RTEMS 6.2
This header file provides the linker sets API. More...
#include <rtems/score/basedefs.h>Go to the source code of this file.
| #define | RTEMS_LINKER_SET_BEGIN(set) _Linker_set_##set##_begin |
| #define | RTEMS_LINKER_SET_END(set) _Linker_set_##set##_end |
| #define | RTEMS_LINKER_SET_ALIGN(type) RTEMS_ALIGNED( RTEMS_ALIGNOF( type ) ) |
| #define | RTEMS_LINKER_ROSET_DECLARE(set, type) |
| #define | RTEMS_LINKER_ROSET(set, type) |
| #define | RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE(set, type, item, order) |
| #define | RTEMS_LINKER_ROSET_ITEM_DECLARE(set, type, item) |
| #define | RTEMS_LINKER_ROSET_ITEM_REFERENCE(set, type, item) |
| #define | RTEMS_LINKER_ROSET_ITEM_ORDERED(set, type, item, order) |
| #define | RTEMS_LINKER_ROSET_ITEM(set, type, item) |
| #define | RTEMS_LINKER_ROSET_CONTENT(set, decl) |
| #define | RTEMS_LINKER_RWSET_DECLARE(set, type) |
| #define | RTEMS_LINKER_RWSET(set, type) |
| #define | RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE(set, type, item, order) |
| #define | RTEMS_LINKER_RWSET_ITEM_DECLARE(set, type, item) |
| #define | RTEMS_LINKER_RWSET_ITEM_REFERENCE(set, type, item) |
| #define | RTEMS_LINKER_RWSET_ITEM_ORDERED(set, type, item, order) |
| #define | RTEMS_LINKER_RWSET_ITEM(set, type, item) |
| #define | RTEMS_LINKER_RWSET_CONTENT(set, decl) |
| #define | RTEMS_LINKER_SET_SIZE(set) |
| #define | RTEMS_LINKER_SET_ITEM_COUNT(set) |
| #define | RTEMS_LINKER_SET_IS_EMPTY(set) ( RTEMS_LINKER_SET_SIZE( set ) == 0 ) |
| #define | RTEMS_LINKER_SET_FOREACH(set, item) |
