RTEMS 6.2
Data Structures | Typedefs | Functions
pipe.h File Reference
POSIX FIFO/pipe File System Support. More...
#include <rtems/libio.h>
#include <rtems/thread.h>
struct  pipe_control
typedef struct pipe_control pipe_control_t
void pipe_release (pipe_control_t **pipep, rtems_libio_t *iop)
 Release a pipe.
int fifo_open (pipe_control_t **pipep, rtems_libio_t *iop)
 File system open. Interface to file system open.
ssize_t pipe_read (pipe_control_t *pipe, void *buffer, size_t count, rtems_libio_t *iop)
 File system read.
ssize_t pipe_write (pipe_control_t *pipe, const void *buffer, size_t count, rtems_libio_t *iop)
 File system write.
int pipe_ioctl (pipe_control_t *pipe, ioctl_command_t cmd, void *buffer, rtems_libio_t *iop)
 File system Input/Output control.
This include file defines the interface to the POSIX FIFO/pipe file system support.
