RTEMS 6.2
25# define _dist_code z__dist_code
26# define _length_code z__length_code
27# define _tr_align z__tr_align
28# define _tr_flush_bits z__tr_flush_bits
29# define _tr_flush_block z__tr_flush_block
30# define _tr_init z__tr_init
31# define _tr_stored_block z__tr_stored_block
32# define _tr_tally z__tr_tally
33# define adler32 z_adler32
34# define adler32_combine z_adler32_combine
35# define adler32_combine64 z_adler32_combine64
36# define adler32_z z_adler32_z
38# define compress z_compress
39# define compress2 z_compress2
40# define compressBound z_compressBound
43# define crc32_combine z_crc32_combine
44# define crc32_combine64 z_crc32_combine64
45# define crc32_combine_gen z_crc32_combine_gen
46# define crc32_combine_gen64 z_crc32_combine_gen64
47# define crc32_combine_op z_crc32_combine_op
48# define crc32_z z_crc32_z
49# define deflate z_deflate
50# define deflateBound z_deflateBound
51# define deflateCopy z_deflateCopy
52# define deflateEnd z_deflateEnd
53# define deflateGetDictionary z_deflateGetDictionary
54# define deflateInit z_deflateInit
55# define deflateInit2 z_deflateInit2
56# define deflateInit2_ z_deflateInit2_
57# define deflateInit_ z_deflateInit_
58# define deflateParams z_deflateParams
59# define deflatePending z_deflatePending
60# define deflatePrime z_deflatePrime
61# define deflateReset z_deflateReset
62# define deflateResetKeep z_deflateResetKeep
63# define deflateSetDictionary z_deflateSetDictionary
64# define deflateSetHeader z_deflateSetHeader
65# define deflateTune z_deflateTune
66# define deflate_copyright z_deflate_copyright
67# define get_crc_table z_get_crc_table
69# define gz_error z_gz_error
70# define gz_intmax z_gz_intmax
71# define gz_strwinerror z_gz_strwinerror
72# define gzbuffer z_gzbuffer
73# define gzclearerr z_gzclearerr
74# define gzclose z_gzclose
75# define gzclose_r z_gzclose_r
76# define gzclose_w z_gzclose_w
77# define gzdirect z_gzdirect
78# define gzdopen z_gzdopen
80# define gzerror z_gzerror
81# define gzflush z_gzflush
82# define gzfread z_gzfread
83# define gzfwrite z_gzfwrite
84# define gzgetc z_gzgetc
85# define gzgetc_ z_gzgetc_
86# define gzgets z_gzgets
87# define gzoffset z_gzoffset
88# define gzoffset64 z_gzoffset64
89# define gzopen z_gzopen
90# define gzopen64 z_gzopen64
92# define gzopen_w z_gzopen_w
94# define gzprintf z_gzprintf
95# define gzputc z_gzputc
96# define gzputs z_gzputs
97# define gzread z_gzread
98# define gzrewind z_gzrewind
99# define gzseek z_gzseek
100# define gzseek64 z_gzseek64
101# define gzsetparams z_gzsetparams
102# define gztell z_gztell
103# define gztell64 z_gztell64
104# define gzungetc z_gzungetc
105# define gzvprintf z_gzvprintf
106# define gzwrite z_gzwrite
108# define inflate z_inflate
109# define inflateBack z_inflateBack
110# define inflateBackEnd z_inflateBackEnd
111# define inflateBackInit z_inflateBackInit
112# define inflateBackInit_ z_inflateBackInit_
113# define inflateCodesUsed z_inflateCodesUsed
114# define inflateCopy z_inflateCopy
115# define inflateEnd z_inflateEnd
116# define inflateGetDictionary z_inflateGetDictionary
117# define inflateGetHeader z_inflateGetHeader
118# define inflateInit z_inflateInit
119# define inflateInit2 z_inflateInit2
120# define inflateInit2_ z_inflateInit2_
121# define inflateInit_ z_inflateInit_
122# define inflateMark z_inflateMark
123# define inflatePrime z_inflatePrime
124# define inflateReset z_inflateReset
125# define inflateReset2 z_inflateReset2
126# define inflateResetKeep z_inflateResetKeep
127# define inflateSetDictionary z_inflateSetDictionary
128# define inflateSync z_inflateSync
129# define inflateSyncPoint z_inflateSyncPoint
130# define inflateUndermine z_inflateUndermine
131# define inflateValidate z_inflateValidate
132# define inflate_copyright z_inflate_copyright
133# define inflate_fast z_inflate_fast
134# define inflate_table z_inflate_table
136# define uncompress z_uncompress
137# define uncompress2 z_uncompress2
139# define zError z_zError
141# define zcalloc z_zcalloc
142# define zcfree z_zcfree
144# define zlibCompileFlags z_zlibCompileFlags
145# define zlibVersion z_zlibVersion
149# define Bytef z_Bytef
150# define alloc_func z_alloc_func
151# define charf z_charf
152# define free_func z_free_func
154# define gzFile z_gzFile
156# define gz_header z_gz_header
157# define gz_headerp z_gz_headerp
158# define in_func z_in_func
160# define out_func z_out_func
162# define uIntf z_uIntf
163# define uLong z_uLong
164# define uLongf z_uLongf
165# define voidp z_voidp
166# define voidpc z_voidpc
167# define voidpf z_voidpf
170# define gz_header_s z_gz_header_s
171# define internal_state z_internal_state
175#if defined(__MSDOS__) && !defined(MSDOS)
178#if (defined(OS_2) || defined(__OS2__)) && !defined(OS2)
181#if defined(_WINDOWS) && !defined(WINDOWS)
184#if defined(_WIN32) || defined(_WIN32_WCE) || defined(__WIN32__)
189#if (defined(MSDOS) || defined(OS2) || defined(WINDOWS)) && !defined(WIN32)
190# if !defined(__GNUC__) && !defined(__FLAT__) && !defined(__386__)
208#ifdef __STDC_VERSION__
212# if __STDC_VERSION__ >= 199901L
218#if !defined(STDC) && (defined(__STDC__) || defined(__cplusplus))
221#if !defined(STDC) && (defined(__GNUC__) || defined(__BORLANDC__))
224#if !defined(STDC) && (defined(MSDOS) || defined(WINDOWS) || defined(WIN32))
227#if !defined(STDC) && (defined(OS2) || defined(__HOS_AIX__))
231#if defined(__OS400__) && !defined(STDC)
241#if defined(ZLIB_CONST) && !defined(z_const)
242# define z_const const
248 typedef unsigned long z_size_t;
250# define z_longlong long long
251# if defined(NO_SIZE_T)
252 typedef unsigned NO_SIZE_T z_size_t;
255 typedef size_t z_size_t;
257 typedef unsigned long z_size_t;
265# define MAX_MEM_LEVEL 8
267# define MAX_MEM_LEVEL 9
297# define OF(args) args
304# if defined(STDC) || defined(Z_HAVE_STDARG_H)
305# define Z_ARG(args) args
307# define Z_ARG(args) ()
318# if defined(M_I86SM) || defined(M_I86MM)
327# if (defined(__SMALL__) || defined(__MEDIUM__))
338#if defined(WINDOWS) || defined(WIN32)
343# if defined(WIN32) && (!defined(__BORLANDC__) || (__BORLANDC__ >= 0x500))
345# define ZEXTERN extern __declspec(dllexport)
347# define ZEXTERN extern __declspec(dllimport)
359# ifndef WIN32_LEAN_AND_MEAN
360# define WIN32_LEAN_AND_MEAN
365# define ZEXPORT WINAPI
367# define ZEXPORTVA WINAPIV
369# define ZEXPORTVA FAR CDECL
374#if defined (__BEOS__)
377# define ZEXPORT __declspec(dllexport)
378# define ZEXPORTVA __declspec(dllexport)
380# define ZEXPORT __declspec(dllimport)
381# define ZEXPORTVA __declspec(dllimport)
387# define ZEXTERN extern
400#if !defined(__MACTYPES__)
401typedef unsigned char Byte;
403typedef unsigned int uInt;
404typedef unsigned long uLong;
408# define Bytef Byte FAR
410 typedef Byte FAR Bytef;
412typedef char FAR charf;
414typedef uInt FAR uIntf;
415typedef uLong FAR uLongf;
418 typedef void const *voidpc;
419 typedef void FAR *voidpf;
422 typedef Byte
const *voidpc;
423 typedef Byte FAR *voidpf;
428#if !defined(Z_U4) && !defined(Z_SOLO) && defined(STDC)
430# if (UINT_MAX == 0xffffffffUL)
431# define Z_U4 unsigned
432# elif (ULONG_MAX == 0xffffffffUL)
433# define Z_U4 unsigned long
434# elif (USHRT_MAX == 0xffffffffUL)
435# define Z_U4 unsigned short
444 typedef Z_U4 z_crc_t;
446 typedef unsigned long z_crc_t;
450# define Z_HAVE_UNISTD_H
454# define Z_HAVE_STDARG_H
459# include <sys/types.h>
463#if defined(STDC) || defined(Z_HAVE_STDARG_H)
481#if defined(_LARGEFILE64_SOURCE) && -_LARGEFILE64_SOURCE - -1 == 1
482# undef _LARGEFILE64_SOURCE
485#ifndef Z_HAVE_UNISTD_H
487# define Z_HAVE_UNISTD_H
490#ifndef Z_HAVE_UNISTD_H
491# if defined(_LARGEFILE64_SOURCE) && !defined(_WIN32)
492# define Z_HAVE_UNISTD_H
496# if defined(Z_HAVE_UNISTD_H)
502# define z_off_t off_t
507#if defined(_LFS64_LARGEFILE) && _LFS64_LARGEFILE-0
511#if defined(_LARGEFILE64_SOURCE) && defined(Z_LFS64)
515#if defined(_FILE_OFFSET_BITS) && _FILE_OFFSET_BITS-0 == 64 && defined(Z_LFS64)
519#if !defined(SEEK_SET) && !defined(Z_SOLO)
529#if !defined(_WIN32) && defined(Z_LARGE64)
530# define z_off64_t off64_t
532# if defined(_WIN32) && !defined(__GNUC__) && !defined(Z_SOLO)
533# define z_off64_t __int64
535# define z_off64_t z_off_t
541 #pragma map(deflateInit_,"DEIN")
542 #pragma map(deflateInit2_,"DEIN2")
543 #pragma map(deflateEnd,"DEEND")
544 #pragma map(deflateBound,"DEBND")
545 #pragma map(inflateInit_,"ININ")
546 #pragma map(inflateInit2_,"ININ2")
547 #pragma map(inflateEnd,"INEND")
548 #pragma map(inflateSync,"INSY")
549 #pragma map(inflateSetDictionary,"INSEDI")
550 #pragma map(compressBound,"CMBND")
551 #pragma map(inflate_table,"INTABL")
552 #pragma map(inflate_fast,"INFA")
553 #pragma map(inflate_copyright,"INCOPY")
