RTEMS 6.2
mcfuart.h
1/*
2 * Generic UART Serial driver for Motorola Coldfire processors definitions
3 *
4 * Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russian Fed.
5 * Author: Victor V. Vengerov <vvv@oktet.ru>
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 */
11
12#ifndef __MCFUART_H__
13#define __MCFUART_H__
14
15#include <termios.h>
16#include "bsp.h"
17#include "mcf5206e.h"
18
19/*
20 * The MCF5206e System Clock Frequency; 54MHz default
21 */
22#ifndef SYSTEM_CLOCK_FREQUENCY
23#define SYSTEM_CLOCK_FREQUENCY BSP_SYSTEM_FREQUENCY
24#endif
25
26/*
27 * The following structure is a descriptor of single UART channel.
28 * It contains the initialization information about channel and
29 * current operating values
30 */
31typedef struct mcfuart {
32 uint32_t chn; /* UART channel number */
33 uint8_t intvec; /* UART interrupt vector number, or
34 0 if polled I/O */
35 void *tty; /* termios channel descriptor */
36
37 volatile const char *tx_buf; /* Transmit buffer from termios */
38 volatile uint32_t tx_buf_len; /* Transmit buffer length */
39 volatile uint32_t tx_ptr; /* Index of next char to transmit*/
40 rtems_isr_entry old_handler; /* Saved interrupt handler */
41
42 tcflag_t c_iflag; /* termios input mode flags */
43 bool parerr_mark_flag; /* Parity error processing
44 state */
45} mcfuart;
46
47/* mcfuart_init --
48 * This function verifies the input parameters and perform initialization
49 * of the Motorola Coldfire on-chip UART descriptor structure.
50 *
51 */
53mcfuart_init(mcfuart *uart, void *tty, uint8_t intvec,
54 uint32_t chn);
55
56/* mcfuart_reset --
57 * This function perform the hardware initialization of Motorola
58 * Coldfire processor on-chip UART controller using parameters
59 * filled by the mcfuart_init function.
60 */
62mcfuart_reset(mcfuart *uart);
63
64/* mcfuart_disable --
65 * This function disable the operations on Motorola Coldfire UART
66 * controller
67 */
69mcfuart_disable(mcfuart *uart);
70
71/* mcfuart_set_attributes --
72 * This function parse the termios attributes structure and perform
73 * the appropriate settings in hardware.
74 */
75int
76mcfuart_set_attributes(mcfuart *mcf, const struct termios *t);
77
78/* mcfuart_poll_read --
79 * This function tried to read character from MCF UART and perform
80 * error handling.
81 */
82int
83mcfuart_poll_read(mcfuart *uart);
84
85/* mcfuart_interrupt_write --
86 * This function initiate transmitting of the buffer in interrupt mode.
87 */
88ssize_t
89mcfuart_interrupt_write(mcfuart *uart, const char *buf, size_t len);
90
91/* mcfuart_poll_write --
92 * This function transmit buffer byte-by-byte in polling mode.
93 */
94ssize_t
95mcfuart_poll_write(mcfuart *uart, const char *buf, size_t len);
96
97/* mcfuart_stop_remote_tx --
98 * This function stop data flow from remote device.
99 */
100int
101mcfuart_stop_remote_tx(mcfuart *uart);
102
103/* mcfuart_start_remote_tx --
104 * This function resume data flow from remote device.
105 */
106int
107mcfuart_start_remote_tx(mcfuart *uart);
108
109#endif
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
rtems_status_code
Definition: status.h:85
Definition: mcfuart.h:31
