RTEMS 6.2
spi-flash-m25p40.h
2
3/*
4 * SPI driver for M25P40 like spi flash device
5 *
6 * FIXME: currently, this driver only supports read/write accesses
7 * erase accesses are to be completed
8 */
9
10/*
11 * Copyright (c) 2007 embedded brains GmbH & Co. KG
12 *
13 * Redistribution and use in source and binary forms, with or without
14 * modification, are permitted provided that the following conditions
15 * are met:
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 * 2. Redistributions in binary form must reproduce the above copyright
19 * notice, this list of conditions and the following disclaimer in the
20 * documentation and/or other materials provided with the distribution.
21 *
22 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32 * POSSIBILITY OF SUCH DAMAGE.
33 */
34
35#ifndef _LIBCHIP_SPI_FLASH_M25P40_H
36#define _LIBCHIP_SPI_FLASH_M25P40_H
37
38#include <libchip/spi-memdrv.h>
39
40#ifdef __cplusplus
41extern "C" {
42#endif
43
44/*
45 * pass one of these descriptor pointers to rtems_libi2c_register_drv
46 */
47extern rtems_libi2c_drv_t *spi_flash_m25p40_rw_driver_descriptor;
48
49extern rtems_libi2c_drv_t *spi_flash_m25p40_ro_driver_descriptor;
50
51#ifdef __cplusplus
52}
53#endif
54
55#endif /* _LIBCHIP_SPI_FLASH_M25P40_H */
Definition: libi2c.h:297
