RTEMS
6.2
score
cpu
nios2
include
score
nios2.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
15
16
* COPYRIGHT (c) 1989-1999.
17
* On-Line Applications Research Corporation (OAR).
18
19
20
* modification, are permitted provided that the following conditions
21
* are met:
22
* 1. Redistributions of source code must retain the above copyright
23
* notice, this list of conditions and the following disclaimer.
24
* 2. Redistributions in binary form must reproduce the above copyright
25
* notice, this list of conditions and the following disclaimer in the
26
* documentation and/or other materials provided with the distribution.
27
28
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38
* POSSIBILITY OF SUCH DAMAGE.
39
40
41
42
#ifndef _RTEMS_SCORE_NIOS2_H
43
#define _RTEMS_SCORE_NIOS2_H
44
45
#ifdef __cplusplus
46
extern
"C"
47
#endif
48
49
50
* This file contains the information required to build
51
* RTEMS for a particular member of the NIOS2 family.
52
* It does this by setting variables to indicate which
53
* implementation dependent features are present in a particular
54
* member of the family.
55
56
* This is a good place to list all the known CPU models
57
* that this port supports and which RTEMS CPU model they correspond
58
* to.
59
60
61
62
* Define the name of the CPU family and specific model.
63
64
65
#define CPU_NAME "NIOS2"
66
#define CPU_MODEL_NAME "nios2"
67
68
69
* See also nios2-rtems-gcc -print-multi-lib for all valid combinations of
70
71
* -mno-hw-mul
72
* -mhw-mulx
73
* -mstack-check
74
* -pg
75
* -EB
76
* -mcustom-fpu-cfg=60-1
77
* -mcustom-fpu-cfg=60-2
78
79
80
#ifdef __cplusplus
81
82
#endif
83
84
#endif
/* _RTEMS_SCORE_NIOS2_H */
