RTEMS 6.2
Header file of SD HAL extended module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
Enumerations | |
| enum | HAL_MMCEx_DMABuffer_MemoryTypeDef { MMC_DMA_BUFFER0 = 0x00U , MMC_DMA_BUFFER1 = 0x01U } |
| HAL_StatusTypeDef | HAL_MMCEx_ConfigDMAMultiBuffer (MMC_HandleTypeDef *hmmc, uint32_t *pDataBuffer0, uint32_t *pDataBuffer1, uint32_t BufferSize) |
| HAL_StatusTypeDef | HAL_MMCEx_ReadBlocksDMAMultiBuffer (MMC_HandleTypeDef *hmmc, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
| HAL_StatusTypeDef | HAL_MMCEx_WriteBlocksDMAMultiBuffer (MMC_HandleTypeDef *hmmc, uint32_t BlockAdd, uint32_t NumberOfBlocks) |
| HAL_StatusTypeDef | HAL_MMCEx_ChangeDMABuffer (MMC_HandleTypeDef *hmmc, HAL_MMCEx_DMABuffer_MemoryTypeDef Buffer, uint32_t *pDataBuffer) |
| void | HAL_MMCEx_Read_DMADoubleBuf0CpltCallback (MMC_HandleTypeDef *hmmc) |
| void | HAL_MMCEx_Read_DMADoubleBuf1CpltCallback (MMC_HandleTypeDef *hmmc) |
| void | HAL_MMCEx_Write_DMADoubleBuf0CpltCallback (MMC_HandleTypeDef *hmmc) |
| void | HAL_MMCEx_Write_DMADoubleBuf1CpltCallback (MMC_HandleTypeDef *hmmc) |
