RTEMS 6.2
stm32h7xx_hal_cec.c File Reference
CEC HAL module driver. This file provides firmware functions to manage the following functionalities of the High Definition Multimedia Interface Consumer Electronics Control Peripheral (CEC). More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization function
  • IO operation function
  • Peripheral Control function
Attention
                       ##### How to use this driver #####
   The CEC HAL driver can be used as follow:
   (#) Declare a CEC_HandleTypeDef handle structure.
   (#) Initialize the CEC low level resources by implementing the HAL_CEC_MspInit ()API:
       (##) Enable the CEC interface clock.
       (##) CEC pins configuration:
           (+++) Enable the clock for the CEC GPIOs.
           (+++) Configure these CEC pins as alternate function pull-up.
       (##) NVIC configuration if you need to use interrupt process (HAL_CEC_Transmit_IT()
            and HAL_CEC_Receive_IT() APIs):
           (+++) Configure the CEC interrupt priority.
           (+++) Enable the NVIC CEC IRQ handle.
           (+++) The specific CEC interrupts (Transmission complete interrupt,
                 RXNE interrupt and Error Interrupts) will be managed using the macros
                 __HAL_CEC_ENABLE_IT() and __HAL_CEC_DISABLE_IT() inside the transmit
                 and receive process.
   (#) Program the Signal Free Time (SFT) and SFT option, Tolerance, reception stop in
       in case of Bit Rising Error, Error-Bit generation conditions, device logical
       address and Listen mode in the hcec Init structure.
   (#) Initialize the CEC registers by calling the HAL_CEC_Init() API.
   (@) This API (HAL_CEC_Init()) configures also the low level Hardware (GPIO, CLOCK, CORTEX...etc)
       by calling the customed HAL_CEC_MspInit() API.
 *** Callback registration ***
 The compilation define  USE_HAL_CEC_REGISTER_CALLBACKS when set to 1
 allows the user to configure dynamically the driver callbacks.
 Use Functions HAL_CEC_RegisterCallback() or HAL_CEC_RegisterXXXCallback()
 to register an interrupt callback.
 Function HAL_CEC_RegisterCallback() allows to register following callbacks:
   (+) TxCpltCallback     : Tx Transfer completed callback.
   (+) ErrorCallback      : callback for error detection.
   (+) MspInitCallback    : CEC MspInit.
   (+) MspDeInitCallback  : CEC MspDeInit.
 This function takes as parameters the HAL peripheral handle, the Callback ID
 and a pointer to the user callback function.
 For specific callback HAL_CEC_RxCpltCallback use dedicated register callbacks
 HAL_CEC_RegisterRxCpltCallback().
 Use function HAL_CEC_UnRegisterCallback() to reset a callback to the default
 weak function.
 HAL_CEC_UnRegisterCallback() takes as parameters the HAL peripheral handle,
 and the Callback ID.
 This function allows to reset following callbacks:
 For callback HAL_CEC_RxCpltCallback use dedicated unregister callback :
 HAL_CEC_UnRegisterRxCpltCallback().
 By default, after the HAL_CEC_Init() and when the state is HAL_CEC_STATE_RESET
 all callbacks are set to the corresponding weak functions :
 examples HAL_CEC_TxCpltCallback() , HAL_CEC_RxCpltCallback().
 Exception done for MspInit and MspDeInit functions that are
 reset to the legacy weak function in the HAL_CEC_Init()/ HAL_CEC_DeInit() only when
 these callbacks are null (not registered beforehand).
 if not, MspInit or MspDeInit are not null, the HAL_CEC_Init() / HAL_CEC_DeInit()
 keep and use the user MspInit/MspDeInit functions (registered beforehand)
 Callbacks can be registered/unregistered in HAL_CEC_STATE_READY state only.
 Exception done MspInit/MspDeInit callbacks that can be registered/unregistered
 in HAL_CEC_STATE_READY or HAL_CEC_STATE_RESET state,
 thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
 In that case first register the MspInit/MspDeInit user callbacks
 using HAL_CEC_RegisterCallback() before calling HAL_CEC_DeInit()
 or HAL_CEC_Init() function.
 When the compilation define USE_HAL_CEC_REGISTER_CALLBACKS is set to 0 or
 not defined, the callback registration feature is not available and all callbacks
 are set to the corresponding weak functions.
