RTEMS 6.2
Data Structures | Enumerations | Functions
#include "tx-support.h"
#include <rtems/test.h>
struct  RtemsTimerReqServerFireAfter_Entry
struct  RtemsTimerReqServerFireAfter_Context
 Test context for spec:/rtems/timer/req/server-fire-after test case. More...
enum  RtemsTimerReqServerFireAfter_Pre_Server { RtemsTimerReqServerFireAfter_Pre_Server_Init , RtemsTimerReqServerFireAfter_Pre_Server_NotInit , RtemsTimerReqServerFireAfter_Pre_Server_NA }
enum  RtemsTimerReqServerFireAfter_Pre_Ticks { RtemsTimerReqServerFireAfter_Pre_Ticks_Valid , RtemsTimerReqServerFireAfter_Pre_Ticks_Is0 , RtemsTimerReqServerFireAfter_Pre_Ticks_NA }
enum  RtemsTimerReqServerFireAfter_Pre_Routine { RtemsTimerReqServerFireAfter_Pre_Routine_Valid , RtemsTimerReqServerFireAfter_Pre_Routine_Null , RtemsTimerReqServerFireAfter_Pre_Routine_NA }
enum  RtemsTimerReqServerFireAfter_Pre_Id { RtemsTimerReqServerFireAfter_Pre_Id_Valid , RtemsTimerReqServerFireAfter_Pre_Id_Invalid , RtemsTimerReqServerFireAfter_Pre_Id_NA }
enum  RtemsTimerReqServerFireAfter_Pre_Context { RtemsTimerReqServerFireAfter_Pre_Context_None , RtemsTimerReqServerFireAfter_Pre_Context_Interrupt , RtemsTimerReqServerFireAfter_Pre_Context_Server , RtemsTimerReqServerFireAfter_Pre_Context_NA }
enum  RtemsTimerReqServerFireAfter_Pre_Clock { RtemsTimerReqServerFireAfter_Pre_Clock_None , RtemsTimerReqServerFireAfter_Pre_Clock_Ticks , RtemsTimerReqServerFireAfter_Pre_Clock_Realtime , RtemsTimerReqServerFireAfter_Pre_Clock_NA }
enum  RtemsTimerReqServerFireAfter_Pre_State { RtemsTimerReqServerFireAfter_Pre_State_Inactive , RtemsTimerReqServerFireAfter_Pre_State_Scheduled , RtemsTimerReqServerFireAfter_Pre_State_Pending , RtemsTimerReqServerFireAfter_Pre_State_NA }
enum  RtemsTimerReqServerFireAfter_Post_Status {
  RtemsTimerReqServerFireAfter_Post_Status_Ok , RtemsTimerReqServerFireAfter_Post_Status_InvId , RtemsTimerReqServerFireAfter_Post_Status_InvAddr , RtemsTimerReqServerFireAfter_Post_Status_InvNum ,
  RtemsTimerReqServerFireAfter_Post_Status_IncStat , RtemsTimerReqServerFireAfter_Post_Status_NA
enum  RtemsTimerReqServerFireAfter_Post_Context {
  RtemsTimerReqServerFireAfter_Post_Context_None , RtemsTimerReqServerFireAfter_Post_Context_Interrupt , RtemsTimerReqServerFireAfter_Post_Context_Server , RtemsTimerReqServerFireAfter_Post_Context_Nop ,
  RtemsTimerReqServerFireAfter_Post_Context_NA
enum  RtemsTimerReqServerFireAfter_Post_Clock {
  RtemsTimerReqServerFireAfter_Post_Clock_None , RtemsTimerReqServerFireAfter_Post_Clock_Ticks , RtemsTimerReqServerFireAfter_Post_Clock_Realtime , RtemsTimerReqServerFireAfter_Post_Clock_Nop ,
  RtemsTimerReqServerFireAfter_Post_Clock_NA
enum  RtemsTimerReqServerFireAfter_Post_State { RtemsTimerReqServerFireAfter_Post_State_Scheduled , RtemsTimerReqServerFireAfter_Post_State_Nop , RtemsTimerReqServerFireAfter_Post_State_NA }
enum  RtemsTimerReqServerFireAfter_Post_Interval { RtemsTimerReqServerFireAfter_Post_Interval_Param , RtemsTimerReqServerFireAfter_Post_Interval_Nop , RtemsTimerReqServerFireAfter_Post_Interval_NA }
enum  RtemsTimerReqServerFireAfter_Post_Routine { RtemsTimerReqServerFireAfter_Post_Routine_Param , RtemsTimerReqServerFireAfter_Post_Routine_Nop , RtemsTimerReqServerFireAfter_Post_Routine_NA }
enum  RtemsTimerReqServerFireAfter_Post_UserData { RtemsTimerReqServerFireAfter_Post_UserData_Param , RtemsTimerReqServerFireAfter_Post_UserData_Nop , RtemsTimerReqServerFireAfter_Post_UserData_NA }
enum  PreConditionContext {
  PRE_NONE = 0 , PRE_INTERRUPT = 1 , PRE_SERVER = 2 , PRE_NONE = 0 ,
  PRE_INTERRUPT = 1 , PRE_SERVER = 2 , PRE_NONE = 0 , PRE_INTERRUPT = 1 ,
  PRE_SERVER = 2 , PRE_NONE = 0 , PRE_INTERRUPT = 1 , PRE_SERVER = 2 ,
enum  Scheduling_Ticks {
  SCHEDULE_NONE = 0 , SCHEDULE_SOON = 1 , SCHEDULE_LATER = 2 , SCHEDULE_MAX = 5 ,
  SCHEDULE_NONE = 0 , SCHEDULE_SOON = 1 , SCHEDULE_MAX = 5 , SCHEDULE_NONE = 0 ,
  SCHEDULE_SOON = 1 , SCHEDULE_LATER = 2 , SCHEDULE_MAX = 5 , SCHEDULE_NONE = 0 ,
  SCHEDULE_VERY_SOON = 1 , SCHEDULE_SOON = 2 , SCHEDULE_LATER = 3 , SCHEDULE_MAX = 5 ,
 T_TEST_CASE_FIXTURE (RtemsTimerReqServerFireAfter, &RtemsTimerReqServerFireAfter_Fixture)
