17void BSP_uart_init(
int uart,
int baud,
int hwFlow);
18void BSP_uart_set_baud(
int uart,
int baud);
19void BSP_uart_intr_ctrl(
int uart,
int cmd);
20void BSP_uart_throttle(
int uart);
21void BSP_uart_unthrottle(
int uart);
22int BSP_uart_polled_status(
int uart);
23void BSP_uart_polled_write(
int uart,
int val);
24int BSP_uart_polled_read(
int uart);
25void BSP_uart_termios_set(
int uart,
void *ttyp);
26ssize_t BSP_uart_termios_write_com(
int minor,
const char *buf,
size_t len);
27int BSP_uart_termios_read_com (
int minor);
28void BSP_uart_termios_isr_com1(
void *unused);
29void BSP_uart_termios_isr_com2(
void *unused);
30void BSP_uart_dbgisr_com1(
void);
31void BSP_uart_dbgisr_com2(
void);
32int BSP_uart_install_isr(
int uart, rtems_irq_hdl handler);
33int BSP_uart_remove_isr(
34ssize_t BSP_uart_termios_write_polled(
int minor,
const char *buf,
size_t len);
38extern unsigned BSP_poll_char_via_serial(
void);
39extern void BSP_output_char_via_serial(
const char val);
40extern int BSPConsolePort;
41extern int BSPBaseBaud;
48typedef void (*BSP_UartBreakCbProc)(
50 unsigned uartRBRLSRStatus,
51 void *termiosPrivatePtr,
56 BSP_UartBreakCbProc handler;
60#define BIOCGETBREAKCB _IOR('b',1,sizeof(BSP_UartBreakCbRec))
61#define BIOCSETBREAKCB _IOW('b',2,sizeof(BSP_UartBreakCbRec))
68#define BSP_UART_INTR_CTRL_DISABLE (0)
69#define BSP_UART_INTR_CTRL_GDB (0xaa)
70#define BSP_UART_INTR_CTRL_ENABLE (0xbb)
71#define BSP_UART_INTR_CTRL_TERMIOS (0xcc)
74#define BSP_UART_STATUS_ERROR (-1)
75#define BSP_UART_STATUS_NOCHAR (0)
76#define BSP_UART_STATUS_CHAR (1)
77#define BSP_UART_STATUS_BREAK (2)
80#define BSP_UART_COM1 (0)
81#define BSP_UART_COM2 (1)
109#define MODEM_STATUS 0
110#define NO_MORE_INTR 1
111#define TRANSMITTER_HODING_REGISTER_EMPTY 2
112#define RECEIVER_DATA_AVAIL 4
113#define RECEIVER_ERROR 6
114#define CHARACTER_TIMEOUT_INDICATION 12
119#define RECEIVE_ENABLE 0x1
120#define TRANSMIT_ENABLE 0x2
121#define RECEIVER_LINE_ST_ENABLE 0x4
122#define MODEM_ENABLE 0x8
123#define INTERRUPT_DISABLE 0x0
178#define FIFO_CTRL 0x01
180#define XMIT_RESET 0x02
181#define RCV_RESET 0x04
184#define RECEIVE_FIFO_TRIGGER1 0x00
185#define RECEIVE_FIFO_TRIGGER4 0x40
186#define RECEIVE_FIFO_TRIGGER8 0x80
187#define RECEIVE_FIFO_TRIGGER12 0xc0
188#define TRIG_LEVEL 0xc0
Parameter block for ioctl.
Definition: libio.h:1375
