RTEMS 6.2
stm32h7xx_ll_utils.h File Reference
Header file of UTILS LL module. More...
#include "stm32h7xx.h"
#include "stm32h7xx_ll_system.h"
#include "stm32h7xx_ll_bus.h"
struct  LL_UTILS_PLLInitTypeDef
 UTILS PLL structure definition. More...
struct  LL_UTILS_ClkInitTypeDef
 UTILS System, AHB and APB buses clock configuration structure definition. More...
#define LL_MAX_DELAY   0xFFFFFFFFU
#define UID_BASE_ADDRESS   UID_BASE
 Unique device ID register base address.
#define FLASHSIZE_BASE_ADDRESS   FLASHSIZE_BASE
 Flash size data register base address.
#define PACKAGE_BASE_ADDRESS   PACKAGE_BASE
 Package data register base address.
#define LL_UTILS_HSEBYPASS_OFF   0x00000000U
#define LL_UTILS_HSEBYPASS_ON   0x00000001U
__STATIC_INLINE uint32_t LL_GetUID_Word0 (void)
 Get Word0 of the unique device identifier (UID based on 96 bits)
__STATIC_INLINE uint32_t LL_GetUID_Word1 (void)
 Get Word1 of the unique device identifier (UID based on 96 bits)
__STATIC_INLINE uint32_t LL_GetUID_Word2 (void)
 Get Word2 of the unique device identifier (UID based on 96 bits)
__STATIC_INLINE uint32_t LL_GetFlashSize (void)
 Get Flash memory size.
__STATIC_INLINE uint32_t LL_GetPackageType (void)
 Get Package type.
__STATIC_INLINE void LL_InitTick (uint32_t HCLKFrequency, uint32_t Ticks)
 This function configures the Cortex-M SysTick source of the time base.
void LL_Init1msTick (uint32_t CPU_Frequency)
 This function configures the Cortex-M SysTick source to have 1ms time base.
void LL_mDelay (uint32_t Delay)
 This function provides accurate delay (in milliseconds) based on SysTick counter flag.
void LL_SetSystemCoreClock (uint32_t CPU_Frequency)
 This function sets directly SystemCoreClock CMSIS variable.
ErrorStatus LL_PLL_ConfigSystemClock_HSI (LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct)
 This function configures system clock at maximum frequency with HSI as clock source of the PLL.
ErrorStatus LL_PLL_ConfigSystemClock_HSE (uint32_t HSEFrequency, uint32_t HSEBypass, LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct)
 This function configures system clock with HSE as clock source of the PLL.
ErrorStatus LL_SetFlashLatency (uint32_t HCLK_Frequency)
 Update number of Flash wait states in line with new frequency and current voltage range.
Author
MCD Application Team
Attention
                   ##### How to use this driver #####
  The LL UTILS driver contains a set of generic APIs that can be
  used by user:
    (+) Device electronic signature
    (+) Timing functions
    (+) PLL configuration functions
