RTEMS 6.2
This header file provides the interfaces of the Strong APA Scheduler. More...
| struct | Scheduler_strong_APA_Node |
| Scheduler node specialization for Strong APA schedulers. More... | |
| struct | Scheduler_strong_APA_CPU |
| CPU related variables and a CPU_Control to implement BFS. More... | |
| struct | Scheduler_strong_APA_Context |
| Scheduler context and node definition for Strong APA scheduler. More... | |
| #define | SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY 255 |
| #define | SCHEDULER_STRONG_APA_ENTRY_POINTS |
| Entry points for the Strong APA Scheduler. | |
| void | _Scheduler_strong_APA_Initialize (const Scheduler_Control *scheduler) |
| Initializes the scheduler. | |
| void | _Scheduler_strong_APA_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| Initializes the node with the given priority. | |
| void | _Scheduler_strong_APA_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Blocks the thread. | |
| void | _Scheduler_strong_APA_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Unblocks the thread. | |
| void | _Scheduler_strong_APA_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Updates the priority of the node. | |
| bool | _Scheduler_strong_APA_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Asks for help. | |
| void | _Scheduler_strong_APA_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Reconsiders help request. | |
| void | _Scheduler_strong_APA_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state) |
| Withdraws the node. | |
| void | _Scheduler_strong_APA_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Makes the node sticky. | |
| void | _Scheduler_strong_APA_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Cleans the sticky property from the node. | |
| void | _Scheduler_strong_APA_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| void | _Scheduler_strong_APA_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle) |
| Adds the idle thread to a processor. | |
| Thread_Control * | _Scheduler_strong_APA_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu) |
| Removes an idle thread from the given cpu. | |
| void | _Scheduler_strong_APA_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Performs a yield operation. | |
| void | _Scheduler_strong_APA_Start_idle (const Scheduler_Control *scheduler, Thread_Control *idle, struct Per_CPU_Control *cpu) |
| Starts an idle thread. | |
| Status_Control | _Scheduler_strong_APA_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, const Processor_mask *affinity) |
| Sets the affinity . | |
