RTEMS 6.2
tx4925.h File Reference
#define TX4925_REG_BASE   0xFF1F0000
#define TX4925_CFG_CCFG   0xE000 /* Chip Configuration Register */
#define TX4925_CFG_REVID   0xE004 /* Chip Revision ID Register */
#define TX4925_CFG_PCFG   0xE008 /* Pin Configuration Register */
#define TX4925_CFG_TOEA   0xE00C /* TimeOut Error Access Address Register */
#define TX4925_CFG_PDNCTR   0xE010 /* Power Down Control Register */
#define TX4925_CFG_GARBP   0xE018 /* GBUS Arbiter Priority Register */
#define TX4925_CFG_TOCNT   0xE020 /* Timeout Count Register */
#define TX4925_CFG_DRQCTR   0xE024 /* DMA Request Control Register */
#define TX4925_CFG_CLKCTR   0xE028 /* Clock Control Register */
#define TX4925_CFG_GARBC   0xE02C /* GBUS Arbiter Control Register */
#define TX4925_CFG_RAMP   0xE030 /* Register Address Mapping Register */
#define SELCHI   0x00100000
#define SELTMR0   0x00000200
#define TX4925_TIMER0_BASE   0xF000
#define TX4925_TIMER1_BASE   0xF100
#define TX4925_TIMER2_BASE   0xF200
#define TX4925_TIMER_TCR   0x00 /* Timer Control Register */
#define TX4925_TIMER_TISR   0x04 /* Timer Interrupt Status Register */
#define TX4925_TIMER_CPRA   0x08 /* Compare Register A */
#define TX4925_TIMER_CPRB   0x0C /* Compare Register B */
#define TX4925_TIMER_ITMR   0x10 /* Interval Timer Mode Register */
#define TX4925_TIMER_CCDR   0x20 /* Divide Cycle Register */
#define TX4925_TIMER_PGMR   0x30 /* Pulse Generator Mode Register */
#define TX4925_TIMER_WTMR   0x40 /* Reserved Register */
#define TX4925_TIMER_TRR   0xF0 /* Timer Read Register */
#define TIMER_CLEAR_ENABLE_MASK   0x1
#define TIMER_INT_ENABLE_MASK   0x8000
#define FFI   0x1
#define TPIAE   0x4000
#define TPIBE   0x8000
#define TIIS   0x1
#define TPIAS   0x2
#define TPIBS   0x4
#define TWIS   0x8
#define TX4925_IRQCTL_DEN   0xF600 /* Interrupt Detection Enable Register */
#define TX4925_IRQCTL_DM0   0xF604 /* Interrupt Detection Mode Register 0 */
#define TX4925_IRQCTL_DM1   0xF608 /* Interrupt Detection Mode Register 1 */
#define TX4925_IRQCTL_LVL0   0xF610 /* Interrupt Level Register 0 */
#define TX4925_IRQCTL_LVL1   0xF614 /* Interrupt Level Register 1 */
#define TX4925_IRQCTL_LVL2   0xF618 /* Interrupt Level Register 2 */
#define TX4925_IRQCTL_LVL3   0xF61C /* Interrupt Level Register 3 */
#define TX4925_IRQCTL_LVL4   0xF620 /* Interrupt Level Register 4 */
#define TX4925_IRQCTL_LVL5   0xF624 /* Interrupt Level Register 5 */
#define TX4925_IRQCTL_LVL6   0xF628 /* Interrupt Level Register 6 */
#define TX4925_IRQCTL_LVL7   0xF62C /* Interrupt Level Register 7 */
#define TX4925_IRQCTL_MSK   0xF640 /* Interrupt Mask Register */
#define TX4925_IRQCTL_EDC   0xF660 /* Interrupt Edge Detection Clear Register */
#define TX4925_IRQCTL_PND   0xF680 /* Interrupt Pending Register */
#define TX4925_IRQCTL_CS   0xF6A0 /* Interrupt Current Status Register */
#define TX4925_IRQCTL_FLAG0   0xF510 /* Interrupt Request Flag Register 0 */
#define TX4925_IRQCTL_FLAG1   0xF514 /* Interrupt Request Flag Register 1 */
#define TX4925_IRQCTL_POL   0xF518 /* Interrupt Request Polarity Control Register */
#define TX4925_IRQCTL_RCNT   0xF51C /* Interrupt Request Control Register */
#define TX4925_IRQCTL_MASKINT   0xF520 /* Interrupt Request Internal Interrupt Mask Register */
#define TX4925_IRQCTL_MASKEXT   0xF524 /* Interrupt Request External Interrupt Mask Register */
#define TX4925_REG_READ(_base, _register)    *((volatile uint32_t *)((_base) + (_register)))
#define TX4925_REG_WRITE(_base, _register, _value)    *((volatile uint32_t *)((_base) + (_register))) = (_value)
MIPS Tx4925 specific information
