RTEMS 6.2
SPI HAL module driver. This file provides firmware functions to manage the following functionalities of the Serial Peripheral Interface (SPI) peripheral: More...
#include "stm32h7xx_hal.h"SPI HAL module driver. This file provides firmware functions to manage the following functionalities of the Serial Peripheral Interface (SPI) peripheral:
##### How to use this driver #####
The SPI HAL driver can be used as follows:
(#) Declare a SPI_HandleTypeDef handle structure, for example:
SPI_HandleTypeDef hspi;
(#)Initialize the SPI low level resources by implementing the HAL_SPI_MspInit() API:
(##) Enable the SPIx interface clock
(##) SPI pins configuration
(+++) Enable the clock for the SPI GPIOs
(+++) Configure these SPI pins as alternate function push-pull
(##) NVIC configuration if you need to use interrupt process or DMA process
(+++) Configure the SPIx interrupt priority
(+++) Enable the NVIC SPI IRQ handle
(##) DMA Configuration if you need to use DMA process
(+++) Declare a DMA_HandleTypeDef handle structure for the transmit or receive Stream/Channel
(+++) Enable the DMAx clock
(+++) Configure the DMA handle parameters
(+++) Configure the DMA Tx or Rx Stream/Channel
(+++) Associate the initialized hdma_tx handle to the hspi DMA Tx or Rx handle
(+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx
(#) Program the Mode, BidirectionalMode , Data size, Baudrate Prescaler, NSS
management, Clock polarity and phase, FirstBit and CRC configuration in the hspi Init structure.
(#) Initialize the SPI registers by calling the HAL_SPI_Init() API:
(++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc)
by calling the customized HAL_SPI_MspInit() API.
Callback registration:
(#) The compilation flag USE_HAL_SPI_REGISTER_CALLBACKS when set to 1UL
allows the user to configure dynamically the driver callbacks.
Use Functions HAL_SPI_RegisterCallback() to register an interrupt callback.
Function HAL_SPI_RegisterCallback() allows to register following callbacks:
(+) TxCpltCallback : SPI Tx Completed callback
(+) RxCpltCallback : SPI Rx Completed callback
(+) TxRxCpltCallback : SPI TxRx Completed callback
(+) TxHalfCpltCallback : SPI Tx Half Completed callback
(+) RxHalfCpltCallback : SPI Rx Half Completed callback
(+) TxRxHalfCpltCallback : SPI TxRx Half Completed callback
(+) ErrorCallback : SPI Error callback
(+) AbortCpltCallback : SPI Abort callback
(+) SuspendCallback : SPI Suspend callback
(+) MspInitCallback : SPI Msp Init callback
(+) MspDeInitCallback : SPI Msp DeInit callback
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
(#) Use function HAL_SPI_UnRegisterCallback to reset a callback to the default
weak function.
HAL_SPI_UnRegisterCallback takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
By default, after the HAL_SPI_Init() and when the state is HAL_SPI_STATE_RESET
all callbacks are set to the corresponding weak functions:
examples HAL_SPI_MasterTxCpltCallback(), HAL_SPI_MasterRxCpltCallback().
Exception done for MspInit and MspDeInit functions that are
reset to the legacy weak functions in the HAL_SPI_Init()/ HAL_SPI_DeInit() only when
these callbacks are null (not registered beforehand).
If MspInit or MspDeInit are not null, the HAL_SPI_Init()/ HAL_SPI_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state.
Callbacks can be registered/unregistered in HAL_SPI_STATE_READY state only.
Exception done MspInit/MspDeInit functions that can be registered/unregistered
in HAL_SPI_STATE_READY or HAL_SPI_STATE_RESET state,
thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
Then, the user first registers the MspInit/MspDeInit user callbacks
using HAL_SPI_RegisterCallback() before calling HAL_SPI_DeInit()
or HAL_SPI_Init() function.
When The compilation define USE_HAL_PPP_REGISTER_CALLBACKS is set to 0 or not defined,
the callback registering feature is not available and weak callbacks are used.
SuspendCallback restriction:
SuspendCallback is called only when MasterReceiverAutoSusp is enabled and
EOT interrupt is activated. SuspendCallback is used in relation with functions
HAL_SPI_Transmit_IT, HAL_SPI_Receive_IT and HAL_SPI_TransmitReceive_IT.
Circular mode restriction:
(+) The DMA circular mode cannot be used when the SPI is configured in these modes:
(++) Master 2Lines RxOnly
(++) Master 1Line Rx
(+) The CRC feature is not managed when the DMA circular mode is enabled
(+) The functions HAL_SPI_DMAPause()/ HAL_SPI_DMAResume() are not supported. Return always
HAL_ERROR with ErrorCode set to HAL_SPI_ERROR_NOT_SUPPORTED.
Those functions are maintained for backward compatibility reasons.
