RTEMS 6.2
SMARTCARD HAL module driver. This file provides firmware functions to manage the following functionalities of the SMARTCARD peripheral: More...
#include "stm32h7xx_hal.h"SMARTCARD HAL module driver. This file provides firmware functions to manage the following functionalities of the SMARTCARD peripheral:
##### How to use this driver #####
The SMARTCARD HAL driver can be used as follows:
(#) Declare a SMARTCARD_HandleTypeDef handle structure (eg. SMARTCARD_HandleTypeDef hsmartcard).
(#) Associate a USART to the SMARTCARD handle hsmartcard.
(#) Initialize the SMARTCARD low level resources by implementing the HAL_SMARTCARD_MspInit() API:
(++) Enable the USARTx interface clock.
(++) USART pins configuration:
(+++) Enable the clock for the USART GPIOs.
(+++) Configure the USART pins (TX as alternate function pull-up, RX as alternate function Input).
(++) NVIC configuration if you need to use interrupt process (HAL_SMARTCARD_Transmit_IT()
and HAL_SMARTCARD_Receive_IT() APIs):
(+++) Configure the USARTx interrupt priority.
(+++) Enable the NVIC USART IRQ handle.
(++) DMA Configuration if you need to use DMA process (HAL_SMARTCARD_Transmit_DMA()
and HAL_SMARTCARD_Receive_DMA() APIs):
(+++) Declare a DMA handle structure for the Tx/Rx channel.
(+++) Enable the DMAx interface clock.
(+++) Configure the declared DMA handle structure with the required Tx/Rx parameters.
(+++) Configure the DMA Tx/Rx channel.
(+++) Associate the initialized DMA handle to the SMARTCARD DMA Tx/Rx handle.
(+++) Configure the priority and enable the NVIC for the transfer complete
interrupt on the DMA Tx/Rx channel.
(#) Program the Baud Rate, Parity, Mode(Receiver/Transmitter), clock enabling/disabling and accordingly,
the clock parameters (parity, phase, last bit), prescaler value, guard time and NACK on transmission
error enabling or disabling in the hsmartcard handle Init structure.
(#) If required, program SMARTCARD advanced features (TX/RX pins swap, TimeOut, auto-retry counter,...)
in the hsmartcard handle AdvancedInit structure.
(#) Initialize the SMARTCARD registers by calling the HAL_SMARTCARD_Init() API:
(++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc)
by calling the customized HAL_SMARTCARD_MspInit() API.
(@) The specific SMARTCARD interrupts (Transmission complete interrupt,
RXNE interrupt and Error Interrupts) will be managed using the macros
__HAL_SMARTCARD_ENABLE_IT() and __HAL_SMARTCARD_DISABLE_IT() inside the transmit and receive process.
[..] Three operation modes are available within this driver :
*** Polling mode IO operation ***
(+) Send an amount of data in blocking mode using HAL_SMARTCARD_Transmit()
(+) Receive an amount of data in blocking mode using HAL_SMARTCARD_Receive()
*** Interrupt mode IO operation ***
(+) Send an amount of data in non-blocking mode using HAL_SMARTCARD_Transmit_IT()
(+) At transmission end of transfer HAL_SMARTCARD_TxCpltCallback() is executed and user can
add his own code by customization of function pointer HAL_SMARTCARD_TxCpltCallback()
(+) Receive an amount of data in non-blocking mode using HAL_SMARTCARD_Receive_IT()
(+) At reception end of transfer HAL_SMARTCARD_RxCpltCallback() is executed and user can
add his own code by customization of function pointer HAL_SMARTCARD_RxCpltCallback()
(+) In case of transfer Error, HAL_SMARTCARD_ErrorCallback() function is executed and user can
add his own code by customization of function pointer HAL_SMARTCARD_ErrorCallback()
*** DMA mode IO operation ***
(+) Send an amount of data in non-blocking mode (DMA) using HAL_SMARTCARD_Transmit_DMA()
(+) Receive an amount of data in non-blocking mode (DMA) using HAL_SMARTCARD_Receive_DMA()
*** SMARTCARD HAL driver macros list ***
Below the list of most used macros in SMARTCARD HAL driver.
(+) __HAL_SMARTCARD_GET_FLAG : Check whether or not the specified SMARTCARD flag is set
(+) __HAL_SMARTCARD_CLEAR_FLAG : Clear the specified SMARTCARD pending flag
(+) __HAL_SMARTCARD_ENABLE_IT: Enable the specified SMARTCARD interrupt
(+) __HAL_SMARTCARD_DISABLE_IT: Disable the specified SMARTCARD interrupt
(+) __HAL_SMARTCARD_GET_IT_SOURCE: Check whether or not the specified SMARTCARD interrupt is enabled
(@) You can refer to the SMARTCARD HAL driver header file for more useful macros
##### Callback registration #####
The compilation define USE_HAL_SMARTCARD_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Function HAL_SMARTCARD_RegisterCallback() to register a user callback.
Function HAL_SMARTCARD_RegisterCallback() allows to register following callbacks:
(+) TxCpltCallback : Tx Complete Callback.
(+) RxCpltCallback : Rx Complete Callback.
(+) ErrorCallback : Error Callback.
(+) AbortCpltCallback : Abort Complete Callback.
(+) AbortTransmitCpltCallback : Abort Transmit Complete Callback.
(+) AbortReceiveCpltCallback : Abort Receive Complete Callback.
(+) RxFifoFullCallback : Rx Fifo Full Callback.
(+) TxFifoEmptyCallback : Tx Fifo Empty Callback.
(+) MspInitCallback : SMARTCARD MspInit.
(+) MspDeInitCallback : SMARTCARD MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_SMARTCARD_UnRegisterCallback() to reset a callback to the default
weak function.
HAL_SMARTCARD_UnRegisterCallback() takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
By default, after the HAL_SMARTCARD_Init() and when the state is HAL_SMARTCARD_STATE_RESET
all callbacks are set to the corresponding weak functions:
examples HAL_SMARTCARD_TxCpltCallback(), HAL_SMARTCARD_RxCpltCallback().
Exception done for MspInit and MspDeInit functions that are respectively
reset to the legacy weak functions in the HAL_SMARTCARD_Init()
and HAL_SMARTCARD_DeInit() only when these callbacks are null (not registered beforehand).
If not, MspInit or MspDeInit are not null, the HAL_SMARTCARD_Init() and HAL_SMARTCARD_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
Callbacks can be registered/unregistered in HAL_SMARTCARD_STATE_READY state only.
Exception done MspInit/MspDeInit that can be registered/unregistered
in HAL_SMARTCARD_STATE_READY or HAL_SMARTCARD_STATE_RESET state, thus registered (user)
MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_SMARTCARD_RegisterCallback() before calling HAL_SMARTCARD_DeInit()
or HAL_SMARTCARD_Init() function.
When The compilation define USE_HAL_SMARTCARD_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available
and weak callbacks are used.
