RTEMS
6.2
libtest
t-test-rtems.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* Copyright (C) 2020 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _T_TEST_RTEMS_H
38
#define _T_TEST_RTEMS_H
39
40
rtems/score/objectimpl.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
52
Objects_Maximum
T_objects_count(
Objects_APIs
api, uint16_t cls);
53
54
void
T_objects_check(
Objects_APIs
api, uint16_t cls,
55
Objects_Maximum
*expected,
const
char
*name);
56
59
#ifdef __cplusplus
60
61
#endif
62
63
#endif
/* _T_TEST_RTEMS_H */
Objects_APIs
Objects_APIs
Definition:
object.h:195
Objects_Maximum
uint16_t Objects_Maximum
Definition:
object.h:107
objectimpl.h
This header file provides interfaces of the Object Handler which are only used by the implementation.
