RTEMS 6.2
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_sram.h File Reference
Header file of SRAM HAL module. More...
#include "stm32h7xx_ll_fmc.h"
struct  SRAM_HandleTypeDef
 SRAM handle Structure definition. More...
#define __HAL_SRAM_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_SRAM_STATE_RESET)
 Reset SRAM handle state.
enum  HAL_SRAM_StateTypeDef {
  HAL_SRAM_STATE_RESET = 0x00U , HAL_SRAM_STATE_READY = 0x01U , HAL_SRAM_STATE_BUSY = 0x02U , HAL_SRAM_STATE_ERROR = 0x03U ,
  HAL_SRAM_STATE_PROTECTED = 0x04U
 HAL SRAM State structures definition. More...
HAL_StatusTypeDef HAL_SRAM_Init (SRAM_HandleTypeDef *hsram, FMC_NORSRAM_TimingTypeDef *Timing, FMC_NORSRAM_TimingTypeDef *ExtTiming)
HAL_StatusTypeDef HAL_SRAM_DeInit (SRAM_HandleTypeDef *hsram)
void HAL_SRAM_MspInit (SRAM_HandleTypeDef *hsram)
void HAL_SRAM_MspDeInit (SRAM_HandleTypeDef *hsram)
HAL_StatusTypeDef HAL_SRAM_Read_8b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint8_t *pDstBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SRAM_Write_8b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint8_t *pSrcBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SRAM_Read_16b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint16_t *pDstBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SRAM_Write_16b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint16_t *pSrcBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SRAM_Read_32b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint32_t *pDstBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SRAM_Write_32b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint32_t *pSrcBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SRAM_Read_DMA (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint32_t *pDstBuffer, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SRAM_Write_DMA (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint32_t *pSrcBuffer, uint32_t BufferSize)
void HAL_SRAM_DMA_XferCpltCallback (MDMA_HandleTypeDef *hmdma)
void HAL_SRAM_DMA_XferErrorCallback (MDMA_HandleTypeDef *hmdma)
HAL_StatusTypeDef HAL_SRAM_WriteOperation_Enable (SRAM_HandleTypeDef *hsram)
HAL_StatusTypeDef HAL_SRAM_WriteOperation_Disable (SRAM_HandleTypeDef *hsram)
HAL_SRAM_StateTypeDef HAL_SRAM_GetState (const SRAM_HandleTypeDef *hsram)
Author
MCD Application Team
Attention
