RTEMS 6.2
Header file of HSEM HAL module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| #define | __HAL_HSEM_SEMID_TO_MASK(__SEMID__) (1 << (__SEMID__)) |
| SemID to mask helper Macro. | |
| #define | __HAL_HSEM_ENABLE_IT(__SEM_MASK__) (HSEM->IER |= (__SEM_MASK__)) |
| Enables the specified HSEM interrupts. | |
| #define | __HAL_HSEM_DISABLE_IT(__SEM_MASK__) (HSEM->IER &= ~(__SEM_MASK__)) |
| Disables the specified HSEM interrupts. | |
| #define | __HAL_HSEM_GET_IT(__SEM_MASK__) ((__SEM_MASK__) & HSEM->MISR) |
| Checks whether interrupt has occurred or not for semaphores specified by a mask. | |
| #define | __HAL_HSEM_GET_FLAG(__SEM_MASK__) ((__SEM_MASK__) & HSEM->ISR) |
| Get the semaphores release status flags. | |
| #define | __HAL_HSEM_CLEAR_FLAG(__SEM_MASK__) (HSEM->ICR |= (__SEM_MASK__)) |
| Clears the HSEM Interrupt flags. | |
| #define | IS_HSEM_SEMID(__SEMID__) ((__SEMID__) <= HSEM_SEMID_MAX ) |
| #define | IS_HSEM_PROCESSID(__PROCESSID__) ((__PROCESSID__) <= HSEM_PROCESSID_MAX ) |
| #define | IS_HSEM_KEY(__KEY__) ((__KEY__) <= HSEM_CLEAR_KEY_MAX ) |
| #define | IS_HSEM_COREID(__COREID__) ((__COREID__) == HSEM_CPU1_COREID) |
| HAL_StatusTypeDef | HAL_HSEM_Take (uint32_t SemID, uint32_t ProcessID) |
| HAL_StatusTypeDef | HAL_HSEM_FastTake (uint32_t SemID) |
| void | HAL_HSEM_Release (uint32_t SemID, uint32_t ProcessID) |
| void | HAL_HSEM_ReleaseAll (uint32_t Key, uint32_t CoreID) |
| uint32_t | HAL_HSEM_IsSemTaken (uint32_t SemID) |
| void | HAL_HSEM_SetClearKey (uint32_t Key) |
| uint32_t | HAL_HSEM_GetClearKey (void) |
| void | HAL_HSEM_ActivateNotification (uint32_t SemMask) |
| void | HAL_HSEM_DeactivateNotification (uint32_t SemMask) |
| void | HAL_HSEM_FreeCallback (uint32_t SemMask) |
| void | HAL_HSEM_IRQHandler (void) |
