RTEMS 6.2
stm32h7xx_hal_usart_ex.c File Reference
Extended USART HAL module driver. This file provides firmware functions to manage the following extended functionalities of the Universal Synchronous Receiver Transmitter Peripheral (USART). More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Peripheral Control functions
Attention
             ##### USART peripheral extended features  #####
  (#) FIFO mode enabling/disabling and RX/TX FIFO threshold programming.
      -@- When USART operates in FIFO mode, FIFO mode must be enabled prior
          starting RX/TX transfers. Also RX/TX FIFO thresholds must be
          configured prior starting RX/TX transfers.
  (#) Slave mode enabling/disabling and NSS pin configuration.
      -@- When USART operates in Slave mode, Slave mode must be enabled prior
