RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
mvme5500
include
bsp
GT64260eth.h
1
/* GT64260eth.h
2
3
* Copyright (c) 2002 Allegro Networks, Inc., Wasabi Systems, Inc.
4
* All rights reserved.
5
6
* RTEMS/Mvme5500 port 2004 by S. Kate Feng, <feng1@bnl.gov>,
7
8
9
10
* modification, are permitted provided that the following conditions
11
* are met:
12
* 1. Redistributions of source code must retain the above copyright
13
* notice, this list of conditions and the following disclaimer.
14
* 2. Redistributions in binary form must reproduce the above copyright
15
* notice, this list of conditions and the following disclaimer in the
16
* documentation and/or other materials provided with the distribution.
17
* 3. All advertising materials mentioning features or use of this software
18
* must display the following acknowledgement:
19
* This product includes software developed for the NetBSD Project by
20
* Allegro Networks, Inc., and Wasabi Systems, Inc.
21
* 4. The name of Allegro Networks, Inc. may not be used to endorse
22
* or promote products derived from this software without specific prior
23
* written permission.
24
* 5. The name of Wasabi Systems, Inc. may not be used to endorse
25
26
27
28
* THIS SOFTWARE IS PROVIDED BY ALLEGRO NETWORKS, INC. AND
29
* WASABI SYSTEMS, INC. ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
30
* INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
31
* AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
32
* IN NO EVENT SHALL EITHER ALLEGRO NETWORKS, INC. OR WASABI SYSTEMS, INC.
33
* BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
34
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
35
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
36
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
37
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
38
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
39
* POSSIBILITY OF SUCH DAMAGE.
40
41
42
/* Keep the ring sizes a power of two for efficiency.
43
Making the Tx ring too long decreases the effectiveness of channel
44
bonding and packet priority.
45
There are no ill effects from too-large receive rings. */
46
#define TX_RING_SIZE 32
47
#define GT_NEXTTX(x) ((x + 1) % TX_RING_SIZE )
48
#define TX_QUARTER_FULL TX_RING_SIZE/2
49
#define TX_HALF_FULL TX_RING_SIZE/2
50
#define RX_RING_SIZE 16
51
#define HASH_TABLE_SIZE 16
52
#define HASH_DRAM_SIZE HASH_TABLE_SIZE*1024
/* size of DRAM for hash table */
53
#define INTR_ERR_SIZE 16
54
55
enum
GTeth_txprio {
56
GE_TXPRIO_HI=1,
57
GE_TXPRIO_LO=0,
58
GE_TXPRIO_NONE=2
59
60
enum
GTeth_rxprio {
61
GE_RXPRIO_HI=3,
62
GE_RXPRIO_MEDHI=2,
63
GE_RXPRIO_MEDLO=1,
64
GE_RXPRIO_LO=0
65
66
67
struct
GTeth_softc
68
struct
GTeth_desc
txq_desc[TX_RING_SIZE];
/* transmit descriptor memory */
69
struct
GTeth_desc
rxq_desc[RX_RING_SIZE];
/* receive descriptor memory */
70
struct
mbuf* txq_mbuf[TX_RING_SIZE];
/* transmit buffer memory */
71
struct
mbuf* rxq_mbuf[RX_RING_SIZE];
/* receive buffer memory */
72
struct
GTeth_softc
*next_module;
73
volatile
unsigned
int
intr_errsts[INTR_ERR_SIZE];
/* capture the right intr_status */
74
unsigned
int
intr_err_ptr1;
/* ptr used in GTeth_error() */
75
unsigned
int
intr_err_ptr2;
/* ptr used in ISR */
76
struct
ifqueue txq_pendq;
/* these are ready to go to the GT */
77
unsigned
int
txq_pending;
78
unsigned
int
txq_lo;
/* next to be given to GT DMA */
79
unsigned
int
txq_fi;
/* next to be free */
80
unsigned
int
txq_to_cpu;
/* next to be returned to CPU */
81
unsigned
int
txq_ei_gapcount;
/* counter until next EI */
82
unsigned
int
txq_nactive;
/* number of active descriptors */
83
unsigned
int
txq_nintr;
/* number of txq desc. send TX_EVENT */
84
unsigned
int
txq_outptr;
/* where to put next transmit packet */
85
unsigned
int
txq_inptr;
/* start of 1st queued tx packet */
86
unsigned
int
txq_free;
/* free Tx queue slots. */
87
unsigned
txq_intrbits;
/* bits to write to EIMR */
88
unsigned
txq_esdcmrbits;
/* bits to write to ESDCMR */
89
unsigned
txq_epsrbits;
/* bits to test with EPSR */
90
91
caddr_t txq_ectdp;
/* offset to cur. tx desc ptr reg */
92
unsigned
long
txq_desc_busaddr;
/* bus addr of tx descriptors */
93
caddr_t txq_buf_busaddr;
/* bus addr of tx buffers */
94
95
struct
mbuf *rxq_curpkt;
/* mbuf for current packet */
96
struct
GTeth_desc
*rxq_head_desc;
/* rxq head descriptor */
97
unsigned
int
rxq_fi;
98
unsigned
int
rxq_active;
/* # of descriptors given to GT */
99
unsigned
rxq_intrbits;
100
unsigned
long
rxq_desc_busaddr;
/* bus addr of rx descriptors */
101
102
struct
arpcom arpcom;
/* rtems if structure, contains ifnet */
103
int
sc_macno;
/* which mac? 0, 1, or 2 */
104
105
unsigned
int
sc_tickflags;
106
#define GE_TICK_TX_IFSTART 0x0001
107
#define GE_TICK_RX_RESTART 0x0002
108
unsigned
int
sc_flags;
109
#define GE_ALLMULTI 0x0001
110
#define GE_PHYSTSCHG 0x0002
111
#define GE_RXACTIVE 0x0004
112
unsigned
sc_pcr;
/* current EPCR value */
113
unsigned
sc_pcxr;
/* current EPCXR value */
114
unsigned
sc_intrmask;
/* current EIMR value */
115
unsigned
sc_idlemask;
/* suspended EIMR bits */
116
unsigned
sc_max_frame_length;
/* maximum frame length */
117
unsigned
rx_buf_sz;
118
119
/* Hash table related members */
120
unsigned
long
long
*sc_hashtable;
121
unsigned
int
sc_hashmask;
/* 0x1ff or 0x1fff */
122
123
rtems_id
daemonTid;
124
rtems_id
daemonSync;
/* synchronization with the daemon */
125
/* statistics */
126
struct
127
volatile
unsigned
long
rxInterrupts;
128
129
volatile
unsigned
long
txInterrupts;
130
unsigned
long
txMultiBuffPacket;
131
unsigned
long
txMultiMaxLen;
132
unsigned
long
txSinglMaxLen;
133
unsigned
long
txMultiMaxLoop;
134
unsigned
long
txBuffMaxLen;
135
unsigned
long
length_errors;
136
unsigned
long
frame_errors;
137
unsigned
long
crc_errors;
138
unsigned
long
or_errors;
/* overrun error */
139
} stats;
140
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition
types.h:94
GTeth_desc
Definition
GT64260ethreg.h:61
GTeth_softc
Definition
GT64260eth.h:67
