBITMASK (0x7U)
1588#define IOMUXC_GPR_SAIMCLK_HIGHBITMASK (0x3U)
1589
1590typedef enum _iomuxc_gpr_saimclk
1591{
1592 kIOMUXC_GPR_SAI1MClk1Sel = IOMUXC_GPR_GPR0_SAI1_MCLK1_SEL_SHIFT,
1593 kIOMUXC_GPR_SAI1MClk2Sel = IOMUXC_GPR_GPR0_SAI1_MCLK2_SEL_SHIFT,
1594 kIOMUXC_GPR_SAI1MClk3Sel = IOMUXC_GPR_GPR0_SAI1_MCLK3_SEL_SHIFT,
1595 kIOMUXC_GPR_SAI2MClk3Sel = IOMUXC_GPR_GPR1_SAI2_MCLK3_SEL_SHIFT + 8U,
1596 kIOMUXC_GPR_SAI3MClk3Sel = IOMUXC_GPR_GPR2_SAI3_MCLK3_SEL_SHIFT + 10U,
1597} iomuxc_gpr_saimclk_t;
1598
1599typedef enum _iomuxc_mqs_pwm_oversample_rate
1600{
1601 kIOMUXC_MqsPwmOverSampleRate32 = 0, /* MQS PWM over sampling rate 32. */
1602 kIOMUXC_MqsPwmOverSampleRate64 = 1 /* MQS PWM over sampling rate 64. */
1603} iomuxc_mqs_pwm_oversample_rate_t;
1604
1605#if defined(__cplusplus)
1606extern "C" {
1607#endif /*_cplusplus */
1608
1611
1633static inline void IOMUXC_SetPinMux(uint32_t muxRegister,
1634 uint32_t muxMode,
1635 uint32_t inputRegister,
1636 uint32_t inputDaisy,
1637 uint32_t configRegister,
1638 uint32_t inputOnfield)
1639{
1640 *((volatile uint32_t *)muxRegister) =
1642
1643 if (inputRegister != 0UL)
1644 {
1645 *((volatile uint32_t *)inputRegister) = inputDaisy;
1646 }
1647}
1648
1665static inline void IOMUXC_SetPinConfig(uint32_t muxRegister,
1666 uint32_t muxMode,
1667 uint32_t inputRegister,
1668 uint32_t inputDaisy,
1669 uint32_t configRegister,
1670 uint32_t configValue)
1671{
1672 if (configRegister != 0UL)
1673 {
1674 *((volatile uint32_t *)configRegister) = configValue;
1675 }
1676}
1677
1685static inline void IOMUXC_SetSaiMClkClockSource(IOMUXC_GPR_Type *base, iomuxc_gpr_saimclk_t mclk, uint8_t clkSrc)
1686{
1687 uint32_t gpr;
1688
1689 if (mclk > kIOMUXC_GPR_SAI2MClk3Sel)
1690 {
1691 gpr = base->GPR2 & ~(IOMUXC_GPR_SAIMCLK_HIGHBITMASK);
1692 base->GPR2 = ((uint32_t)clkSrc & IOMUXC_GPR_SAIMCLK_HIGHBITMASK) | gpr;
1693 }
1694 else if (mclk > kIOMUXC_GPR_SAI1MClk3Sel)
1695 {
1696 gpr = base->GPR1 & ~(IOMUXC_GPR_SAIMCLK_HIGHBITMASK);
1697 base->GPR1 = ((uint32_t)clkSrc & IOMUXC_GPR_SAIMCLK_HIGHBITMASK) | gpr;
1698 }
1699 else if (mclk > kIOMUXC_GPR_SAI1MClk2Sel)
1700 {
1701 gpr = base->GPR0 & ~((uint32_t)IOMUXC_GPR_SAIMCLK_HIGHBITMASK << (uint32_t)mclk);
1702 base->GPR0 = (((uint32_t)clkSrc & IOMUXC_GPR_SAIMCLK_HIGHBITMASK) << (uint32_t)mclk) | gpr;
1703 }
1704 else
1705 {
1706 gpr = base->GPR0 & ~((uint32_t)IOMUXC_GPR_SAIMCLK_LOWBITMASK << (uint32_t)mclk);
1707 base->GPR0 = (((uint32_t)clkSrc & IOMUXC_GPR_SAIMCLK_LOWBITMASK) << (uint32_t)mclk) | gpr;
1708 }
1709}
1710
1717static inline void IOMUXC_MQSEnterSoftwareReset(IOMUXC_GPR_Type *base, bool enable)
1718{
1719 if (enable)
1720 {
1721 base->GPR3 |= IOMUXC_GPR_GPR3_MQS_SW_RST_MASK;
1722 }
1723 else
1724 {
1725 base->GPR3 &= ~IOMUXC_GPR_GPR3_MQS_SW_RST_MASK;
1726 }
1727}
1728
1735static inline void IOMUXC_MQSEnable(IOMUXC_GPR_Type *base, bool enable)
1736{
1737 if (enable)
1738 {
1739 base->GPR3 |= IOMUXC_GPR_GPR3_MQS_EN_MASK;
1740 }
1741 else
1742 {
1743 base->GPR3 &= ~IOMUXC_GPR_GPR3_MQS_EN_MASK;
1744 }
1745}
1746
1754
1755static inline void IOMUXC_MQSConfig(IOMUXC_GPR_Type *base, iomuxc_mqs_pwm_oversample_rate_t rate, uint8_t divider)
1756{
1757 uint32_t gpr = base->GPR3 & ~(IOMUXC_GPR_GPR3_MQS_OVERSAMPLE_MASK | IOMUXC_GPR_GPR3_MQS_CLK_DIV_MASK);
1758
1759 base->GPR3 = gpr | IOMUXC_GPR_GPR3_MQS_OVERSAMPLE(rate) | IOMUXC_GPR_GPR3_MQS_CLK_DIV(divider);
1760}
1761
1763
1764#if defined(__cplusplus)
1765}
1766#endif /*_cplusplus */
1767
1769
1770#endif /* _FSL_IOMUXC_H_ */
#define IOMUXC_GPR_GPR3_MQS_CLK_DIV(x)
Definition MIMXRT1166_cm4.h:47350
#define IOMUXC_GPR_GPR3_MQS_OVERSAMPLE(x)
Definition MIMXRT1166_cm4.h:47368
#define IOMUXC_SW_MUX_CTL_PAD_SION(x)
Definition MIMXRT1052.h:24264
#define IOMUXC_SW_MUX_CTL_PAD_MUX_MODE(x)
Definition MIMXRT1052.h:24256
Definition MIMXRT1052.h:24400
