RTEMS 6.2
SMBUS Extended HAL module driver. This file provides firmware functions to manage the following functionalities of SMBUS Extended peripheral: More...
#include "stm32h7xx_hal.h"SMBUS Extended HAL module driver. This file provides firmware functions to manage the following functionalities of SMBUS Extended peripheral:
##### SMBUS peripheral Extended features #####
[..] Comparing to other previous devices, the SMBUS interface for STM32H7xx
devices contains the following additional features
(+) Disable or enable wakeup from Stop mode(s)
(+) Disable or enable Fast Mode Plus
##### How to use this driver #####
(#) Configure the enable or disable of SMBUS Wake Up Mode using the functions :
(++) HAL_SMBUSEx_EnableWakeUp()
(++) HAL_SMBUSEx_DisableWakeUp()
(#) Configure the enable or disable of fast mode plus driving capability using the functions :
(++) HAL_SMBUSEx_EnableFastModePlus()
(++) HAL_SMBUSEx_DisableFastModePlus()
