RTEMS 6.2
Macros | Functions
serial_mouse.h File Reference
Serial Mouse Driver. More...
#include <rtems/io.h>
#define SERIAL_MOUSE_DEVICE_PS2   "/dev/psaux"
 Standard device file path for a PS2 mouse device.
#define SERIAL_MOUSE_DRIVER_TABLE_ENTRY
rtems_device_driver serial_mouse_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 The initialization of the serial mouse driver.
rtems_device_driver serial_mouse_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Open device driver entry point for the serial mouse driver.
rtems_device_driver serial_mouse_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Close device driver entry point for the serial mouse driver.
rtems_device_driver serial_mouse_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Read device driver entry point for the serial mouse driver.
rtems_device_driver serial_mouse_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Write device driver entry point for the serial mouse driver.
rtems_device_driver serial_mouse_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 IO Control device driver entry point for the serial mouse driver.
bool bsp_get_serial_mouse_device (const char **name, const char **type)
 Obtain serial mouse configuration information.
This file describes the Serial Mouse Driver for all boards. This driver assumes that the BSP or application will provide an implementation of the method bsp_get_serial_mouse_device() which tells the driver what serial port device to open() and what type of mouse is connected.
This driver relies on the Mouse Parser Engine.
