RTEMS 6.2
Header file of FLASH HAL module. More...
| struct | FLASH_ProcessTypeDef |
| FLASH handle Structure definition. More... | |
Enumerations | |
| enum | FLASH_ProcedureTypeDef { FLASH_PROC_NONE = 0U , FLASH_PROC_SECTERASE_BANK1 , FLASH_PROC_MASSERASE_BANK1 , FLASH_PROC_PROGRAM_BANK1 , FLASH_PROC_SECTERASE_BANK2 , FLASH_PROC_MASSERASE_BANK2 , FLASH_PROC_PROGRAM_BANK2 , FLASH_PROC_ALLBANK_MASSERASE } |
| FLASH Procedure structure definition. | |
| HAL_StatusTypeDef | HAL_FLASH_Program (uint32_t TypeProgram, uint32_t FlashAddress, uint32_t DataAddress) |
| HAL_StatusTypeDef | HAL_FLASH_Program_IT (uint32_t TypeProgram, uint32_t FlashAddress, uint32_t DataAddress) |
| void | HAL_FLASH_IRQHandler (void) |
| void | HAL_FLASH_EndOfOperationCallback (uint32_t ReturnValue) |
| void | HAL_FLASH_OperationErrorCallback (uint32_t ReturnValue) |
| HAL_StatusTypeDef | HAL_FLASH_Unlock (void) |
| HAL_StatusTypeDef | HAL_FLASH_Lock (void) |
| HAL_StatusTypeDef | HAL_FLASH_OB_Unlock (void) |
| HAL_StatusTypeDef | HAL_FLASH_OB_Lock (void) |
| HAL_StatusTypeDef | HAL_FLASH_OB_Launch (void) |
| uint32_t | HAL_FLASH_GetError (void) |
| HAL_StatusTypeDef | FLASH_WaitForLastOperation (uint32_t Timeout, uint32_t Bank) |
| HAL_StatusTypeDef | FLASH_OB_WaitForLastOperation (uint32_t Timeout) |
| HAL_StatusTypeDef | FLASH_CRC_WaitForLastOperation (uint32_t Timeout, uint32_t Bank) |
| FLASH_ProcessTypeDef | pFlash |
