196/* @brief Is affected by errata with ID 5641 (Module does not transmit a message that is enabled to be transmitted at a specific moment during the arbitration process). */
198/* @brief Is affected by errata with ID 5829 (FlexCAN: FlexCAN does not transmit a message that is enabled to be transmitted in a specific moment during the arbitration process). */
200/* @brief Is affected by errata with ID 6032 (FlexCAN: A frame with wrong ID or payload is transmitted into the CAN bus when the Message Buffer under transmission is either aborted or deactivated while the CAN bus is in the Bus Idle state). */
202/* @brief Is affected by errata with ID 9595 (FlexCAN: Corrupt frame possible if the Freeze Mode or the Low-Power Mode are entered during a Bus-Off state). */
253/* @brief Has register bit field REG3[REG_FBK_SEL]). */
254#define FSL_FEATURE_DCDC_HAS_REG3_FBK_SEL (0)
255
256/* EDMA module features */
257
258/* @brief Number of DMA channels (related to number of registers TCD, DCHPRI, bit fields ERQ[ERQn], EEI[EEIn], INT[INTn], ERR[ERRn], HRS[HRSn] and bit field widths ES[ERRCHN], CEEI[CEEI], SEEI[SEEI], CERQ[CERQ], SERQ[SERQ], CDNE[CDNE], SSRT[SSRT], CERR[CERR], CINT[CINT], TCDn_CITER_ELINKYES[LINKCH], TCDn_CSR[MAJORLINKCH], TCDn_BITER_ELINKYES[LINKCH]). (Valid only for eDMA modules.) */
259#define FSL_FEATURE_EDMA_MODULE_CHANNEL (32)
260/* @brief Total number of DMA channels on all modules. */
261#define FSL_FEATURE_EDMA_DMAMUX_CHANNELS (32)
262/* @brief Number of DMA channel groups (register bit fields CR[ERGA], CR[GRPnPRI], ES[GPE], DCHPRIn[GRPPRI]). (Valid only for eDMA modules.) */
473/* @brief Baud rate oversampling is available (has bit fields C4[OSR], C5[BOTHEDGE], C5[RESYNCDIS] or BAUD[OSR], BAUD[BOTHEDGE], BAUD[RESYNCDIS] if the registers are 32-bit wide). */
596/* @brief Has support of combining multiple data channel FIFOs into single channel FIFO (register bit fields TCR3[CFR], TCR4[FCOMB], TFR0[WCP], TFR1[WCP], RCR3[CFR], RCR4[FCOMB], RFR0[RCP], RFR1[RCP]). */
598/* @brief Has packing of 8-bit and 16-bit data into each 32-bit FIFO word (register bit fields TCR4[FPACK], RCR4[FPACK]). */
599#define FSL_FEATURE_SAI_HAS_FIFO_PACKING (1)
600/* @brief Configures when the SAI will continue transmitting after a FIFO error has been detected (register bit fields TCR4[FCONT], RCR4[FCONT]). */
602/* @brief Configures if the frame sync is generated internally, a frame sync is only generated when the FIFO warning flag is clear or continuously (register bit fields TCR4[ONDEM], RCR4[ONDEM]). */
603#define FSL_FEATURE_SAI_HAS_ON_DEMAND_MODE (1)
604/* @brief Simplified bit clock source and asynchronous/synchronous mode selection (register bit fields TCR2[CLKMODE], RCR2[CLKMODE]), in comparison with the exclusively implemented TCR2[SYNC,BCS,BCI,MSEL], RCR2[SYNC,BCS,BCI,MSEL]. */
605#define FSL_FEATURE_SAI_HAS_CLOCKING_MODE (0)
606/* @brief Has register for configuration of the MCLK divide ratio (register bit fields MDR[FRACT], MDR[DIVIDE]). */
