RTEMS 6.2
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
test-info.h File Reference
This header file provides interfaces of the RTEMS Test Support. More...
#include <rtems/score/atomic.h>
#include <rtems/score/smpbarrier.h>
struct  rtems_test_parallel_context
 Internal context for parallel job execution. More...
struct  rtems_test_parallel_job
 Basic parallel job description. More...
#define RTEMS_TEST_INITIAL_EXTENSION    { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension, NULL }
 Initial extension for tests.
#define TEST_STATE   RTEMS_TEST_STATE_PASS
#define RTEMS_TEST_PARALLEL_PROCESSOR_MAX   32
typedef struct rtems_test_parallel_job rtems_test_parallel_job
typedef void(* rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id)
 Worker task setup handler.
enum  RTEMS_TEST_STATE {
  RTEMS_TEST_STATE_PASS , RTEMS_TEST_STATE_FAIL , RTEMS_TEST_STATE_USER_INPUT , RTEMS_TEST_STATE_INDETERMINATE ,
  RTEMS_TEST_STATE_BENCHMARK
 Test states.
void rtems_test_fatal_extension (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code)
 Fatal extension for tests.
int rtems_test_begin (const char *name, const RTEMS_TEST_STATE state)
 Prints a begin of test message using printf().
int rtems_test_end (const char *name)
 Prints an end of test message using printf().
RTEMS_NO_RETURN void rtems_test_exit (int status)
 Exit the test without calling exit() since it closes stdin, etc and pulls in stdio code.
void rtems_test_parallel (rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count)
 Runs a bunch of jobs in parallel on all processors of the system.
void rtems_test_busy_cpu_usage (time_t seconds, long nanoseconds)
 Performs a busy loop for the specified seconds and nanoseconds based on the CPU usage of the executing thread.
RTEMS_NO_RETURN void rtems_test_run (rtems_task_argument arg, const RTEMS_TEST_STATE state)
 Runs the test cases of the RTEMS Test Framework using a default configuration in the context of a task.
void rtems_test_gcov_dump_info (void)
 Dumps the gcov information as a base64 encoded gcfn and gcda data stream using rtems_put_char().
const char rtems_test_name []
 Each test must define a test name string.
