RTEMS 6.2
Functions | Variables
system_stm32h7xx.h File Reference
CMSIS Cortex-Mx Device System Source File for STM32H7xx devices. More...
void SystemInit (void)
 Setup the microcontroller system. Initialize the System and update the SystemFrequency variable.
void SystemCoreClockUpdate (void)
 Update SystemCoreClock variable according to Clock Register Values. The SystemCoreClock variable contains the core clock , it can be used by the user application to setup the SysTick timer or configure other parameters.
uint32_t SystemCoreClock
 System clock frequency (core clock)
uint32_t SystemD2Clock
const uint8_t D1CorePrescTable [16]
Author
MCD Application Team
Attention
