RTEMS 6.2
lpc-clock-config.h
2
11/*
12 * Copyright (c) 2009 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC176X_LPC_CLOCK_CONFIG_H
37#define LIBBSP_ARM_LPC176X_LPC_CLOCK_CONFIG_H
38
39#include <bsp.h>
40#include <bsp/irq.h>
41#include <bsp/lpc176x.h>
42#include <bsp/io.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif /* __cplusplus */
47
48#define LPC_CLOCK_INTERRUPT LPC176X_IRQ_TIMER_0
49#define LPC_CLOCK_TIMER_BASE TMR0_BASE_ADDR
50#define LPC_CLOCK_TIMECOUNTER_BASE TMR1_BASE_ADDR
51#define LPC_CLOCK_REFERENCE LPC176X_PCLK
52#define LPC_CLOCK_MODULE_ENABLE() \
53 lpc176x_module_enable( LPC176X_MODULE_TIMER_0, LPC176X_MODULE_PCLK_DEFAULT )
54
55#ifdef __cplusplus
56}
57#endif /* __cplusplus */
58
59#endif /* LIBBSP_ARM_LPC176X_LPC_CLOCK_CONFIG_H */
Specific register definitions according to lpc176x family boards.
