RTEMS
6.2
bsps
powerpc
qoriq
include
bsp
uart-bridge.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2011, 2015 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_POWERPC_QORIQ_UART_BRIDGE_H
37
#define LIBBSP_POWERPC_QORIQ_UART_BRIDGE_H
38
39
rtems/termiosdevice.h
40
41
bsp/intercom.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
57
typedef
struct
58
rtems_termios_device_context
base;
59
const
char
*device_path;
60
intercom_type type;
61
rtems_id
transmit_task;
62
rtems_chain_control
transmit_fifo;
63
uart_bridge_master_context
64
65
typedef
struct
66
base;
67
struct
rtems_termios_tty
*tty;
68
intercom_type type;
69
rtems_id
transmit_task;
70
rtems_chain_control
transmit_fifo;
71
uart_bridge_slave_context
72
73
bool
qoriq_uart_bridge_master_probe(
*base);
74
75
extern
const
rtems_termios_device_handler
qoriq_uart_bridge_master;
76
77
extern
const
qoriq_uart_bridge_slave;
78
81
#ifdef __cplusplus
82
83
#endif
/* __cplusplus */
84
85
#endif
/* LIBBSP_POWERPC_QORIQ_UART_BRIDGE_H */
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition:
types.h:94
intercom.h
Inter-Processor Communication API.
Termios device context.
Definition:
termiosdevice.h:68
Termios device handler.
Definition:
termiosdevice.h:100
rtems_termios_tty
Definition:
termiostypes.h:94
Definition:
uart-bridge.h:57
Definition:
uart-bridge.h:65
termiosdevice.h
This header file provides the interfaces of the RTEMS Termios Device Support.
Chain_Control
This union represents a chain control block.
Definition:
chain.h:96
