RTEMS 6.2
SMARTCARD HAL module driver. This file provides extended firmware functions to manage the following functionalities of the SmartCard. More...
#include "stm32h7xx_hal.h"SMARTCARD HAL module driver. This file provides extended firmware functions to manage the following functionalities of the SmartCard.
##### SMARTCARD peripheral extended features #####
The Extended SMARTCARD HAL driver can be used as follows:
(#) After having configured the SMARTCARD basic features with HAL_SMARTCARD_Init(),
then program SMARTCARD advanced features if required (TX/RX pins swap, TimeOut,
auto-retry counter,...) in the hsmartcard AdvancedInit structure.
(#) FIFO mode enabling/disabling and RX/TX FIFO threshold programming.
-@- When SMARTCARD operates in FIFO mode, FIFO mode must be enabled prior
starting RX/TX transfers. Also RX/TX FIFO thresholds must be
configured prior starting RX/TX transfers.
