RTEMS 6.2
Header file of RTC HAL module. More...
| struct | RTC_InitTypeDef |
| RTC Configuration Structure definition. More... | |
| struct | RTC_TimeTypeDef |
| RTC Time structure definition. More... | |
| struct | RTC_DateTypeDef |
| RTC Date structure definition. More... | |
| struct | RTC_AlarmTypeDef |
| RTC Alarm structure definition. More... | |
| struct | RTC_HandleTypeDef |
| RTC Handle Structure definition. More... | |
| #define | RTC_HOURFORMAT_24 0x00000000u |
| #define | RTC_HOURFORMAT_12 RTC_CR_FMT |
| #define | RTC_OUTPUT_DISABLE 0x00000000u |
| #define | RTC_OUTPUT_ALARMA RTC_CR_OSEL_0 |
| #define | RTC_OUTPUT_ALARMB RTC_CR_OSEL_1 |
| #define | RTC_OUTPUT_WAKEUP RTC_CR_OSEL |
| #define | RTC_OUTPUT_POLARITY_HIGH 0x00000000u |
| #define | RTC_OUTPUT_POLARITY_LOW RTC_CR_POL |
| #define | RTC_OUTPUT_TYPE_PUSHPULL RTC_OR_ALARMOUTTYPE |
| #define | RTC_OUTPUT_TYPE_OPENDRAIN 0x00000000u |
| #define | RTC_ALARM_OUTPUT_TYPE RTC_OR_ALARMOUTTYPE |
| #define | RTC_OUTPUT_REMAP_NONE 0x00000000u |
| #define | RTC_OUTPUT_REMAP_POS1 RTC_OR_OUT_RMP |
| #define | RTC_HOURFORMAT12_AM ((uint8_t)0x00) |
| #define | RTC_HOURFORMAT12_PM ((uint8_t)0x01) |
| #define | RTC_DAYLIGHTSAVING_SUB1H RTC_CR_SUB1H |
| #define | RTC_DAYLIGHTSAVING_ADD1H RTC_CR_ADD1H |
| #define | RTC_DAYLIGHTSAVING_NONE 0x00000000u |
| #define | RTC_STOREOPERATION_RESET 0x00000000u |
| #define | RTC_STOREOPERATION_SET RTC_CR_BKP |
| #define | RTC_FORMAT_BIN 0x00000000u |
| #define | RTC_FORMAT_BCD 0x00000001u |
| #define | RTC_MONTH_JANUARY ((uint8_t)0x01) |
| #define | RTC_MONTH_FEBRUARY ((uint8_t)0x02) |
| #define | RTC_MONTH_MARCH ((uint8_t)0x03) |
| #define | RTC_MONTH_APRIL ((uint8_t)0x04) |
| #define | RTC_MONTH_MAY ((uint8_t)0x05) |
| #define | RTC_MONTH_JUNE ((uint8_t)0x06) |
| #define | RTC_MONTH_JULY ((uint8_t)0x07) |
| #define | RTC_MONTH_AUGUST ((uint8_t)0x08) |
| #define | RTC_MONTH_SEPTEMBER ((uint8_t)0x09) |
| #define | RTC_MONTH_OCTOBER ((uint8_t)0x10) |
| #define | RTC_MONTH_NOVEMBER ((uint8_t)0x11) |
| #define | RTC_MONTH_DECEMBER ((uint8_t)0x12) |
| #define | RTC_WEEKDAY_MONDAY ((uint8_t)0x01) |
| #define | RTC_WEEKDAY_TUESDAY ((uint8_t)0x02) |
| #define | RTC_WEEKDAY_WEDNESDAY ((uint8_t)0x03) |
| #define | RTC_WEEKDAY_THURSDAY ((uint8_t)0x04) |
| #define | RTC_WEEKDAY_FRIDAY ((uint8_t)0x05) |
| #define | RTC_WEEKDAY_SATURDAY ((uint8_t)0x06) |
| #define | RTC_WEEKDAY_SUNDAY ((uint8_t)0x07) |
| #define | RTC_ALARMDATEWEEKDAYSEL_DATE 0x00000000u |
| #define | RTC_ALARMDATEWEEKDAYSEL_WEEKDAY RTC_ALRMAR_WDSEL |
| #define | RTC_ALARMMASK_NONE 0x00000000u |
| #define | RTC_ALARMMASK_DATEWEEKDAY RTC_ALRMAR_MSK4 |
| #define | RTC_ALARMMASK_HOURS RTC_ALRMAR_MSK3 |
| #define | RTC_ALARMMASK_MINUTES RTC_ALRMAR_MSK2 |
| #define | RTC_ALARMMASK_SECONDS RTC_ALRMAR_MSK1 |
| #define | RTC_ALARMMASK_ALL |
| #define | RTC_ALARM_A RTC_CR_ALRAE |
| #define | RTC_ALARM_B RTC_CR_ALRBE |
| #define | RTC_ALARMSUBSECONDMASK_ALL 0x00000000u |
| #define | RTC_ALARMSUBSECONDMASK_SS14_1 RTC_ALRMASSR_MASKSS_0 |
| #define | RTC_ALARMSUBSECONDMASK_SS14_2 RTC_ALRMASSR_MASKSS_1 |
| #define | RTC_ALARMSUBSECONDMASK_SS14_3 (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_1) |
| #define | RTC_ALARMSUBSECONDMASK_SS14_4 RTC_ALRMASSR_MASKSS_2 |
| #define | RTC_ALARMSUBSECONDMASK_SS14_5 (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_2) |
| #define | RTC_ALARMSUBSECONDMASK_SS14_6 (RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_2) |
| #define | RTC_ALARMSUBSECONDMASK_SS14_7 (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_2) |
| #define | RTC_ALARMSUBSECONDMASK_SS14_8 RTC_ALRMASSR_MASKSS_3 |
| #define | RTC_ALARMSUBSECONDMASK_SS14_9 (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_3) |
| #define | RTC_ALARMSUBSECONDMASK_SS14_10 (RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_3) |
| #define | RTC_ALARMSUBSECONDMASK_SS14_11 (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_3) |
| #define | RTC_ALARMSUBSECONDMASK_SS14_12 (RTC_ALRMASSR_MASKSS_2 | RTC_ALRMASSR_MASKSS_3) |
| #define | RTC_ALARMSUBSECONDMASK_SS14_13 (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_2 | RTC_ALRMASSR_MASKSS_3) |
| #define | RTC_ALARMSUBSECONDMASK_SS14 (RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_2 | RTC_ALRMASSR_MASKSS_3) |
| #define | RTC_ALARMSUBSECONDMASK_NONE RTC_ALRMASSR_MASKSS |
| #define | RTC_IT_TS RTC_CR_TSIE |
| #define | RTC_IT_WUT RTC_CR_WUTIE |
| #define | RTC_IT_ALRA RTC_CR_ALRAIE |
| #define | RTC_IT_ALRB RTC_CR_ALRBIE |
| #define | RTC_FLAG_RECALPF RTC_ISR_RECALPF |
| #define | RTC_FLAG_TSOVF RTC_ISR_TSOVF |
| #define | RTC_FLAG_TSF RTC_ISR_TSF |
| #define | RTC_FLAG_ITSF RTC_ISR_ITSF |
| #define | RTC_FLAG_WUTF RTC_ISR_WUTF |
| #define | RTC_FLAG_ALRBF RTC_ISR_ALRBF |
| #define | RTC_FLAG_ALRAF RTC_ISR_ALRAF |
| #define | RTC_FLAG_INITF RTC_ISR_INITF |
| #define | RTC_FLAG_RSF RTC_ISR_RSF |
| #define | RTC_FLAG_INITS RTC_ISR_INITS |
| #define | RTC_FLAG_SHPF RTC_ISR_SHPF |
| #define | RTC_FLAG_WUTWF RTC_ISR_WUTWF |
| #define | RTC_FLAG_ALRBWF RTC_ISR_ALRBWF |
| #define | RTC_FLAG_ALRAWF RTC_ISR_ALRAWF |
| #define | __HAL_RTC_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_RTC_STATE_RESET) |
| Reset RTC handle state. | |
| #define | __HAL_RTC_WRITEPROTECTION_DISABLE(__HANDLE__) |
| Disable the write protection for RTC registers. | |
| #define | __HAL_RTC_WRITEPROTECTION_ENABLE(__HANDLE__) |
| Enable the write protection for RTC registers. | |
| #define | __HAL_RTC_IS_CALENDAR_INITIALIZED(__HANDLE__) (((((__HANDLE__)->Instance->ISR) & (RTC_FLAG_INITS)) == RTC_FLAG_INITS) ? 1U : 0U) |
| Check whether the RTC Calendar is initialized. | |
| #define | __HAL_RTC_DAYLIGHT_SAVING_TIME_ADD1H(__HANDLE__, __BKP__) |
| Add 1 hour (summer time change). | |
| #define | __HAL_RTC_DAYLIGHT_SAVING_TIME_SUB1H(__HANDLE__, __BKP__) |
| Subtract 1 hour (winter time change). | |
| #define | __HAL_RTC_ALARMA_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= (RTC_CR_ALRAE)) |
| Enable the RTC ALARMA peripheral. | |
| #define | __HAL_RTC_ALARMA_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRAE)) |
| Disable the RTC ALARMA peripheral. | |
| #define | __HAL_RTC_ALARMB_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= (RTC_CR_ALRBE)) |
| Enable the RTC ALARMB peripheral. | |
| #define | __HAL_RTC_ALARMB_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRBE)) |
| Disable the RTC ALARMB peripheral. | |
| #define | __HAL_RTC_ALARM_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR |= (__INTERRUPT__)) |
| Enable the RTC Alarm interrupt. | |
| #define | __HAL_RTC_ALARM_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__)) |
| Disable the RTC Alarm interrupt. | |
| #define | __HAL_RTC_ALARM_GET_IT(__HANDLE__, __INTERRUPT__) (((((__HANDLE__)->Instance->ISR)& (__INTERRUPT__ >> 4)) != 0U)? 1U : 0U) |
| Check whether the specified RTC Alarm interrupt has occurred or not. | |
| #define | __HAL_RTC_ALARM_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) (((((__HANDLE__)->Instance->CR) & (__INTERRUPT__)) != 0U) ? 1U : 0U) |
| Check whether the specified RTC Alarm interrupt has been enabled or not. | |
| #define | __HAL_RTC_ALARM_GET_FLAG(__HANDLE__, __FLAG__) (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U) |
| Get the selected RTC Alarm's flag status. | |
| #define | __HAL_RTC_ALARM_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ISR = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT))) |
| Clear the RTC Alarm's pending flags. | |
| #define | __HAL_RTC_ALARM_EXTI_ENABLE_IT() (EXTI->IMR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
| Enable interrupt on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_DISABLE_IT() (EXTI->IMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
| Disable interrupt on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_ENABLE_EVENT() (EXTI->EMR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
| Enable event on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_DISABLE_EVENT() (EXTI->EMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
| Disable event on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_ENABLE_FALLING_EDGE() (EXTI->FTSR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
| Enable falling edge trigger on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_DISABLE_FALLING_EDGE() (EXTI->FTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
| Disable falling edge trigger on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_ENABLE_RISING_EDGE() (EXTI->RTSR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
| Enable rising edge trigger on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_DISABLE_RISING_EDGE() (EXTI->RTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
| Disable rising edge trigger on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_ENABLE_RISING_FALLING_EDGE() |
| Enable rising & falling edge trigger on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_DISABLE_RISING_FALLING_EDGE() |
| Disable rising & falling edge trigger on the RTC Alarm associated Exti line. | |
| #define | __HAL_RTC_ALARM_EXTI_GET_FLAG() (EXTI->PR1 & RTC_EXTI_LINE_ALARM_EVENT) |
| Check whether the RTC Alarm associated Exti line interrupt flag is set or not. | |
| #define | __HAL_RTC_ALARM_EXTI_CLEAR_FLAG() (EXTI->PR1 = (RTC_EXTI_LINE_ALARM_EVENT)) |
| Clear the RTC Alarm associated Exti line flag. | |
| #define | __HAL_RTC_ALARM_EXTI_GENERATE_SWIT() (EXTI->SWIER1 |= RTC_EXTI_LINE_ALARM_EVENT) |
| Generate a Software interrupt on RTC Alarm associated Exti line. | |
| #define | RTC_TR_RESERVED_MASK |
| #define | RTC_DR_RESERVED_MASK |
| #define | RTC_INIT_MASK 0xFFFFFFFFu |
| #define | RTC_ISR_RESERVED_MASK 0x0003FFFFu |
| #define | RTC_RSF_MASK (~(RTC_ISR_INIT | RTC_ISR_RSF)) |
| #define | RTC_TIMEOUT_VALUE 1000u |
| #define | RTC_EXTI_LINE_ALARM_EVENT EXTI_IMR1_IM17 |
| #define | IS_RTC_OUTPUT(OUTPUT) |
| #define | IS_RTC_HOUR_FORMAT(FORMAT) |
| #define | IS_RTC_OUTPUT_POL(POL) |
| #define | IS_RTC_OUTPUT_TYPE(TYPE) |
| #define | IS_RTC_OUTPUT_REMAP(REMAP) |
| #define | IS_RTC_HOURFORMAT12(PM) |
| #define | IS_RTC_DAYLIGHT_SAVING(SAVE) |
| #define | IS_RTC_STORE_OPERATION(OPERATION) |
| #define | IS_RTC_FORMAT(FORMAT) |
| #define | IS_RTC_YEAR(YEAR) ((YEAR) <= 99u) |
| #define | IS_RTC_MONTH(MONTH) (((MONTH) >= 1u) && ((MONTH) <= 12u)) |
| #define | IS_RTC_DATE(DATE) (((DATE) >= 1u) && ((DATE) <= 31u)) |
| #define | IS_RTC_WEEKDAY(WEEKDAY) |
| #define | IS_RTC_ALARM_DATE_WEEKDAY_DATE(DATE) (((DATE) > 0u) && ((DATE) <= 31u)) |
| #define | IS_RTC_ALARM_DATE_WEEKDAY_WEEKDAY(WEEKDAY) |
| #define | IS_RTC_ALARM_DATE_WEEKDAY_SEL(SEL) |
| #define | IS_RTC_ALARM_MASK(MASK) (((MASK) & ~(RTC_ALARMMASK_ALL)) == 0u) |
| #define | IS_RTC_ALARM(ALARM) |
| #define | IS_RTC_ALARM_SUB_SECOND_VALUE(VALUE) ((VALUE) <= RTC_ALRMASSR_SS) |
| #define | IS_RTC_ALARM_SUB_SECOND_MASK(MASK) |
| #define | IS_RTC_ASYNCH_PREDIV(PREDIV) ((PREDIV) <= (RTC_PRER_PREDIV_A >> RTC_PRER_PREDIV_A_Pos)) |
| #define | IS_RTC_SYNCH_PREDIV(PREDIV) ((PREDIV) <= (RTC_PRER_PREDIV_S >> RTC_PRER_PREDIV_S_Pos)) |
| #define | IS_RTC_HOUR12(HOUR) (((HOUR) > 0u) && ((HOUR) <= 12u)) |
| #define | IS_RTC_HOUR24(HOUR) ((HOUR) <= 23u) |
| #define | IS_RTC_MINUTES(MINUTES) ((MINUTES) <= 59u) |
| #define | IS_RTC_SECONDS(SECONDS) ((SECONDS) <= 59u) |
Enumerations | |
| enum | HAL_RTCStateTypeDef { HAL_RTC_STATE_RESET = 0x00U , HAL_RTC_STATE_READY = 0x01U , HAL_RTC_STATE_BUSY = 0x02U , HAL_RTC_STATE_TIMEOUT = 0x03U , HAL_RTC_STATE_ERROR = 0x04U } |
| HAL State structures definition. More... | |
| HAL_StatusTypeDef | HAL_RTC_Init (RTC_HandleTypeDef *hrtc) |
| HAL_StatusTypeDef | HAL_RTC_DeInit (RTC_HandleTypeDef *hrtc) |
| void | HAL_RTC_MspInit (RTC_HandleTypeDef *hrtc) |
| void | HAL_RTC_MspDeInit (RTC_HandleTypeDef *hrtc) |
| HAL_StatusTypeDef | HAL_RTC_SetTime (RTC_HandleTypeDef *hrtc, RTC_TimeTypeDef *sTime, uint32_t Format) |
| HAL_StatusTypeDef | HAL_RTC_GetTime (RTC_HandleTypeDef *hrtc, RTC_TimeTypeDef *sTime, uint32_t Format) |
| HAL_StatusTypeDef | HAL_RTC_SetDate (RTC_HandleTypeDef *hrtc, RTC_DateTypeDef *sDate, uint32_t Format) |
| HAL_StatusTypeDef | HAL_RTC_GetDate (RTC_HandleTypeDef *hrtc, RTC_DateTypeDef *sDate, uint32_t Format) |
| HAL_StatusTypeDef | HAL_RTC_SetAlarm (RTC_HandleTypeDef *hrtc, RTC_AlarmTypeDef *sAlarm, uint32_t Format) |
| HAL_StatusTypeDef | HAL_RTC_SetAlarm_IT (RTC_HandleTypeDef *hrtc, RTC_AlarmTypeDef *sAlarm, uint32_t Format) |
| HAL_StatusTypeDef | HAL_RTC_DeactivateAlarm (RTC_HandleTypeDef *hrtc, uint32_t Alarm) |
| HAL_StatusTypeDef | HAL_RTC_GetAlarm (RTC_HandleTypeDef *hrtc, RTC_AlarmTypeDef *sAlarm, uint32_t Alarm, uint32_t Format) |
| void | HAL_RTC_AlarmIRQHandler (RTC_HandleTypeDef *hrtc) |
| void | HAL_RTC_AlarmAEventCallback (RTC_HandleTypeDef *hrtc) |
| ALARM A Event Callback in non blocking mode. | |
| HAL_StatusTypeDef | HAL_RTC_PollForAlarmAEvent (RTC_HandleTypeDef *hrtc, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_RTC_WaitForSynchro (RTC_HandleTypeDef *hrtc) |
| HAL_RTCStateTypeDef | HAL_RTC_GetState (RTC_HandleTypeDef *hrtc) |
| HAL_StatusTypeDef | RTC_EnterInitMode (RTC_HandleTypeDef *hrtc) |
| HAL_StatusTypeDef | RTC_ExitInitMode (RTC_HandleTypeDef *hrtc) |
| uint8_t | RTC_ByteToBcd2 (uint8_t Value) |
| uint8_t | RTC_Bcd2ToByte (uint8_t Value) |
